just how offset are OE rods?
BFB
BFB is offline
PostPosted: Mon Dec 15, 2025 6:24 pm    Post subject: just how offset are OE rods? Reply with quote
anyone ever measure or read about how much factory connecting rods are offset?
Most experts aren't.
BFB
BFB is offline
PostPosted: Thu Jan 01, 2026 10:15 am    Post subject: Re: just how offset are OE rods? Reply with quote
I guess its one of those things that Berg didn't notate so none of the experts know...
Dougy Dee
Dougy Dee is offline
PostPosted: Thu Jan 01, 2026 1:33 pm    Post subject: Re: just how offset are OE rods? Reply with quote
You, too, could measure a stock rod...
I get 1mm...
redhot
redhot is offline
PostPosted: Thu Jan 01, 2026 1:54 pm    Post subject: Re: just how offset are OE rods? Reply with quote
According to a 1968 print.
Since February 1963.
34hp engines 1.0mm
Other engines 1.5mm
The print refers to rods otherwise of the types 25/30hp, 34hp, 1300ccm up to Jan.1966 and 1500cc up to Aug.1965 plus 1300, 1500 and 1600 otherwise.
So would assume all those are included in the statement (34hp and up).
If they later changed also the 34hp...?
BFB
BFB is offline
PostPosted: Thu Jan 01, 2026 3:05 pm    Post subject: Re: just how offset are OE rods? Reply with quote
I get 1mm...
I'd be happy to, but I'll admit that I just cant picture how to do it.
wanna tell me how you did it?
raygreenwood
raygreenwood is offline
PostPosted: Thu Jan 01, 2026 3:45 pm    Post subject: Re: just how offset are OE rods? Reply with quote
BFB wrote:
I get 1mm...
A little while back I had to think about how to measure the same thing on the little end of type 4 rods. You can look at it and see that one side sticks out more from an imaginary centerline.
Going off memory here wo it may not be 100% the eight sequence but you get the gist. What I did was take a small granite plate that I have and lay the rod on there with the shorter side of the rod down....hold it down tight so its flat and used a caliper to measure how far the granite plate the cheeks of the rod were. Call that 0 or normal. Then flip the rod over and hold the wider side of the little end tight and flat against the plate and measure between the cheek of the big end and the plate. By subtracting the two measurements you get an idea of the offset.
And.....for type 4 its not really offset like type 1. It just has one side wider on the little end. But you can use the same technique to measure with. Ray
Dougy Dee
PostPosted: Thu Jan 01, 2026 4:24 pm    Post subject: Re: just how offset are OE rods? Reply with quote
BFB wrote:
I get 1mm...
I held a rod up to my straight edge and used my eyecrometer...
For more accuracy I would have used a flat plate and dial indicator but that would have taken more time.
BFB
BFB is offline
PostPosted: Thu Jan 01, 2026 10:24 pm    Post subject: Re: just how offset are OE rods? Reply with quote
Im getting the feeling ya’ll are talking about the small end being offset side to side , not offset parallel to the big end’s center line ?
Im wondering if , say the stock wrist pin is off centered, is it just in the piston or the piston & rod both?
IE if you flip the stock rod so tang is down with using non-offset pistons, would it change the geometry of the crank & wristpin ? Or is the rod’s big & small ends parallel?
Theres always been talk of the rods needing to go tang up because their offset, but i got a feeling their not. And even if they were i dont see how itd matter aside from making a goofy off centered rod. Thats why im asking if anyone actually knows.
redhot
redhot is offline
PostPosted: Fri Jan 02, 2026 9:51 am    Post subject: Re: just how offset are OE rods? Reply with quote
My understanding is that there are two offsets with two differing objectives;
- connecting rod offset (in connecting rod itself): center the pistion in the bore engine lengthwise front to back. This I assume stem from how the engine block, crankshaft and piston bores all stack up packing wise including re-use existing forming tools, parts, optimizing tolerancese etc.. So one can move them over btw. sides without flipping them.
According to a search here, but not available on website anymore?
On the Gene Berg website he refers to:
Bug-pack Rods…Further, they did not have the proper 2mm offset the stock VW rods all have that is required to position the rod on the crank so it properly lines up to case and cylinder bore. "O" offset causes unwanted side loading on the rod bearing and piston, which make wrist pin keepers burr up or come out as well as blow-by.
- piston pin offset (in piston itself): offsetting the piston pin in the bore vertically so to optimize side force on work strok vs. compression stroke. Hence to move them over one needs to flip them to maintain this relationship on the flat-4.
Great article: https://www.engineprofessional.com/articles/EPQ416_50-54.pdf
modok
modok is offline
PostPosted: Fri Jan 02, 2026 9:30 pm    Post subject: Re: just how offset are OE rods? Reply with quote
How offset are the rods?
One would hope the right amount for the crank
So how offset is the crank?
The CASE did not change from 40 horse to 1300/1600
it was the crank and rods that changed offset, to have a thicker cheek between rod throws.
It just takes some time with dial calipers and a flat surface to figure it out with what parts actually exist. Aftermarket stroker cranks sometimes have LESS.
I figured out half of it before but I don't recall what that number was exactly for all brands of this or that.
GOood question. Good luck
BFB
BFB is offline
PostPosted: Sat Jan 03, 2026 10:44 am    Post subject: Re: just how offset are OE rods? Reply with quote
wristpin offset in the piston should be easy enough to measure. but rod offset ( not side to side ) seems a different story to me, unless im overthinking it. the only way I could see to measure if theres any rod offset would be to mock a rod up on a crank with a piston that is known to not have any offset then see if when these parts are lined up 180 if the piston is at true TDC. or set the piston to TDC and see if the crank is off by any number of degrees.
