front beam bushings
bullifecal
bullifecal is offline
PostPosted: Wed May 17, 2006 4:24 pm    Post subject: front beam bushings Reply with quote
Anybody know where i can get new bushings for the front beam of a 1960 bus?
diy570
diy570 is offline
PostPosted: Wed May 17, 2006 4:53 pm    Post subject: Reply with quote
wagens west had them for sale. 15 each or something
campingbox Premium Member
campingbox is offline
PostPosted: Wed May 17, 2006 5:32 pm    Post subject: Re: front beam bushings Reply with quote
Which bushings are you referring to? Link pin bushings or torsion arm bushings?
gatorwyatt
gatorwyatt is offline
PostPosted: Wed May 17, 2006 7:24 pm    Post subject: Reply with quote
if you are reffering to the beam bushings the torsion arms ride on, i bought mine from isp west.they were not going in unless you press them in and they also needed to be fitted via hone. not hard or rocket science just lots of patience to get them to fit.
good luck.
www.blastserv.com
wanted:
Nothing!
bullifecal
PostPosted: Wed May 17, 2006 7:52 pm    Post subject: bush Reply with quote
I'm referring to the big bushings inside the beam. Thanks for the help
PostPosted: Wed May 17, 2006 10:45 pm    Post subject: Reply with quote
I used a drift and a big hammer to drive in the bushings. This was the hardest part of the job.
gatorwyatt
PostPosted: Thu May 18, 2006 4:01 am    Post subject: Reply with quote
remember they are made out of bakeolite or something ,very brittle.dont fuck em up
www.blastserv.com
wanted:
Nothing!
PostPosted: Thu May 18, 2006 8:13 am    Post subject: Reply with quote
The workshop manual calls for this drift along with a big hammer. I'll use a press when I do the set for the yellow '56 Westy but when I did the '56 I didn't pull the beam.
busracer
busracer is offline
PostPosted: Thu May 18, 2006 8:26 am    Post subject: Reply with quote
ive got that drift but no reamer. me wanty reamer.
PostPosted: Thu May 18, 2006 8:37 am    Post subject: Reply with quote
They turn up on eBay every few months or so and usually fetch between $100-$300 depending on who's looking at them.
Saggs
Saggs is offline
PostPosted: Thu May 18, 2006 12:39 pm    Post subject: Reply with quote
I've got the same type of bushings in my 56 oval. How did you get the old ones out? I was thinking to cut throuhh them w/ a sawzall and remove them in 2-3 pieces. I tried a slide hammer w/ no luck Crying or Very sad
"One man can make a difference...Jesus did."
PostPosted: Thu May 18, 2006 12:42 pm    Post subject: Reply with quote
Saggs wrote:
I've got the same type of bushings in my 56 oval. How did you get the old ones out? I was thinking to cut throuhh them w/ a sawzall and remove them in 2-3 pieces. I tried a slide hammer w/ no luck :cry:
The bushings are slightly smaller in size in an oval. The "Tools of local manufacture" book has instructions on how to make a tool to remove these. It's basicly a drift similar to the drum race drifts but mounted on the end of a 4' pole. Don't forget to pull out your grease fittings. The workshop manual also shows a "puller" for the bushings but that would be a bit more challenging to make.
As the old saying goes, "if they ain't broke don't fix it". Measure you're bushings and if they're within spec., leave them there.....
