soazvw Samba Member
Posted: Sun Jul 30, 2006 5:58 pm Post subject: alum vs. as41 case |
hey what do you guys think is the best case to go with? _________________ 74 custom standard bug <1915w120cam>
sold:73 stock squareback
89' jeep cherokee<rockdude> |
1200RS Samba Member
Posted: Sun Jul 30, 2006 6:06 pm Post subject: Re: alum vs. as41 case |
soazvw wrote: |
hey what do you guys think is the best case to go with? |
AS41 is far better, and more than adequate for running in the 10's |
soazvw Samba Member
Posted: Sun Jul 30, 2006 6:09 pm Post subject: |
whats the differeance? _________________ 74 custom standard bug <1915w120cam>
1200RS Samba Member
Posted: Sun Jul 30, 2006 6:13 pm Post subject: |
soazvw wrote: |
whats the differeance? |
AS41 is an alloy of magnesium, whereas aluminium blocs are made with an aluminium alloy.
AS41 are far lighter, have do not have tooling problems.
the choice of an aluminium bloc have to be considered only for 82/86mm cranks, because you have not to use spacers under the cylinders, the siting area is far thicker _________________ sorry, i'm french |
jamestwo Samba Member
Posted: Sun Jul 30, 2006 6:15 pm Post subject: |
I like the as41, but with all the aluminiums ones on the market, I finally got one. First impression, it's heavy.
So far it checks out, but I haven't started the motor yet. _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
1200RS Samba Member
Posted: Sun Jul 30, 2006 6:20 pm Post subject: |
jamestwo wrote: |
So far it checks out, but I haven't started the motor yet. |
of course
density of magnesium 1.8
density of aluminium 2.7.
50% more weight.
evry time peaple tell me about alu, I report what say Ian Clark in GB
"aluminium bloc is probably better, but I dont need it."
He ran in the mid 10's  _________________ sorry, i'm french |
Posted: Sun Jul 30, 2006 7:54 pm Post subject: |
True, been a diehard AS41 advacate, but the Aluminium is about 200 cheaper, because it comes bored for larger cylinders, full flowed and no need to sleeve lifter bores.
We will see  _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
propflux01 Samba Member
Joined: June 03, 2006 Posts: 501 Location: Central Arkansastan
Posted: Sun Jul 30, 2006 9:43 pm Post subject: |
What was/is the purpose of making an aluminum block to begin with? is there some benefit to it? |
kimosullivan Samba Member
Joined: January 18, 2004 Posts: 45 Location: Las Cruces, NM
Posted: Sun Jul 30, 2006 10:17 pm Post subject: |
propflux01 wrote: |
Aluminum is stronger and therefore more crack resistant. After having two magnesium cases get cracked oil galleys, I like the option of aluminum. More importantly, the foundry was probably trying to reduce the ammount of magnesium casting it had to do, since most of its work is aluminum.
propflux01 wrote: |
AS41 are far lighter, have do not have tooling problems. |
What tooling problems are you refering too? I haven't noticed any machining problems with the aluminum cases. They're certainly easier to weld for full flow oiling. _________________ '70 KG 'vert '96 GTI 2.0 |
krusher Samba Member
Joined: September 24, 2002 Posts: 7662 Location: europe
Posted: Mon Jul 31, 2006 12:21 am Post subject: |
1200RS wrote: |
jamestwo wrote: |
of course
50% more weight.
He ran in the mid 10's  |
People allways think in 1 dimension when they like to put somthing down. But how long will that as41 last doing 10's?
I'm no advocate of the alu case, but people seem to miss that if it turns out to be as strong as the type4 case, you may be able to do 200,000 hard miles open it up and find no line bore is needed and the mains have not become battered from high gear luggin.
There should be long term benifits, keep that in mind.
Oh and this question gets covered about once a month, can we have a sticky to follow what people have found whiule using them.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79473 Location: Sneaking up behind you
Posted: Mon Jul 31, 2006 3:00 am Post subject: |
krusher wrote: |
Okee Dokee, but let's keep it n topic. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
soazvw Samba Member
Posted: Mon Jul 31, 2006 5:09 pm Post subject: |
so for dirveability and reliability i should go with a alu block because it is stronger? _________________ 74 custom standard bug <1915w120cam>
Glenn  Mr. 010
Posted: Mon Jul 31, 2006 5:11 pm Post subject: |
soazvw wrote: |
so for dirveability and reliability i should go with a alu block because it is stronger? |
No.
