Ignition timing for a Bosch 019?
Saggs
Saggs is offline
PostPosted: Fri Jul 07, 2006 11:54 am    Post subject: Ignition timing for a Bosch 019? Reply with quote
I'm putting a Bosch 019 dist. in my 1600 dp single carb motor for my 67 westy. Anyone reccommend a timing setting for this dist? I think I'm running 7degs BTDC with the stock vacuum job. Thx
"One man can make a difference...Jesus did."
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jul 07, 2006 11:57 am    Post subject: Reply with quote
Set it 28*-32* BTDC at 3000rpm.
You should never static time a mechanical distirbutor.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Saggs
Saggs is offline
PostPosted: Fri Jul 07, 2006 12:26 pm    Post subject: Reply with quote
Glen, I have a stock vw pulley w/ no major timing marks, any suggestions where 28-33 degs BTDC would be? Maybe one of the press spokes on the pulley face?
oc63rag
oc63rag is offline
PostPosted: Fri Jul 07, 2006 12:36 pm    Post subject: Reply with quote
46mm from the TDC mark is 30 degrees.
Designed for four soldiers and a machine gun...also for family use.
My food baby is crowning.
Saggs
Saggs is offline
PostPosted: Fri Jul 07, 2006 12:56 pm    Post subject: Reply with quote
oc, thx for the info-I assume that is 46mm along the top plane (edge) of the pulley?
oc63rag
oc63rag is offline
PostPosted: Fri Jul 07, 2006 1:34 pm    Post subject: Reply with quote
Correct. Once you measure the distance just mark it with a line of paint.
GeorgeL
GeorgeL is offline
PostPosted: Fri Jul 07, 2006 1:44 pm    Post subject: Reply with quote
Why? I've never had a problem with static timing mechanical, vacuum only, and SVDA distributors. I occasionally hook up the timing light to see if they are advancing properly to 30 degrees, but that is a diagnostic, not a setting method.
George
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Fri Jul 07, 2006 5:12 pm    Post subject: Reply with quote
George
Because they vary in maximum advance (especially cheap 009s), and your advance at 3000 RPM is a hell of a lot more important than at 0 RPM.
Sounds like you've had good luck with distributors.
GeorgeL
GeorgeL is offline
PostPosted: Fri Jul 07, 2006 5:49 pm    Post subject: Reply with quote
Towel Rail wrote:
George
Not so much good luck as I've checked them at both ends of their advance curve. The only one I've had that didn't advance correctly is the worn-out DVDA that came in my bus.
Mr. 010
Glenn is offline
PostPosted: Fri Jul 07, 2006 6:53 pm    Post subject: Reply with quote
Print this degree wheel and use it to put a paint mark on the pulley.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mark
Mark is offline
PostPosted: Fri Jul 07, 2006 9:33 pm    Post subject: Reply with quote
For what it's worth, with point-less pertronix, compufire, etc. systems, I find static timing to be useless. Besides, w/ the "quality control" of 009's I'd rather some comfort of knowing the total advance using a strobe. Yet another one of the Muir'isms that I strongly disagree with.
Having said that, I'm quite happy w/ my 009...so far. Smile
www.zwerks.ca
Towel Rail
PostPosted: Fri Jul 07, 2006 10:22 pm    Post subject: Reply with quote
By luck, I meant that the ones you got had the correct advance. As 009s vary all over the map, would you feel right telling someone to just time theirs statically? I sure wouldn't.
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Jul 08, 2006 5:22 am    Post subject: Reply with quote
Excellent advice.
Mr. 010
Glenn is offline
PostPosted: Sat Jul 08, 2006 5:30 am    Post subject: Reply with quote
Excellent advice.
Wink
BTW... the 28*-32* needs to be "dialed in" due to the type of fuel, combustion chamber shape and compression. You want to have the most advance with out the engine "pinging". Start with 30 and if it pings, back down to 28. If it doesn't try 32. If you use Premium gas, then 32 will most likely be fine.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
GeorgeL
GeorgeL is offline
PostPosted: Sat Jul 08, 2006 11:16 am    Post subject: Reply with quote
I generally advise people to put the 009s on the shelf and use a better distributor!
I would be very leery of any distributor that varied from a reasonable advance curve. If it doesn't advance enough and you set 30 degrees at 3000 RPM you'll end up too far BTDC at idle. That isn't good either.
saw2
saw2 is offline
PostPosted: Sat Apr 30, 2011 6:51 am    Post subject: Reply with quote
My 019 advances to about 3200 rpms. Should I set timing at maximum advance. Or as most things I see about setting at 3000 rpm
Mr. 010
Glenn is offline
PostPosted: Sat Apr 30, 2011 7:11 am    Post subject: Reply with quote
Max advance, that's why I say to do it @ 3500rpm.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
saw2
saw2 is offline
PostPosted: Sat Apr 30, 2011 7:23 am    Post subject: Reply with quote
Thanks, Glenn I was hoping for your answer.
Boom
Boom is offline
PostPosted: Thu May 19, 2011 7:01 pm    Post subject: Reply with quote
just so I am sure, you always set the timing at full advance and it doesnt matter what the timing at idle ends up being.
mine idles @900 rpms and is @ 10 degrees
Ovals are Overrated.....Click to view image
67 Chubby White Chic
Düg Büg
dLk
Mr. 010
Glenn is offline
PostPosted: Thu May 19, 2011 7:03 pm    Post subject: Reply with quote
You're fine.
019 only has 17* so at 28* total advance you'll have 11* initial.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
