Align bored and Thrust cut any good for mild motor
cal63look
cal63look is offline
PostPosted: Sat Jan 06, 2007 8:04 pm    Post subject: Align bored and Thrust cut any good for mild motor Reply with quote
Ok case is an as41 freshly checked out from the machine shop, cylinder mating surfaces leveled and resurfaced .040 thrust cut and .020 line bore. Would this be OK for a mild 1776-1835??
The Noof
The Noof is offline
PostPosted: Sat Jan 06, 2007 8:33 pm    Post subject: Reply with quote
Properly done, align bored case is fine for that purpose. I used a case that was .5mm on the o.d./1mm on the thrust for a turbo application and it is holding up fine. As long as the machine work is good, you won't have any issues.
1432
1432 is offline
PostPosted: Sat Jan 06, 2007 9:51 pm    Post subject: Reply with quote
If properly done a line bored case is good for all applications.
nsracing
nsracing is offline
PostPosted: Mon Jan 08, 2007 7:45 pm    Post subject: Reply with quote
AMEN!!! Very Happy
Thank goodness. Finally. Some sense of direction.
Nater
Nater is offline
PostPosted: Mon Jan 08, 2007 7:52 pm    Post subject: Reply with quote
Shocked They have only been align boring cases for ......what 40 years?
gt1953
gt1953 is offline
PostPosted: Tue Jan 09, 2007 6:28 am    Post subject: Reply with quote
I do not see a problem with what has been done with your case...while you are at it make it full flow.
72 type 1
72 Squareback
EZGZ
EZGZ is offline
PostPosted: Tue Jan 09, 2007 7:06 pm    Post subject: Reply with quote
in 1993 I thought I would freshen up a running 1776.
It turned out to be 4th over on main and thrust.
I bought a cheap welded counterweighted crank that was .020 over.
I threw some .100 shims under the barrels which brought the compression down below 7 to 1.
I put that engine in service in a manx buggy, then a sandrail and then on the street. I gave it to my son to run the beegeezus out of it in a bus. That POS is still screaming today and leaks from every seam.
I think the trick was to keep the compression down.
You don't have anything to worry about.
64 custom Ghia, 66 Bug, Sandrail, Barrien tub
cal63look
PostPosted: Sat Jan 20, 2007 6:21 pm    Post subject: Reply with quote
Ok bringing back up this post, i received my bearings from the guy i bough the case from today and they are mahle ext- .50 int- std. are these the correct bearings??? I put the rear in to see how it fits i think thust is correct bearing isnt loose but snug if i push it in.
Please help are these correct bearings?? I have the specs in my first post.
Ace
Ace is offline
PostPosted: Sat Jan 20, 2007 8:40 pm    Post subject: Reply with quote
What about heat and stress. An align bore doesn't do anything to correct this.
propflux01
propflux01 is offline
PostPosted: Sat Jan 20, 2007 10:03 pm    Post subject: Reply with quote
Actually, yes it does. It returns the main saddles to a straighter line, therefor relieving the stress if a twisty crank or cocked gear and the resultant heat and HP loss from that internal friction.
1432
1432 is offline
PostPosted: Sat Jan 20, 2007 10:51 pm    Post subject: Reply with quote
[quote="cal63look"]Ok bringing back up this post, i received my bearings from the guy i bough the case from today and they are mahle ext- .50 int- std. are these the correct bearings??? I put the rear in to see how it fits i think thust is correct bearing isnt loose but snug if i push it in.
Please help are these correct bearings?? I have the specs in my first post.[/quote]
With your case +.020" and your crank at standard size your bearings should be +.05mm, std, + 1mm (os .040" thrust). be certain thrust bearing is a 'snug' fit in it's saddle, with the thrust bearing in position in the 1/2 case you should not detect any movement when wiggiling the exposed half of the bearing.
Tip, when final installing your crank in one case half, use the opposite 1/2 shell of the center main to straddle the crank (center main journal) when the two halves contact each other (or very close to contact) you can be confident that all bearings are aligned properly with their corresponding dowel pins. During pre assembly (always a good idea) when the case is torqued, with crank only, it should spin easily with no more than finger tip pressure as well as move freely front to back.
1432
1432 is offline
PostPosted: Sat Jan 20, 2007 10:56 pm    Post subject: Reply with quote
What about heat and stress. An align bore doesn't do anything to correct this.[/quote]
Any problems related to heat or stress should be evaluated and addressed prior to any machine work being done on the case.
Ace
Ace is offline
PostPosted: Sun Jan 21, 2007 1:43 pm    Post subject: Reply with quote
You tell my old center main support that.
MackB
MackB is offline
PostPosted: Sun Jan 21, 2007 4:47 pm    Post subject: Reply with quote
A properly done align bore should be good for any application, but one must make a reasonable judgement as to if the case is fit to be reused, and having it done by a reputable company with proper tools such as rimco, will ensure that the tolerances will be perfect and problems such as low oil pressures will not be a problem.
propflux01
PostPosted: Sun Jan 21, 2007 6:30 pm    Post subject: Reply with quote
Perhaps it wasn't the case or line-bore to begin with....
1200RS
1200RS is offline
PostPosted: Tue Feb 13, 2007 2:29 pm    Post subject: Reply with quote
about stress, it's easy to correst this.
the only way i find is to let the block in the garage during at least 3 months and it will be stabilized, and after, align it.
the same process is used on milling machine or other made with cast iron, but it need 6 months at least.
sorry, i'm french
vwinnovator
vwinnovator is offline
PostPosted: Tue Feb 13, 2007 5:32 pm    Post subject: Reply with quote
Sounds like you center main was warped. A good shop would have checked that before alignboring and told you to trash that case. I clean and torque every case to check for warpage BEFORE I alignbore them.
It's the "little" things like this that make for a good build.
GregZA
GregZA is offline
PostPosted: Wed Feb 14, 2007 1:41 pm    Post subject: Reply with quote
I'm curious to know exactly how you check for warpage and where?
I am assuming that you are not just talking about ovality in the housing...
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Wed Feb 14, 2007 1:44 pm    Post subject: Reply with quote
Bolt the case halves together with the six main studs/nuts and shine a flashlight down the case... if it is warped you will see light on the center main #3 bearing where the case halves touch on either side of the bearing saddle.
GregZA
GregZA is offline
PostPosted: Wed Feb 14, 2007 1:51 pm    Post subject: Reply with quote
Okay so we're talking about warpage of the mating surface of the case halves?
Back in the day they used to standardize casings by facing both halves and align boring the main housings and reaming the cam housings, then you still had to remachine the oil pump housing.
Not really worth all the effort, especially considering the trauma that a case needing all this done would have been through but it was once common practice here. (South Africa)
