BFB Samba Member
Posted: Tue Dec 23, 2025 9:47 pm Post subject: Re: Another super stockish build |
What never gets asked is why the big boys running boost run hemi chambers… no one here wants to look into that for fear they might be wrong about something.
I’d say the hemi heads are trash if you use them like st. Berg suggests with 7:1 cr then all the common knowledge about it thats spewed out here probably does apply. Unless st. Berg was here to tell everyone why it was a good idea, then theyd all get back on the bandwagon.
The chambers im talking about though, put those to shame… interesting thing id read about this type of chamber is that it works great for eliminating pre-ignition because theres no edges and hot spots like a traditional chamber with “squish”.
Far as these heads though, with that chamber id run more compression than 8.4 and i sure wouldnt run Cerekote, thats stuff is garbage, at least the non bake ceramic coating is. Maybe the bake on stuff is better, i dunno. Not interested in finding out. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7978 Location: Videbaek Denmark
Posted: Wed Dec 24, 2025 12:38 am Post subject: Re: Another super stockish build |
Show me ONE high ranking ACVW turbo engine that has SH heads
A few turbo/nitrous engines run 4 degrees tilted squish opposite the plug. Thats not hemi. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4331 Location: Rapid City, South Dakota
Posted: Wed Dec 24, 2025 9:34 am Post subject: Re: Another super stockish build |
| BFB wrote: |
| What never gets asked is why the big boys running boost run hemi chambers… no one here wants to look into that for fear they might be wrong about something. |
It's not that no one wants to talk about it.........its common sense.......
They run hemi chambers because doing the hemi cut is one of the only ways to add a huge amount of chamber volume to keep the compression low for a turbo. If you try to pull 10cc out of just about any chamber shape, its gonna end up looking like a giant bathtub hemi chamber. Same exact reason Berg did it. Its the easiest way to remove material. Then give it a fancy name to make it sound impressive so people will buy into it.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
BFB Samba Member
Posted: Wed Dec 24, 2025 10:07 am Post subject: Re: Another super stockish build |
did I say it was VW specific? no, but I like how you try to load your question as it narrows down the scope of it so that your weighing it heavier on your side to try to prove your point. THEN you'll say something stupid like vw is a different engine than say an LS or any other internal combustion 4 cycle engine just to again, try to prove your right.
also, your holding onto the st. Berg term of "SH" , and trying to cover your ass with what's not a "SH" head too....
you need to calm down, the fuck you getting so worked up about and so adamant you have to be right for? you doing shit like this is why certain subjects dont get discussed and why matthewl made the disclaimer in his initial post about how much hate there is. he already knew there'd be some dipshit sidetracking things because they think they know everything, yet he still wanted to post what he's got going on inspite of there being a YOU thats going to start shit about it.
if you dont like it, thats fine, but how about you be an adult, shut your mouth and let ol boy have his day without you pissing all over it.
but to answer your question, I have seen a set of of Pauter heads with hemispherical chambers. ( not SH ).
now, I couldn't give a shit less what you all think nor is it my job to prove your wrong. I dont care, im not like you and dont think everyone has to bow down to my superior knowledge nor do I think ppl need to agree with me, thats childish. nor do I see any of you doing something so amazing that you need to be recognized as being an authority on the subject. pretty sure you, Alstrup was the same one that one telling someone they had pre-detotanion?? personally I think ya'll look stupid because you fell right into the hater category that Matthewl mentioned. nice job. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Posted: Wed Dec 24, 2025 10:32 am Post subject: Re: Another super stockish build |
I never said a bad thing about the SH chambers, I was just answering your question as to WHY its done in the VW world.
No need to hate anything here. I have a really good idea what the outcome of his engine will be regardless of what the chamber shape is. Some chamber shapes will make it slightly better, and some will make it worse.
-Modok
AlteWagen Troll
Posted: Wed Dec 24, 2025 12:12 pm Post subject: Re: Another super stockish build |
Werent most of the real 'hemi' heads used with domed pistons? I thought that is why they needed 40+ timing when used on a VW because of the flat top piston. With the dome and the hemi shape chamber deck height was not such a big issue since the flame only had so much area to travel.
If a domed piston was available for A/C VW you could realize the benefits of a 'SH' chamber. The issue now is the low compression the SH chamber gives for NA builds with the different timing curve most dont use so the engine runs hot. with the inefficient combustion comes, lower mpg, more heat, less engine life especially when people throw more fuel at the issue. If the stock bathtub chamber design required 40* timing from the factory why would an even bigger chamber shape require any less? _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
Posted: Wed Dec 24, 2025 2:16 pm Post subject: Re: Another super stockish build |
Correct. Real Hemi heads also have canted valves, which makes the airflow substantially better as the valve lifts higher. The ONLY benefit running a hemi chamber in a VW is to make a huge chamber volume. If you have a need for a giant chamber, or you like catchy phrases or titles, a VW Semi-Hemi might just be perfect for you!!. Again.....not hating on them, just explaining the differences.
