koozy Samba Member
Posted: Sat Dec 20, 2025 7:55 pm Post subject: 71 double cab new rear brake drum face too thick |
What am I missing here. Has anyone had this issue? 71 double cab new rear brake drum face too thick so when I put it on, the studs are now too short.
Called and asked the salesman and he said he's never heard of this problem. Am I using the wrong drum?
Thanks in advance,
Mike |
richparker Samba Member
Joined: November 24, 2011 Posts: 7833 Location: Durango, CO
Posted: Sat Dec 20, 2025 10:43 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
After market parts aren’t always what they should be? Did you buy German drums?
Although it’s certainly thicker, I can’t imagine 3.26mm being an issue with the wheel studs. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab |
koozy Samba Member
Posted: Sat Dec 20, 2025 10:45 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17791 Location: San Diego, California
Posted: Sat Dec 20, 2025 11:11 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
Isn’t that a Vanagon wheel? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
koozy Samba Member
Posted: Sat Dec 20, 2025 11:15 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
| I don't know. Is it? Maybe that's the problem |
koozy Samba Member
Posted: Sat Dec 20, 2025 11:16 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
| How do I tell the difference? Please forgive my ignorance |
Posted: Sat Dec 20, 2025 11:20 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
What I’m actually referring to is the center of the wheel. The flowered one like you have might not seat around the round hub _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Sat Dec 20, 2025 11:25 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
https://www.mamotorworks.com/vw/knowledgelibrary/exterior/volkswagen-rims-what-you-should-know
The last pic shows a round center _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
koozy Samba Member
koozy Samba Member
Posted: Sat Dec 20, 2025 11:30 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
| But I see what you are saying. I'll look at that when I get to the shop tomorrow. That's a good point. Thanks!!! |
Posted: Sat Dec 20, 2025 11:36 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
Yeah I saw they listed it like that but if you examine your pic closely, you’ll see that where the flower petals are the paint it chipped. That tells me that it’s interfering with the mate of the hub and wheel. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
koozy Samba Member
Posted: Sat Dec 20, 2025 11:43 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
Before replacing the drum
Posted: Sat Dec 20, 2025 11:49 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
I’m probably wrong. Anyway, I’ve never seen this particular problem before but I have seen some pretty poorly copied Chinese bus drums before. In one case they wouldn’t even slide over the axle splines (split bus) and the American vendor knew about the issue but didn’t want to get stuck eating the loss so they sold them anyway hoping that many wouldn’t be returned for credit. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
koozy Samba Member
Posted: Sat Dec 20, 2025 11:55 pm Post subject: Re: 71 double cab new rear brake drum face too thick |
| Gives me something to check, so thanks for the info. It may just be the drums are being made a bit too thick and folks just run them this way. Worst case I'll just replace the studs with good quality longer ones. |
Posted: Sun Dec 21, 2025 12:00 am Post subject: Re: 71 double cab new rear brake drum face too thick |
Maybe the extra thickness makes up for the poor quality steel? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
koozy Samba Member
Posted: Sun Dec 21, 2025 12:03 am Post subject: Re: 71 double cab new rear brake drum face too thick |
The thought crossed my mind.
I was hoping someone was gonna chime in and say something like "The 71 came in two configurations. The super early German delivered one had the bla bla bla that came with the thinner drum and you have to order part number XXX1234 or they send you the late model one that is thicker"
Dang |
germansupplyscott Samba Member
Posted: Sun Dec 21, 2025 9:50 am Post subject: Re: 71 double cab new rear brake drum face too thick |
| koozy wrote: |
That's not an easy repair, the rear studs are difficult to match due to the diameter of the spline where they press into the hub.
I will measure a drum later today and post what I find, but pretty sure something is wrong with drums you have. When the drum is installed on the hub, the outer surface of the drum will be flush with the step on the hub. In the photo I am referring to where the drum fits over the hub, you can see there is no step there, it's flush. Your drum would have a ~3mm step. Photos below are a '71 with original drums.
_________________ SL |
koozy Samba Member
Posted: Sun Dec 21, 2025 10:27 am Post subject: Re: 71 double cab new rear brake drum face too thick |
| Thanks for the great info and photos. I think the part is wrong and will order another set with the correct part number |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4158 Location: Seattle, WA
Posted: Sun Dec 21, 2025 11:05 am Post subject: Re: 71 double cab new rear brake drum face too thick |
I"ve got a set of brand-new brake drums for my '71 bus, do not remember where or when purchased but have "BDM" markings. The web measurement varies from 2.75 to 3.25 mm, both sides have a layer of self-applied paint.
It would be really helpful if folks reporting on problematic parts would disclose the seller and brand info, if known. _________________ '67 bug: seized by the authorities
