Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 553 Location: Denmark
Posted: Sun Nov 06, 2005 8:48 am Post subject: 356 oil cooler |
Does anybody know if a 356 oil cooler will fit on a 36hp engine?
I have been told they are made in aluminium and there for much beter
to cool the oil, is there any thruth in that?
Any info would be nice! _________________ http://vw-bluehats.blogspot.com/ |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Sun Nov 06, 2005 10:14 am Post subject: related link |
Hello-
I don't know if this is where you found out about 356 oil coolers, but here's a related link:
http://www.pca.org/tech/tech_qa_question.asp?id={25E92F7D-C594-4AA8-BCD9-B1BBD70E0A91}
Thanks for your time.
Paul |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14197 Location: Southampton U.K.
Posted: Sun Nov 06, 2005 12:03 pm Post subject: |
Okay thanks
Now I only need too know if it will fit on my 36hp egine? _________________ http://vw-bluehats.blogspot.com/ |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3840 Location: Eastern WA
Posted: Sun Nov 06, 2005 2:36 pm Post subject: 356 oil cooler |
I will go out and check in a minute , I have both styles of 356/912 coolers and a bare 36hp block . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Teeroy  Samba Member
Posted: Sun Nov 06, 2005 3:31 pm Post subject: 356 oil cooler |
The alum cooler has 8mm studs , the 356 and 36hp have 6mm studs , but all the holes line up . There is enough material to drill the case for the bigger studs . Both the Porsche coolers have a larger opening , not sure if the standard cooler gasket would work (I didn't have any to check) the holes are about 1.5 - 2mm bigger . Here are some pics . TROY
ARR #3
swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Posted: Sun Nov 06, 2005 7:44 pm Post subject: |
There is an aluminium coolor for early 356 that has the 6mm studs. They show up occaisionally on Ebay. They fit the case, how they fit in the cooling tin is something that I have not tried, but I think they will fit fine. |
Posted: Mon Nov 07, 2005 3:24 am Post subject: Re: 356 oil cooler |
Teeroy wrote: |
Okay thanks alot!
What is the diffrents between the one in the middle and the left one?
I would say that the left one is best because of all those little finns/ribs
(I dont know what it is called in english sorry ) _________________ http://vw-bluehats.blogspot.com/ |
Teeroy  Samba Member
Posted: Mon Nov 07, 2005 9:54 am Post subject: 356 oil cooler |
The one in the middle is steel , like the VW cooler . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
OMT Samba Member
Posted: Thu Nov 10, 2005 4:30 am Post subject: |
Hello all.
The 356 alloy oil cooler will hit the top directional vane inside the fan shroud. I think Porsche designed the 3 piece case to work with the "tall" oil cooler and the VW shrouds(modified) it robbed from the OEM.
It will leave about a 1/8" gap over the cooler side of the shroud.
Troy please double check me on this. It's hard to tell, the case ribbing makes it look like it fits, but the shroud doesn't seat on the "roof" of the case. The shroud will rock back and forth.
You can do what want you want; I'm not saying it will not work. Compare the pic's and you will notice how the tops of the coolers differ.
I had to use a "Behr" cooler on my 1958 VW 36hp case with early (1956)
Porsche fan shroud.
Good luck with your project.
Al |
Teeroy  Samba Member
Posted: Thu Nov 10, 2005 12:26 pm Post subject: 356 oil cooler |
Al , went out to the shop , the alum cooler fit as far in the shroud I have as the steel cooler and a later 36hp, the dome top with brace bracket did not though . I don't have a case drilled for the larger mounting studs , to see if things change when cooler is bolted to block . TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Teeroy  Samba Member
Posted: Thu Nov 10, 2005 11:11 pm Post subject: |
Okay is it any taller than the original 36hp one?
Is it 36 hp fan shroud that tried to put the coolers in? _________________ http://vw-bluehats.blogspot.com/ |
Teeroy  Samba Member
Posted: Fri Nov 11, 2005 11:35 am Post subject: 356 oil cooler |
It's shorter than the 36hp dometop with the brace bracket , yes testing with a 36hp VW shroud. TROY _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Wed Jun 14, 2006 7:30 pm Post subject: |
Hello-
I've been looking for aluminum oil coolers on eBay when I noticed a couple of things. First, you can purchase "Stepped" oil cooler seals from Zim's Autotechnik - they're intended for people who want to mount late model oil coolers on early 356's. Second, it looks like a lot of these replacement coolers come with studs that are 6mm on one end and 8mm on the other. Lastly, I've noticed that they sell brass vw style coolers for $60 new. Does anyone know if these disipate much more heat than the standard steel cooler?
Thanks.
P- _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
AlteWagen Troll
Posted: Thu Feb 18, 2010 8:12 am Post subject: |
Hello-
I would advise against purchasing the late model 356 cooler. They are very heavy so they're more likely to damage to your case.
If you want a 356 cooler, install one of the early ones, or save up your pennies and purchase one of the very efficient/light ones from NLA Parts.
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
AlteWagen Troll
Posted: Thu Feb 18, 2010 11:55 am Post subject: |
Can see why weight would make much of a difference as the bulk of the weight would be centered on the HUGE case boss.
The reason I ask is most people want to put doghouse coolers on a 40hp but if the aluminum 356 cooler would fit inside a stock non DH shroud I think its a no brainer. Better cooling than stock with completely stock appearance.
Also if it works on a 40hp case it would work on later 1500 or 1600 SP as well.
So, back to the question, has anyone actually used the aluminum 356 cooler on a 40hp engine with success?? No theories or opinions unless you have used one. _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
perello Samba Member
Joined: April 15, 2005 Posts: 888 Location: where social security comes for free
Posted: Fri Jan 07, 2011 6:12 am Post subject: |
for the sake of contributing with more material I post the choices I have on my desk
IMHO, the left one aluminum behr oil cooler is getting hard to find on good conditions. Instead the center 356B/C oil coller can be found at an affordable price if you look thoroughly.
If I finally use the 356 one, I doubt between keeping the 8 mm studs an machine the holes on the case or substitute those studs.... _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
