my dyno run
1641 bug
1641 bug is offline
PostPosted: Sat Oct 08, 2005 9:53 pm    Post subject: my dyno run Reply with quote
well i put my 1970 1641 dual port ,weber 44 gas drinking rocket up onthe horsepower pump and it threw down 64.19 hp and 81.04 flbs of torque at 12.1air fuel ratio a littel rich i know and i was wondering if that good power for what i have?
ice baller61
ice baller61 is offline
PostPosted: Sat Oct 08, 2005 11:51 pm    Post subject: Reply with quote
Yea that is awsome HP. There is a guy in here with a 2L who gets about the same HP as you Shocked NO offense to any one Shhh
bumping sounds and boosting pounds
SeVVenth
SeVVenth is offline
PostPosted: Sun Oct 09, 2005 12:30 am    Post subject: Reply with quote
And superbtl has 600 and some more cc too... He's havin some bad luck.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Oct 09, 2005 2:53 am    Post subject: Reply with quote
It's all in the "combo".
You can't just throw a bunch of parts into a box, shake and expect to get a highly tuned engine.
Carefully matching parts, meticulous assembly and alot of time final tuning will give you the most horsepower. That's why my 1904cc outruns many larger engines.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
mharney
mharney is offline
PostPosted: Sun Oct 09, 2005 7:22 am    Post subject: Reply with quote
Why?? That's what I did. It worked. Now I have this shabby pieced together 2332.
Ok, ok, so it's cookbook. So what.
superbtl
superbtl is offline
PostPosted: Sun Oct 09, 2005 7:39 am    Post subject: Reply with quote
when reading air fuel ratio, what is rich and what is lean.my car had a reading of 14.2 on my better run of 86 hp then i loost a cylinder( dyno guy accidentally unplugged #1 spark plug) and i had an a/f reading of 12.5 and had a hp reading of 58.7 on 3 cylinders.
so when i had the 86 hp run on 4 cylinders with an a/f reading of 14.2 i was way too rich ...correct?
clearsurf2001
Samba Vaccinator
clearsurf2001 is offline
PostPosted: Sun Oct 09, 2005 7:47 am    Post subject: Reply with quote
Incorrect ... it's an air/fuel ratio. 14.2 is leaner than 12.5.
On another note ...
Sorry ... have to hold up the BULLS%#T card here Very Happy
Get ready for the injection Smile
Make sure it is coherent. Rodney
mharney wrote:
I think Glenn has an EMPI crank in his engine.
superbtl
superbtl is offline
PostPosted: Sun Oct 09, 2005 7:51 am    Post subject: Reply with quote
would that mean i need more fuel top end
ice baller61
PostPosted: Sun Oct 09, 2005 7:57 am    Post subject: Reply with quote
I think every one is tryin to tell you , you need better heads or a different combo
clearsurf2001
Samba Vaccinator
You're rehashing your problem (covered in your other thread) ... re-read what Mark, Darren, Glenn, John, Jake, etc. had to say about carb setup, cam duration, compression, etc. IIRC you have some people (local) that want to help you ... don't jump to any conclusions about your a/f ratio until the basics are solid.
clearsurf2001
Samba Vaccinator
PostPosted: Sun Oct 09, 2005 8:00 am    Post subject: Re: my dyno run Reply with quote
BTW ... very good dyno run. Fine tune that bad boy and find a few more hidden ponies. A wideband 02 sensor and an Innovate a/f meter can work wonders.
mharney
mharney is offline
PostPosted: Sun Oct 09, 2005 8:11 am    Post subject: Reply with quote
What you need is more fuel at LOAD conditions. 14.7 is the ideal ratio for economy I believe, but VWs don't like it. They like 13.5 to 14.0 for cruise and about 12.5 for power.
For a pretty decent read on combustion chemistry, read this:
http://www.autoshop101.com/forms/h55.pdf
Ideally, you can jet so that you can have about 13.5 to 14.0 AFR during cruise, at most reasonable speeds and RPM ranges, and about 12.5-12.8 AFR under heavy load and WOT, but getting there is pretty hard. You have to decide:
1. How much energy you want to put into perfection
2. What's more important to you as a target - power or economy
3. How much money you want to sink into getting it perfect or close
Carbs aren't perfect, and with weather and altitude changes, the numbers will skew a little.. Fact of life. You can get close though, and 25MPG is a reality you can achieve if you put enough into it. Of course, if you drive with a heavy foot, forget it.
But none of this means a lot until everything else is pretty well matched up. A bastard combo may do better at other numbers.
nsracing
nsracing is offline
PostPosted: Sun Oct 09, 2005 5:10 pm    Post subject: man 'o man... Reply with quote
SB...
You have got one of the bigger engines around. Those are NOT tiny parts you have in the motor. For some reason the motor is NOT producing anywhere near what is it supposed to be.
You need to re-do that motor. Back up and go into that thing and see what is up in there.
No amount of tuning will make that motor run if the "mechanics" of it is NOT close to perfect. You probably have a deck height of 1/2" for all you know. CR of 6:1? Chambers too big for the application.
Take it apart and just re-do it man.
Ciao.
