Mirror / Hing Pin Removal - ok I did a search
Page: 1, 2, 3, 4  Next
Skim
Rants Master
Skim is offline
PostPosted: Fri Jan 19, 2007 8:25 pm    Post subject: Mirror / Hing Pin Removal - ok I did a search Reply with quote
My 60 SC came with no outside mirrors, I have the arms but whats the best way to knock out the door hing pins to put the mirror arms in. I know this has probably been asked a million times already. Thanks in advance.
GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
campingbox Premium Member
campingbox is offline
PostPosted: Fri Jan 19, 2007 8:31 pm    Post subject: Reply with quote
I use an air chisel. Be sure to have an anchor on top to keep from tweaking the door hinges (I'm sure you have access to a railroad tie).
Skim
Rants Master
Skim is offline
PostPosted: Fri Jan 19, 2007 8:34 pm    Post subject: Reply with quote
should I marinate them in some PB blaster for a few days prior?
GFK
1953 Kabriolet
1954 Sunroof
PostPosted: Fri Jan 19, 2007 8:38 pm    Post subject: Reply with quote
It won't hurt.....I've never had one that an air chisel wouldn't move.
Lind
Lind is offline
PostPosted: Fri Jan 19, 2007 8:43 pm    Post subject: Reply with quote
my experience is that the PB blaster won't really penetrate into it. it is too tight of a fit.
Wanted:
j.pickens
j.pickens is offline
PostPosted: Fri Jan 19, 2007 9:05 pm    Post subject: Reply with quote
Please elaborate on the technique.
Thanks,
J.
BeaterBarndoor wrote:
Red Fau Veh wrote:
hazetguy
hazetguy is offline
PostPosted: Fri Jan 19, 2007 9:24 pm    Post subject: Reply with quote
try these threads, they might help:
http://www.thesamba.com/vw/forum/viewtopic.php?t=96800
http://www.thesamba.com/vw/forum/viewtopic.php?t=49937
Skim
Rants Master
Skim is offline
PostPosted: Fri Jan 19, 2007 9:26 pm    Post subject: Reply with quote
thanks Hazet Cool
GFK
1953 Kabriolet
1954 Sunroof
PostPosted: Fri Jan 19, 2007 9:28 pm    Post subject: Reply with quote
Here's a photo of the piece of railroad track I used last time. This keeps you from damaging the hinge itself and still allows enough clearance to move the hinge pin.
Skim
Rants Master
Skim is offline
PostPosted: Fri Jan 19, 2007 9:31 pm    Post subject: Reply with quote
haha now I get it, you said Railroad 'Tie', I was like hmmm? Question Very Happy
GFK
1953 Kabriolet
1954 Sunroof
PostPosted: Fri Jan 19, 2007 9:33 pm    Post subject: Reply with quote
Skim wrote:
haha now I get it, you said Railroad 'Tie', I was like hmmm? :?: :D
My bad......what I meant was track. This specific "all-purpose tool" was found while travelling on the Shasta Snow Trip.
hazetguy
hazetguy is offline
PostPosted: Fri Jan 19, 2007 9:37 pm    Post subject: Reply with quote
thanks Hazet Cool
just saying, there might be some info in there that may help, and may not be said in here. please don't kill me.
Skim
Rants Master
Skim is offline
PostPosted: Fri Jan 19, 2007 9:42 pm    Post subject: Reply with quote
thanks Hazet Cool
Shocked
GFK
1953 Kabriolet
1954 Sunroof
hazetguy
hazetguy is offline
PostPosted: Fri Jan 19, 2007 9:52 pm    Post subject: Reply with quote
Laughing
scruzdelux
scruzdelux is offline
PostPosted: Fri Jan 19, 2007 10:15 pm    Post subject: Reply with quote
This thread from Hazetguy looks the best. I removed mine by soaking with PB for several hours, heating to help the penetration, and knocking it out from below with a punch and small sledge. Air hammer sounds like a good way too. Once you get movement soak and heat some more. A good soaking, for as long as you can, is important.
-Jeff
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Fri Jan 19, 2007 11:21 pm    Post subject: Reply with quote
One of mine was stuck to the point where I had to take the door off and invert it on an anvil and drive the pin out with a long drift and a BFH. It did finally come out though.
j.pickens
PostPosted: Fri Jan 19, 2007 11:56 pm    Post subject: Reply with quote
Campingbox, do you have an air chisel insert small enough to punch out the pin? Or have you made up some sort of adaptor, or what?
Red Fau Veh wrote:
Aaron
Samba Luddite
Aaron is offline
PostPosted: Sat Jan 20, 2007 12:24 am    Post subject: Reply with quote
I couldn't find a correct size attachment when I had a stuck pin so I ground down a tapered attachment. Once I got the pin started I used the stem of an old valve and a mini sledge.
Mr. Loaf
Mr. Loaf is offline
PostPosted: Sat Jan 20, 2007 4:01 am    Post subject: Pin Reply with quote
If you get the old pins out don't forget to ream the hinges for the new pins.
Never drive faster than your Angel can fly
$24,100 was too hard to resist.................
Metalwizard
Metalwizard is offline
PostPosted: Sat Jan 20, 2007 6:48 am    Post subject: Reply with quote
I soak with pb and for about 30 mins then i heat with the henrob torch. Spray it again, then use the air hammer while its still a bit warm. I have a tapered punch that came with my last new air hammer and it works great, its not tapered enuff to go all the way through but after it once moves 1/2 inch or so you can use a normal drift punch. Same deal works on cargo door hinges as well. I have just changed about 5 in the last month on this damn 56 Sunroof getting it ready to ship home later this week. If it don't kill me first that is. Oh also on the hinges do as Greg says about backing it up with something with some ass. And back the air down on the hammer, you shouldn't need full force, it might get away from you and fuck up something you don't want it to. Don't ask how i know that please. Shocked
http://s461.photobucket.com/albums/qq335/Metalwizard/
Kelly aka
"Bubble & Nut Buster for wannabe BadBoy's of Restoration"
"There is no cure for Stupid"
ITMC "Drill SGT"
View user's profile Send private message AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
Page 1 of 4
