Update on 74 bus problem
slow_and_the_curious
slow_and_the_curious is offline
PostPosted: Sat Oct 14, 2006 4:04 pm    Post subject: Update on 74 bus problem Reply with quote
In my recent post i was saying that smoke was coming from out of what looked like a breater tube. But after looking at some pics of other engines, i saw the tube that looked like it but it wasnt open and sticking out, it was connected to something.
If you look at the engine from the open hatch at the rear it is in front of the carb and slightly to the right on top of the engine. It looks like a black braided hose connected to the top middle of engine.
Any ideas of what it is and what it means if busted?
Brian 11
Brian 11 is offline
PostPosted: Sat Oct 14, 2006 4:45 pm    Post subject: Reply with quote
Can you either take a picture of it for us or copy a picture of one you have seen and put it here?
I CAN MAKE IT UP THIS HILL IN 4TH GEAR I CAN MAKE IT UP THIS HILL IN 4TH GEAR
My Fleet:
1972 BAY Flash Back
1963 Beetle Nana's Little Bug
1977 Ford F100
1972 Nova
No computers, No abs. Yea! GOTTA LOVE THE OLD STUFF!!!
If everything I tell you is a lie and I then tell you I'm lying, am I?
PostPosted: Sat Oct 14, 2006 5:08 pm    Post subject: Reply with quote
heres a pic
http://viewmorepics.myspace.com/index.cfm?fuseacti...1289086995
PostPosted: Sat Oct 14, 2006 5:39 pm    Post subject: Reply with quote
I am really hoping that whatever this tube is that busted might be what caused my bus to mess up. Better then something more major.
Any ideas yet on what it is?
Brian 11
Brian 11 is offline
PostPosted: Sat Oct 14, 2006 5:49 pm    Post subject: Reply with quote
What year Bay do you have, The pic is small. Are you talking about the black hose running just behind the fan shroud , the one with the duct tape on it, the smaller gray looking one running vertical, the smaller black one comming from behind the duct tape twoard the drivers side or the larger black one behind the last one I stated running up and to the left. A better picture would help. Going to try to post the picture here I don't know if that will blow it up or not and I will try to blow it up but it will come out a little fuzzy. What kind of carb system do you have on it or is it FI? Here is where you can go to learn how to post a pic directly.
http://www.thesamba.com/vw/forum/viewtopic.php?t=6
Anyone else out there seeing what I am not??? Yes I'm old and my eye perscription is due...
My Fleet:
1972 BAY Flash Back
1977 Ford F100
1972 Nova
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Oct 14, 2006 5:52 pm    Post subject: Reply with quote
Can you point it out in this photo?
mine is a 74 bay window kombi with a carb
the hose in which i am reffering to is the one directly above the big metal piece in the pic running parallel to it
PostPosted: Sat Oct 14, 2006 6:15 pm    Post subject: Reply with quote
heres a pic
On my bus that hose is severed and the tip looks melted
what is it?
Randy in Maine
PostPosted: Sat Oct 14, 2006 6:19 pm    Post subject: Reply with quote
So it is the 12 or 14mm hose that goes from the oil breather to the carb for combustion?
Replace it if it is torn.
PostPosted: Sat Oct 14, 2006 6:22 pm    Post subject: Reply with quote
its not torn, there is only half of it....the left side is still connected and i dont know where the right side is or where it should be going.
Do you think that could be the reason why my bus will start but not move?
PostPosted: Sat Oct 14, 2006 6:55 pm    Post subject: Reply with quote
Are both ends of hose supposed to be connected to something or is one end supposed to be open?
This is huge because if this hose isnt supposed to be open ended cut-off like it is then it might be the reason why my bus starts and idles bit wont drive...
Anyone know?
Wildthings
Wildthings is offline
PostPosted: Sat Oct 14, 2006 6:59 pm    Post subject: Reply with quote
Since you said "a carb" you probably have an aftermarket progressive that was sloppily installed. Your crankcase vent needs to go to your air cleaner preferably on the outside of you element while using a PCV filter. This is more easily said than done with most junky progressive setups. It is likely easier to go to the inside of the filter element, but you should have some form of backfire preventor in place to keep from blowing you rocker covers off.
PostPosted: Sat Oct 14, 2006 7:03 pm    Post subject: Reply with quote
Sorry man.. everything you just said went slightly over my head. The two main things i need to know is
1. should my hose be connected to something on both ends
2. Could this be the reason my bus will start and idle but not drive?
ChiTwnVW
ChiTwnVW is offline
PostPosted: Sat Oct 14, 2006 7:18 pm    Post subject: Reply with quote
Yes.
Probably not.
PostPosted: Sat Oct 14, 2006 7:22 pm    Post subject: Reply with quote
well damn... for a few minutes there i was thinking i wouldnt have to drop 500 to have a new clutch put in.
By the way is 500(Parts and labor) a good price to have somebody put a new clutch in?
ChiTwnVW
ChiTwnVW is offline
PostPosted: Sat Oct 14, 2006 7:48 pm    Post subject: Reply with quote
Why do you think it's the clutch?
What was your other thread?
PostPosted: Sat Oct 14, 2006 7:54 pm    Post subject: Reply with quote
In my other thread i was talking about how i bought it and drove it about ten miles. The first time it got it anywhere near 60mph, fourth gear was doing more reving then actual powering. Then 3rd started doing it and then second and now if i start it and put it in first gear, it will barely inch forward with the clutch all the way out...
I really like my new bus and just wish i could actually get to drive it. Talk about ultimate frustration.
Here's a pic
ChiTwnVW
ChiTwnVW is offline
PostPosted: Sat Oct 14, 2006 8:44 pm    Post subject: Reply with quote
A clutch kit costs about 150, mechanics usually charge around 50 per hour, so 500 is a bit high but not totally nuts. If you've got the dough and don't feel like doing it yourself, go for it and start driving!
PostPosted: Sat Oct 14, 2006 8:46 pm    Post subject: Reply with quote
Im all for doing it myself but am not fully confident that i know enough mechanically to pull it off.
Know of any good links that explain it step by step including removing the engine?
ChiTwnVW
ChiTwnVW is offline
PostPosted: Sat Oct 14, 2006 9:41 pm    Post subject: Reply with quote
ratwell.com has an engine pull step by step. Shouldn't be more than a 5 or 6 hour job.