-Modok
Wreck Samba Member
Posted: Wed Dec 24, 2025 3:25 pm Post subject: Re: Another super stockish build |
Just thinking of Nascar , most likely the most developed parallel 2 valve engines on the planet . If they thought a SH chamber and domed piston was good it would have made it there .
Instead you have the opposite , dished pistons ,shaped to the chamber. A small chamber shaped to continue the port profile .With as big a quench area as possible.
I have a set of dyno run pistons bought off ebay from a Nascar team . They run a very very tight squish , you can see on the pistons where they have just been touching the head .
Steve Morris has a YT clip on squish . With boosted engines they soften the squish pads by milling them at an angle . about 7 degrees from memory .
If you look at simple physics , you wants as much thrust from the combustion event parallel to the rod , not at 30 or 40 degrees to the rods .for example at 45 degrees you loose 50 percent of down thrust to side thrust .
Merry Christmas from Australia ! |
Posted: Wed Dec 24, 2025 8:06 pm Post subject: Re: Another super stockish build |
This thread went from discussing an engine that will struggle to rev to 4250rpm, to discussing a historically bad chamber design, all tied together by BFB once again yelling profanities at someone.
-Modok
BS&E Samba Member
Joined: February 27, 2013 Posts: 1 Location: Denmarkl
Posted: Thu Dec 25, 2025 2:13 am Post subject: Re: Another super stockish build |
I went 1914 with PICT 34 in my Thing
It drives like a modern turbo diesel . Pulls like a tractor and run out of steam at 3900rpm .
And I love it because it is a cruiser and simple to maintain
It can idle al day long , cruise with a trailer at 90-100kmh and topspeed around 150kmh
Never get higher in oiltemp than 110 celcius
Looks bone stock with original oilbath filter , and og heater boxes , but with a simple 1 3/8 4-1 header . Rest of tthe exhaust system is made out of 2 HideAway silencer that comes out through the bumper as original
It is VERY "snappy" engine(has cracked one flywheel at the center) , and at meetings , everybody look in my enginebay , and looks very confuesed
The numbers are 86hp/3800rpm and 170nm /1800rpm
@Alstrup
Rob Combs Samba Member
Joined: December 30, 2020 Posts: 957 Location: South Bay LA, California
Posted: Thu Dec 25, 2025 9:20 am Post subject: Re: Another super stockish build |
Now that we’ve steered back towards the original post/topic, can you share more about the cam & heads on the 1914?
Might shed some light on where a similar configuration would max out on a ~ 25% larger displacement. Brian’s initial 4k estimate looks like it might turn out to be on the high side all other things being equal.
Torben once indicated to me that, whether out here in the open or perhaps via PM when I was still penciling in my own setup, that the sweet spot on stock-looking performance engines comes in at 1955cc. Edit: using some of the tricks he’s got up his sleeve.
After doing a lot of homework since then, and making a couple mistakes of my own, it’s starting to make more sense, at least to me it is.
Merry Christmas everyone! |
BFB Samba Member
Posted: Thu Dec 25, 2025 11:11 am Post subject: Re: Another super stockish build |
| Brian_e wrote: |
Brian |
awwww there you experts go again trying to point the finger at me for whatever reason you can so that it diverts blame off of you people for hating on someone's build... you people sidetracked shit, not me. im just the one that pointed it out. also, you have no room to whine about profanities considering the amount of them you've thrown at me in PM's and they were worse than anything ive ever posted. dont throw stones in a glass house Brian. you just do it behind closed doors so as not to mar your highly esteemed reputation , I do what I do in the open, and i hold back out of respect for the mods & owner of this place.
far as the semi heads go, its funny how narrow most of the field of vision is here. it only take a quick google search to answer a lot of the questions and "common knowledge" thats here.
there have been a vast number of engines that used hemisherical chambers, Lamborghini used it in their v12 for 50 years according to wiki. obviously Porsche & Chrysler are well known to have used them too. and yeh, from the limited research ive done on production engines designed with hemi chambers , seems most have domed pistons but the biggest reason for the domed chamber is the valve angle.
also, as far as why you dont see them in NASCAR ... its because NASCAR banned them, a couple times.
itd stand to reason that one of the reasons you dont see it now like we used to isn't because its a bad design but because its harder to 4 - 5 valves in a hemispherical chamber.