Most if not all of the aluminum cases are sand cast and are brittle. _________________ Glenn
Member #1009
#BlueSquare
Wild Bill Samba Member
Joined: January 02, 2006 Posts: 1013 Location: Pepsi-Cola, Fl
Posted: Tue Aug 01, 2006 11:07 am Post subject: |
Just built a 2110 alu block. Will put in on the engine stand this week to break it in. Goes into the car this weekend. I'll give a report as to what happens. ps I drive real Hard!! _________________ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~
"Life in the Fast Lane ?....What the Hell does that feel Like?"
"Wild" Bill Tucker
Pensacola, Fl
1978 Champagne Edition (High Top Camper Converstion.) 2.0L FI
1969 Squareback 2.0L
www.rareairvw.com |
soazvw Samba Member
Posted: Tue Aug 01, 2006 1:50 pm Post subject: |
so glenn do you recommend a as41 then? _________________ 74 custom standard bug <1915w120cam>
millerje78 Samba Amishman
Joined: October 16, 2005 Posts: 2445 Location: Holmes County, Ohio
Posted: Tue Aug 01, 2006 3:06 pm Post subject: |
you ought to look for an AS-21 case if you are super worried about strength. those use a stronger alloy than the AS-41 and can be found in fuel injected late model bugs. I think there is one in the classifieds right now. _________________ always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry |
Glenn  Mr. 010
Posted: Tue Aug 01, 2006 3:09 pm Post subject: |
soazvw wrote: |
so glenn do you recommend a as41 then? |
I built my 1904cc on a German Industrial AS-21 case. It's about as strong as you can get... and it's OEM. _________________ Glenn
Member #1009
#BlueSquare
GeorgeL Samba Member
Posted: Tue Aug 01, 2006 4:17 pm Post subject: |
Is _anyone_ making a _correctly_ machined aluminum case? I've never heard of anyone putting together a motor based upon a aluminum case without major corrective machine work. There's a fellow on the type2 list whose aluminum case turned into a supreme money pit.
I think I'd look into converting a wasserboxer case before I went for an aftermarket aluminum case. There's still a lot of machining involved, but at least you start with a VW factory case that is predictable.
George |
Posted: Tue Aug 01, 2006 4:27 pm Post subject: |
empi cases are the best, believe it or not, and they are cheaper. _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
Posted: Tue Aug 01, 2006 6:18 pm Post subject: |
Glenn wrote: |
Most if not all of the aluminum cases are sand cast and are brittle. |
http://www.webelements.com/webelements/elements/text/Al/xtal.html
http://www.webelements.com/webelements/elements/text/Mg/xtal.html
Observe that magnesium has a hexagonal close packed (HCP) crystalline structure, while aluminum had a cubic close packed or face centered cubic (FCC) crystalline structure. The HCP structure has only one close packed plane while the FCC structure has 4 close packed planes. The likelyhood of four planes having one aligned in the direction of applied stress is much greater than only one plane, therefore dislocation motion inside the FCC crystal grains is much more likely to occur resulting in plastic deformation, while in HCP applied stress will more likely result in high stress concentration at grain boundaries leading to microcrack growth and finally macroscopic crack development and propagation.
GeorgeL wrote: |
Is _anyone_ making a _correctly_ machined aluminum case? I've never heard of anyone putting together a motor based upon a aluminum case without major corrective machine work. |
http://www.grupohubner.com.br/autolinea/04_produtos.html
I've got an Auto Linea case. It arrived ready for a stock 1600. The only work I had to do was bore it for 90.5mm cylinders, clearance it for a 78mm crank, and weld, drill, tap, and plug for full flow. These would all have to be done to a stock magnesium case anyway, and the welding was much easier on aluminum.
I will say that the oill pump I have was 0.050" out of alignment with the oil galleys in case, but that was remedied by a 0.050" thick piece of aluminum and a hole saw to shim it out.
Being that Auto Linea casts nonferrous parts for Catapillar, Ford, VW, Mercedes-Benz, Scania, and Volvo, I feel that I can trust their abilities to do it right. _________________ '70 KG 'vert '96 GTI 2.0 |
