redrum71 Samba Member
Joined: August 07, 2006 Posts: 494 Location: No-wheresville KS
Posted: Tue Dec 12, 2006 7:40 pm Post subject: Solex 30/31 H |
Has anyone heard of this carb? The first time I've seen one was on my car and tuning has proven to be a hair pulling task!!! which isn't remotely close yet as it's running rich as hell, how reliable is this carb, does anyone know? Also does anyone have any pictures of the vacuum line routing my car doesn't have any, and when I un-cap the ports on the carb I get no suction, any ideas where to start??? _________________
72 FAT chick
71 baywindow -
67 Baja  |
clarkbre Samba Member
Joined: June 20, 2004 Posts: 1107 Location: Everett, WA
Posted: Tue Dec 12, 2006 7:44 pm Post subject: |
| I've got one on my '69. It's run great for the last 5 years. Yes, tuning them can be a trick. I think it also depends if you have the Brosol or the other kind. Mine's the Brosol and I've heard those are the prefered ones. It's also in the jetting as well. I can't remember what size jet I'm running but I know I had to alter that. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80175 Location: Sneaking up behind you
Posted: Tue Dec 12, 2006 7:47 pm Post subject: |
I've got a Solex H30/31PICT on my 1600DP and it runs great. The vacuum advance port is #1 on the left side.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Migit Banned
Joined: July 09, 2004 Posts: 831 Location: Central Illinois
Posted: Tue Dec 12, 2006 9:32 pm Post subject: |
Have an intake leak there Glenn? Blow the plug out of the front? Mine was JB welded looks like you used some Juicy Fruit or something!! _________________ Looking for a 58 euro hardtop! |
TimD_66 Samba Member
Joined: February 01, 2005 Posts: 1170 Location: San José, California
Posted: Wed Dec 13, 2006 2:30 am Post subject: |
i have a Brosol H30/31 and its nearly impossible to tune correctly, or even close....its really been giving me trouble this week and ive been threatening to hammer it to pieces....on thursday im swapping it out for a different carb though...cuz its gotten so bad that i go nuts when i drive it...(ive got like a 2 second delay on takeoff, wont get up to speed, and more problems...)
the brosol H30/31 is a brazillian POS...my recommendation: trash it now before your headache gets worse, and get a proper german carb.  _________________ '58 Ragtop bug - 2276T (Re-assembly in progress!)
'65 13 window deluxe bus (SWR/BG)
'04 VW R32 - 3.2L VR6
B.L.T.N.
N.A.G. |
Failer Samba Member
Joined: April 16, 2005 Posts: 520 Location: South Austin
Glenn  Mr. 010
Posted: Wed Dec 13, 2006 3:55 am Post subject: |
| Migit wrote: |
| Have an intake leak there Glenn? Blow the plug out of the front? Mine was JB welded looks like you used some Juicy Fruit or something!! |
That's the way it come on the engine. This was just a spare and will soon be replaced by a 2180 in the Spring.
| TimD_66 wrote: |
| i have a Brosol H30/31 and its nearly impossible to tune correctly, or even close. |
Mine runs great. I tried it with a 009, 034 and 010 distributor, the 010 works best. I replaced it with a 34PICT-3 and tried the same 3 distributors and found the H30/31PICT and 010 was the best of the 6 combos.
It idles smooth and pulls smoothly through all the gears.
If you're having problems remove the jets and blow the carb out. That worked for me. _________________ Glenn
Member #1009
#BlueSquare
Posted: Wed Dec 13, 2006 8:26 am Post subject: |
glenn- the huge difference between yours and mine is that yours is a german Solex H30/31, and mine is a new Brazilian Brosol H30/31....two different carbs, even if they may be then same model. _________________ '58 Ragtop bug - 2276T (Re-assembly in progress!)
B.L.T.N.
N.A.G. |
Glenn  Mr. 010
Posted: Wed Dec 13, 2006 8:34 am Post subject: |
| TimD_66 wrote: |
| glenn- the huge difference between yours and mine is that yours is a german Solex H30/31, and mine is a new Brazilian Brosol H30/31....two different carbs, even if they may be then same model. |
If you say so. I haven't had a stock engine in my car since 1978. And as soon as my 2180 is done it will be put back into storage. _________________ Glenn
Member #1009
#BlueSquare
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Wed Dec 13, 2006 9:48 am Post subject: |
| Glenn wrote: |
| TimD_66 wrote: |
If you say so. I haven't had a stock engine in my car since 1978. And as soon as my 2180 is done it will be put back into storage. |
I don't think there is such a thing as a German 30/31...
Dud's exist with all models of carbs. I don't see why anyone has to condem all of a model just because the one you have doesn't function properly.
Except maybe those new Pierburg Kafer 34's  |
LedFloyd Samba Member
Joined: August 12, 2004 Posts: 227 Location: Somewhere outside Barstow
Posted: Wed Dec 13, 2006 10:21 am Post subject: |
| clarkbre wrote: |
Did you go up or down on the jet? I just ordered a 130. Hoping that eases the flatspotting and tuning pains until I get my SVDA. _________________ "Smokey this is not Nam, this is bowling, there are rules." |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26598 Location: Douglas, WY
Posted: Wed Dec 13, 2006 11:23 am Post subject: |
| keifernet wrote: |
I've seen some H30/31's run just fine, and some run like <bleep>. A lot of the time it's because your distributor doesn't mate up well with it (refer to the thread mentioned above for more on that topic.)