so for someone to just get online and spout out that a hemispherical chamber is a poor design and has to have 40 degrees of timing to even run just shows that, well,... they're an expert.
now I will agree partly that Brian is somewhat correct in that the vw engine isn't the same and isn't set up as a true hemisherical head, the piston isn't domed, the valves aren't angled ( which is why ive asked and wondered about running a Porsche head on a T1 ), and yes I have no idea why st. berg wanted to do this and run such low compression and why ppl bought into either, probably the same reason why they buy into what you experts on here tell them would be my guess though.
as far as needing to dome the chamber for boost, you dont need to that, there's many other ways to get the CR down. and there's guys that run boost on a higher CR than a lot of you run just N/A.
but most vw semi - hemi heads aren't cut anything like that. I dont agree with berg's low CR theory but with the semi - hemi cut & tool he did make a great way for anyone to lower the CR of their engine when running larger pistons. you can easily repeat a chamber design and volume from one cylinder to the next. its a phenomenal idea and absolutely nothing wrong it. nowadays people just order new heads with the chambers cc'ed to their specs and trust that the ppl selling the head have the best chamber design. Berg's was a simpler solution for before this was an everyday option, and it's still a viable option. its not like 'ol boy has 80cc chambers in his heads like some of you act like it is. hell, my domed chambers are only 52 or 54 cc's ( started off with 45 or 47 ) can't remember exact #'s as its been like 9 years or so ago..
so you experts really need to get off your high horses, and stop trashing someone's project like its going to turn out like shit because they run a semi - hemi head or more than 040 deck, or just dont do it how you think it needs to be done. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
sled Samba Member
Posted: Thu Dec 25, 2025 11:26 am Post subject: Re: Another super stockish build |
| matthewl wrote: |
| So I have a set of dual port heads I'm going to use. |
why do you think using those heads is a good idea? _________________ drive your split. |
Posted: Thu Dec 25, 2025 1:34 pm Post subject: Re: Another super stockish build |
| Rob Combs wrote: |
-Might shed some light on where a similar configuration would max out on a 25% larger displacement. Brian’s initial 4k estimate looks like it might turn out to be on the high side all other things being equal.
Cam choice, CR and final set up always plays a role. If you are ready to exploit 98-100 octane Euro fuel all the numbers easily "jumps" with 5%
BFB. I do not want to get in to a pissing contest with you again over heresay. Just sayin´ that you might want to read up on what happens in a bath tub/wedge chamber versus a Hemi/Semi Hemi. Let me give you a couple of hints:
A hemi/Semi Hemi sacrifices tubulence for knock resistance.
Look into flame/burn propagandation (and thereby IMEP) in relation to CA (Crank angle)
The MAIN reason for using hemi heads in just about ANY engine is due to the possiblity to install larger valves. Larger valves can - naturally - flow more, plus the fact that they get unshrouded faster, BUT, at a cost. That is what you need to read up on.
Also, take a look in to the modern Hemi heads in f.i. the Dodge Cat series. 1. They are dual plugged. 2. Heey, they have 4 degrree quench areas....
Happy reading. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Thu Dec 25, 2025 9:38 pm Post subject: Re: Another super stockish build |
| BFB wrote: |
| Brian_e wrote: |
Brian |
awwww…….. |
I haven’t done any hating in here. All I did was point out 3 things that are true.
Just to clarify, when I mentioned the chambers, I was referring to hemi cut chambers used in air cooled VW engines, since this is an air cooled vw engine specific forum. I should have been more clear I guess. _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
BFB Samba Member
Posted: Fri Dec 26, 2025 1:37 pm Post subject: Re: Another super stockish build |
Alstrup, I bet you have an idea where id tell you to put your hints. and I say that because your not actually discussing anything, just trying to set up questions so the answers set you up to be right and you throw out shit to try to make yourself look smart , when your really not, at least not as much as you think.
I think its unfortunate that people that dont know better follow your "advise" like its gospel... hey, I think I'll call you st. Alstrup from now on! not that your in the same category as st. Berg, he actually accomplished a lot.
and if you dont want to have a "pissing match" then dont address me personally, definitely dont talk to me in a condescending manner because we all know I won't just let that go. but instead, just make your point and move on. and if someone contradicts you, its ok, it doesn't demote your sainthood, so you dont have to defend yourself nor try to prove the other person wrong.
but the real important part here, the main thing your overlooking or ignoring/ diverting attention from is the fact that YOU are the guy hating on ol boys heads that he predicted someone would do. you started all this shit. at least Brian said he wasn't trying to hate on it, just wanted to make a point. completely understandable. you st. Alstrup were on the other hand being a snarky ass and still following the same pattern... _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
