RIS Samba Member
Joined: December 18, 2003 Posts: 3044 Location: Youngstown, Ohio
Air Sucker Samba Member
Joined: October 03, 2005 Posts: 29 Location: Pittsburgh, PA
Posted: Sat Feb 04, 2006 10:51 am Post subject: |
Is that a hose attachment point on the back of the shroud where the oil cooler sits behind? _________________ 1971 Super Beetle
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79790 Location: Sneaking up behind you
Posted: Sat Feb 04, 2006 10:53 am Post subject: |
Not speaking for Jake, but I don't think that was included in his tests.
And that is a round hose fitting for the outlet of the oil cooler air. It's perfect for a kit car. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sat Feb 04, 2006 11:03 am Post subject: |
Can you use OEM cooling flaps with this? _________________ 1971 Super Beetle
Glenn  Mr. 010
Posted: Sat Feb 04, 2006 11:05 am Post subject: |
Air Sucker wrote: |
Can you use OEM cooling flaps with this? |
I don't see any holes for mounting the flaps, but that can be solved. The rear dog house looks deeper than stock, so the linkage might need to be tweaked. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Feb 04, 2006 11:15 am Post subject: |
Glenn wrote: |
Air Sucker wrote: |
I don't see any holes for mounting the flaps, but that can be solved. The rear dog house looks deeper than stock, so the linkage might need to be tweaked. |
So you just need to drill a few holes then? This seems like an interesting option to the 181 shroud. _________________ 1971 Super Beetle
Glenn  Mr. 010
Posted: Sat Feb 04, 2006 12:21 pm Post subject: |
Air Sucker wrote: |
Glenn wrote: |
Air Sucker wrote: |
So you just need to drill a few holes then? This seems like an interesting option to the 181 shroud. |
Probibly... like I said... you should be able to get some flaps in there. _________________ Glenn
Member #1009
#BlueSquare
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Sat Feb 04, 2006 1:19 pm Post subject: |
Air Sucker wrote: |
The one pictured above from CB doesn't look like it has the holes for the screws to the flaps.
The "Low-Profile" (Puma) Doghouse Fanshroud w/ fresh air outlets that I have on my Ghia has provisions for the OEMs as well as the two other Puma shrouds I have up in the rafters. I am running thermostat and flaps on my engine.
I bought mine as a kit from SCS (Small Car Specialties - Anaheim, CA) back in 1985 and at that time CB Performance (Claude Buggies back then) too also sold them.
You can see on left of the fresh air hose is the screw for the flaps as well as under you can see a partial cutout of the cylinder tin where the flaps swivel.
_________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
Glenn  Mr. 010
Posted: Sat Feb 04, 2006 1:22 pm Post subject: |
Jim... what took you so long?  _________________ Glenn
Member #1009
#BlueSquare
Air Sucker wrote: |
Is that a hose attachment point on the back of the shroud where the oil cooler sits behind? |
Yes, that is an hose attachment. I used one of those paper cardboard type fresh air hose connect to that oil cooler outlet and route mine to exit under the engine. _________________ Jim Kikuchi
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Sat Feb 04, 2006 2:24 pm Post subject: |
I did not test the shroud in question... At that time I could not find one. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
steel buggin Samba Member
Joined: March 24, 2003 Posts: 415 Location: Arcadia,Ca
Posted: Sat Feb 04, 2006 8:14 pm Post subject: |
I have tested it and it is the best factory fan shroud you can get other then the DTM I had one on my buddy street car which made 185HP and 173TQ at the real wheel's never had a over heating issue. The best part about the shroud is the 2" exhaust tube for the oil cooler plus the unit is one piece not two like the other oem shround's.
https://www.thesamba.com/vw/classifieds/pix/medium/546322.jpg |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1797 Location: Boise, Idaho
Posted: Sun Feb 05, 2006 10:33 am Post subject: |
How did you fix the front tin where the hose from the cooler exits? Did you wels or pop rivit a piece of metal to seal around the hose? (stock rectangle exit, Puma round..)
Steve |
Posted: Sun Feb 05, 2006 11:30 am Post subject: |
Steve Arndt wrote: |
Steve |
Steve, the front tin where the oil cooler exits also has the round hole in which as rubber hose is in conjunction between the two.
I can take a picture of one of the other Puma shroud and front tin that I have and post it here. _________________ Jim Kikuchi
Posted: Sun Feb 05, 2006 5:47 pm Post subject: |
Routing the oil cooler outlet hose into the heater channel would be slick for easy winter heat. |
Posted: Sun Feb 05, 2006 7:23 pm Post subject: |
Here are the pics of the Puma "Low-Profile" doghouse fanshrouds I retrieved from the rafters...
My set of Puma doghouse fanshrouds with the front tin
Bottom and rear view of the Puma shrouds
Bottom view with flaps and Brazilian oil cooler mount
Brazilian doghouse oil cooler mount
Internal directional airflow vanes
Front tin with round oil cooler outlet
Glenn  Mr. 010
Posted: Sun Feb 05, 2006 7:25 pm Post subject: |
Nice Jim... that's a sweet setup. _________________ Glenn
Member #1009
#BlueSquare
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Sun Feb 05, 2006 7:47 pm Post subject: |
very nice jimmy...when are you going to sell me one of them things?!  |
Glenn  Mr. 010
Posted: Sun Feb 05, 2006 8:00 pm Post subject: |
thanks glenn, i know and im tempted, but i want heat when the 2110 is done. afterall it is my daily. |