Actually, there IS such a thing as a German Solex 31PICT-3. I'd read about them in a British VW history book, but never saw one til a while back on another post here. That carb was designed for the 1300DP engine sold in Europe. But it's a bit of a different beast than the H30/31 replacement carb they make in Brazil.
I can't remember/find what thread the pics were in, but for my "carb reference" photo file I snagged the pics, here's one of them:
Posted: Wed Dec 13, 2006 2:50 pm Post subject: |
Okay, so i'm running a 009 dist. with a petronix ignitor II in it, and it's running rich as hell, it has a small flat spot off idle but other that that it runs great, plus it doesn't have ANY vacuum lines hooked up, any ideas on how to lean it out or hook up vacuum lines?
thanks! _________________
72 FAT chick
71 baywindow -
67 Baja  |
Posted: Wed Dec 13, 2006 3:15 pm Post subject: |
With an 009, all vacuum lines are to be capped off, so as long as yours aren't open to the atmosphere, you're set up right.
If the choke is working properly, and none of the jets are plugged or messed up, the only way to really lean it out is to put in different jets, either a smaller main jet or larger air correction.
-Andy |
Posted: Wed Dec 13, 2006 7:34 pm Post subject: |
| glutamodo wrote: |
| keifernet wrote: |
Doesn't say 30/31 though does it?
I have seen a few of those on some german imported used engines back in the late 80's early 90's.
Pretty sure the brazillian 30/31 is a copy based on that carb. |
Posted: Wed Dec 13, 2006 7:39 pm Post subject: |
Well I decided to pull it off and re-build it tonight, when I took it appart there was alot of crap in it so I cleaned the hell out of it. I also looked it over and noticed that it's a Brazilian Brosol, I'm not sure if that makes any difference tuning wise or not.
With my last bug I was running a 34 PICT, with an 009 and I had one line off the carb to the air box, and if i'm understanding everyone correctly, with the 30/31 and an 009 you don't run any vacuum lines?
Thanks for all the help guys!! hopefully i can get this thing ruinning better  _________________
72 FAT chick
71 baywindow -
67 Baja  |
Posted: Thu Dec 14, 2006 3:20 am Post subject: |
| keifernet wrote: |
You're right, no H30/31 on that one. And yeah, I'm sure the Brazillian version was based on that too - except Brosol obviously "reworked it" to be more universal, or actually more like the 30PICT-3. I don't know what the "H" means either, but I'm sure that has something to do with what they did to it. The German one only has two vacuum lines coming out of it instead of 4, and missing that extra casting on the side of the float bowl (manual choke cable support of some kind, it looks like) - and I'm thinking the German one probably is designed to work with the SVDA wheras the Brosol one doesn't unless modified. |
Posted: Thu Dec 14, 2006 8:02 am Post subject: |
| glutamodo wrote: |
| keifernet wrote: |
Seems more like the 31 you posted pic of and the 34 pict 3 to me due to the placement of the idle air shutoff solenoid VS the electromagnetic idle pilot jet on the later 30 pict series.
I agree that they re worked the tooling to try and make a replacement carb to cover many models/markets ( all the vaccum hookups for various pollution control devices found on US cars?) I can't recall ever trying one with a late model SVDA... although I have read the information about the vacuum signal not being correct or causing some kind of timing advance issue. I mostly see the carb run with 009.
Andy...is the 30/31 supposed to work well with the eariler single vaccum only distribs? Seems like it should...Have you posted somewhere in all the threads you participate in the info? I may have missed reading it. Link me up if you can.  |
canvmnvw Samba Member
Posted: Thu Dec 14, 2006 8:50 am Post subject: |
I have the exact same carb on my 1641 DP type 1 engine and am using a stock 009 distributor with all vacume lines plugged. Mine runs great and I never seem to have any problems tuning it ???
Added note: I purchased mine back in the mid 90's or so from MOFOCO. Back then, they were selling several "modified" versions of this carb with different jetting etc to work in conjuction with various different distributors. I purchased the version "pre-tuned ?" to work with the 009.
worked great right outta the box and still does after 10 or so years. Don't know if MOFOCO still offers this service, but they might have some helpful info regarding rejetting etc.?????
PS my front cap also blew out JB welded a dime in the hole .... Must be a fairly common problem  |
Posted: Thu Dec 14, 2006 9:06 pm Post subject: |
| keifernet wrote: |
Well, that's in my "huge" post where I compared a bunch of different stock carbs to the H30/31.
http://www.thesamba.com/vw/forum/viewtopic.php?t=185095
Basically, the conclusions there were that the H30/31 is plumbed internally much like the 30PICT-3, which was a vacuum-only carburator. The vacuum tests I did with it unmodified showed they were quite similar in their advance curves. And neither of them generat nearly strong enough of a vacuum pull to work an SVDA diaphram correctly. Unless you play with modifying it, or buy one already modded, I'd ONLY want to use a vacuum-only distributor with that carb.
-Andy |
