Daniel Hood Samba Member
Posted: Sat Oct 21, 2006 6:33 pm Post subject: My alternator conversion |
Here's some photos of my 2110 with CB fuel injection and Denso alternator conversion that is fully adjustable. Also notice the heater outlets and oil tube are gone. I just got it running yesterday
59 vw guy Samba Member
Joined: October 09, 2002 Posts: 969 Location: Oklahoma
Posted: Sat Oct 21, 2006 6:36 pm Post subject: |
Freakin sweet whered you get the brackets.. _________________ New project 66 bug And 61 bug for parts if you need some 61 parts im me to see if i have it Will trade 61 parts for dual carbs and bumpers for a 66.. |
Posted: Sat Oct 21, 2006 9:04 pm Post subject: |
I made the brackets and requires machining of the fan housing. I also used a modified billet aluminum alt pulley that is used on nascar engines.
As I felt the denso pulley was to small. |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2962 Location: Fresno, Ca.
Posted: Sat Oct 21, 2006 9:24 pm Post subject: |
You need to throw up some more pics of the car Daniel. Inside and out. _________________ If you`re going to do something, do it right. |
Posted: Sun Oct 22, 2006 6:47 am Post subject: |
I agree and make more..  _________________ New project 66 bug And 61 bug for parts if you need some 61 parts im me to see if i have it Will trade 61 parts for dual carbs and bumpers for a 66.. |
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Sun Oct 22, 2006 9:26 am Post subject: |
how did you do that with the fan shroud? did you just weld some new metal in orr....
and where do you fill the oil these days, or does it run on MAGIC  _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
Posted: Sun Oct 22, 2006 9:46 am Post subject: |
Yes, I welded new pieces of metal in. I add oil in from the breather box.
there is some more photos of the car, Click on my gallery. |
squareonair Samba Member
Joined: February 11, 2005 Posts: 990 Location: springfield,missouri
Posted: Sun Oct 22, 2006 9:53 am Post subject: |
Daniel Hood wrote: |
so each time you add oil ...you have to unscrew the two bolts on top?  |
Posted: Sun Oct 22, 2006 11:13 am Post subject: |
Well its not like its going to burn oil. You`ll only have to do it when you change oil. _________________ If you`re going to do something, do it right. |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Sun Oct 22, 2006 12:52 pm Post subject: |
is there a dipstick somewhere or am I just not seeing it? _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Sun Oct 22, 2006 12:56 pm Post subject: |
blankmange wrote: |
is there a dipstick somewhere or am I just not seeing it? |
i didnt see one.. |
Posted: Sun Oct 22, 2006 2:48 pm Post subject: |
You guys didn't see it.
electricmonk Samba Member
Joined: August 25, 2005 Posts: 538 Location: South Australia
Posted: Sun Oct 22, 2006 4:35 pm Post subject: |
Nice, I would realy like more details an the alternator, How many amps? what exactly did you use and what needed to be fabricated and how? I can get a few things done at work as I just don't have tools anymore like I used to. Any pics of how you did it? |
Posted: Sun Oct 22, 2006 8:01 pm Post subject: |
Look in his gallery for more pics. _________________ If you`re going to do something, do it right. |
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3307 Location: So. Cal. Oceanside GFK!
Posted: Sun Oct 22, 2006 8:04 pm Post subject: |
Very clean, looks nice!  _________________ It's not about the window, it's about the people.
German Folks |
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3069 Location: Portland, Oregon
Posted: Mon Oct 23, 2006 7:53 pm Post subject: |
electricmonk wrote: |
The original and more:
http://www.icbm.org/erkson/ttt/engine/generator.html#custom
In kit form:
http://www.theddb.com/ _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
Posted: Mon Oct 23, 2006 7:54 pm Post subject: Re: My alternator conversion |
Here's some photos of my 2110 with CB fuel injection and Denso alternator conversion that is fully adjustable. Also notice the heater outlets and oil tube are gone... |
Nice work! I like the shorty fan housing
Two recommendations:
1. Move the coil to a cooler location. On top of the case isn't a good spot and coils need to keep cool. I'd recommend moving up to an after-market ignition system when you can to get even more power;)
2. Try to get taller air filters if you can. Makes a noticable difference in power output with more air filtration area...BTDT. _________________ Toby http://www.aircoolednut.com/
Posted: Mon Oct 23, 2006 8:05 pm Post subject: |
There are no other air cleaners that will fit under the lid. I don`t think it makes much difference as I have ran my car without filters for tuning and it feels the same with then on or off. _________________ If you`re going to do something, do it right. |
Posted: Tue Oct 24, 2006 11:02 am Post subject: |
I dropped 1/4 inch on my air filter height and felt the power loss. See if you can find a slightly taller air filter; it just will make taking the air filter tops off a little more challenging. Mine are VERY close to touching (but aren't) the engine lid surround. I understand engine dynamics/physics as well and know from that perspective that the lower surface area creates a restriction, too. I bet if you put it on a dyno you'd see the difference as you're engine is only 103cc bigger than mine  _________________ Toby http://www.aircoolednut.com/
trylordurben Samba Member
Joined: January 11, 2005 Posts: 402 Location: Hialeah, Fl
Posted: Tue Oct 24, 2006 11:25 am Post subject: |
very nice!
where do you get those dizzy wires that are bent 90 degrees?
im curious as to how your fan shroud mods affect the airflow? i know there was a thread on how beetle motors work better with the original heater ducts as opposed to the removed ones, just wondering if you looked into that? My shroud has the ends plugged.
how do you like the fuel injection kit? my friend is putting the same kit in his beetle.
again, your motor looks very nice! |