I bet theres a tool for this somewhere....
redhot
redhot is offline
PostPosted: Sat Jan 03, 2026 12:15 pm    Post subject: Re: just how offset are OE rods? Reply with quote
Exactly what offset are you chasing?
redhot
redhot is offline
PostPosted: Wed Jan 07, 2026 11:02 am    Post subject: Re: just how offset are OE rods? Reply with quote
Would be interesting to see a follow up.
My uinderstanding is that rod is offset I guess what you call "side to side" (engine lenght axis) while pistion boss is offset "top vs. bottom" (engine vertical axis).
What would be interesting - but have been discussed before - is what the use of non offset rods then has towards either/both performance or service life. While worthwile back in major serial production, maybe not for most of recreational use. But maybe important for high performance.
Or said differently - when should one maybe use original rods for "normal use" due to a tolerance stack up in the case, crankshaft and piston bores?
BFB
BFB is offline
PostPosted: Wed Jan 07, 2026 8:27 pm    Post subject: Re: just how offset are OE rods? Reply with quote
I dont think the rods are offset at all , i think it’s just in the wristpin. If you think about it, offsetting the small end to the big end would only make a weaker rod.
The small end does seem to have a little more meat on one side ( fore & aft ) but i dont see that making any difference and dont see why itd be done other than maybe production process. Theres so much room for the rod inside the piston that it’s not like a little more / less meat on one side or the other provides some clearance or something.
RWK
RWK is offline
PostPosted: Thu Jan 08, 2026 7:45 am    Post subject: Re: just how offset are OE rods? Reply with quote
Ther is a pic of the offset in the 61-65 Bently workshop manual.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
Dusty1
Dusty1 is offline
PostPosted: Thu Jan 08, 2026 8:00 am    Post subject: Re: just how offset are OE rods? Reply with quote
Rod offset prevents piston slap. Seems to me my beloved EJ22s have less or no offset. An aged Subi slaps like hand jive.
Doesn't matter if the stock rods are a tiny bit weaker than they could be. They're designed for a 50hp engine. They will handle about 200hp.
Many if not most "connecting rod problems" aren't due to design flaw or weakness. They're due to oiling problems, assembly clearance problems and you bet if you drop a valve and mushroom a piston you'll end up with a matched set of three rods. Rolling Eyes
"May you live an interesting life."
BFB
BFB is offline
PostPosted: Thu Jan 08, 2026 11:28 am    Post subject: Re: just how offset are OE rods? Reply with quote
I think yall are making the assumption that because a wristpin is offset that the rod is too. the term rod offset is just used synonymous with wrist pin offset and again, ppl assume that the rods are offset because of a tab. and somewhere along the line its become common knowledge that they are offset but not a single person so far actually knows for sure.
all ppl know it that the casting tab goes up on OE rods which means bearing tangs go down, so then by that, all other rods missing casting tabs still need bearing tangs to face down as well too. why? apparently just because thats how its been done so we do it that way and were gunna keep on doing it that way because its been done that way, and if we do it that way there must be a reason and that reason must be because the rod is offset otherwise it wouldn't matter, but it does matter because thats the way we do it. so therefore thats why OE rods are offset. maybe not aftermarket rods but they still need to go the same direction as OE regardless...
redhot
redhot is offline
PostPosted: Fri Jan 09, 2026 11:30 am    Post subject: Re: just how offset are OE rods? Reply with quote
It is in a VW publication, that the rod itself has a side-to-side offsett... With a drawing - of the rod.
BFB
BFB is offline
PostPosted: Sat Jan 17, 2026 7:18 pm    Post subject: Re: just how offset are OE rods? Reply with quote
ok, so rod offset is just common knowledge bullshit.
yes the small ends do seem to be thicker on one side than the other as far as front to back of the engine, but as I said before thats not what im talking about nor would that even affect anything because of the floating wrist pin.
what im talking about is small end offset to the crank, what ppl seem to confuse or correlate with the wrist pin being off centered in the piston. and that because OE pistons have a tang , that the tang must serve as the same purpose as the arrow on the piston, giving direction as to how its supposed to be mounted.
SO, I drew up and printed a mock crank that spins in a base with a wrist pin that slides up & down to mimic a vw, and yes it is spec correct so I can put a vw rod on it. I havent yet as I forgot to bring one home but in all reality, it's a moot point anyhow.
I also drew up & printed several connecting rods, all 137 mm from center to center, but with 0, 1, 2, and 10 mm offsets.
my conclusion, there is no such thing as ROD offset because its either 137mm center to center or its not. ie, if you offset the end of the rod but its still 137mm then you just made a dog legged rod is all you did. if it varies from 137mm then all you did was make a longer or shorter rod, and we know what that does.
as you'll see in the pics below, the altered offset doesn't change any positioning and matter of fact you can even use the 0 offset and the 10mm offset together , as in on the same journal, and theres no binding. fyi, theres .5mm gap between main 'journal' and the big end of the rod, not enough play that it'd allow for binding otherwise.
so you can mount your rods tang up, tang down, makes no difference other than your OCD and doing things the way they've been done because thats how we do it.
enjoy the pics....
EVfun Premium Member
EVfun is offline
PostPosted: Yesterday 12:17 am    Post subject: Re: just how offset are OE rods? Reply with quote
The rod offset that comes to mind for me is how the center of the rod journal is not the center of the cylinder bore. I think VW added a little extra metal between rod journals 1 and 2, and also between 3 and 4. This shifted the center of the rod journal off of the center of the cylinder bore. I'm not positive about this on the VW engine, but I have seen it on other engines.
Wildthings wrote:
