My Bus' Rear End Is Sagging
Page: Previous  1, 2
OB Bus
OB Bus is offline
PostPosted: Thu Aug 17, 2006 5:07 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
"...overlooked by the stock zealots."
Apparently, you are talking to me. (???) If so:
1. I'm not a stock zealot. If you have seen my bus or my posts, you'd know that.
2. I know very well that coilovers were factory options and wouldn't mind putting them on my bus.
To which, I again say, this is ass backwards. Adjust the torsion bars (assuming they are out of spec which may or may not be the case), then think about shocks.
Nemo - chill. You are not a stock zealot and neither am I. There are a number of people that upon seeing the word "coilover" react as if a GEX engine was being forced upon their bus. Coilovers were a factory option and should not immediately be discounted. I do not have the tools or physical skills to adjust spring plates and the local shops want $350-500 to do the job. $80 of coilovers solved my problem and have worked well for the past 18 months.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Aug 17, 2006 5:19 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
steponmebbbboom wrote:
Tram wrote:
OB Bus wrote:
Chrispoage wrote:
What about just using coil over shocks instead of doing the tortion thing? It seems like that would be way easier and less dangerous... has anyone done that as a solution to the soggy bottom bus?
Yep, have the coil overs on my '69. This was a somewhat ghetto remedy to 15" wheels with too much offset and 205/75R15 Michelins. They work great. Ride and handling much better that the worn out gas-a-justs they replaced and the fender lips now clear the tires.
Where did you get them? My '71 Westy DOES have a case of droopy drawers.
This is not the proper way to remedy the problem. The Bentley manual describes the proper procedure to adjust the torsion bars, the only thing they do not tell you is what a minute (*) means, which IIRC is a 20th of a degree? Last time I posted on this subject I had the manual in front of me.
IMO you do not need the tool to reposition your spring plates. If you put a jackstand under the torsion tube to support the bus and use your floor jack saddle on the end of the spring plate, you can easily remove and reinstall the plate, gently pry outward with a crowbar while the saddle is supporting the wheel end of the plate, and let it down when you are clear of the stop block. Pound with a rubber mallet on the bar end of the plate (I had to use the mallethead as a drift and hit it with a 4lb sledge) to install. Use new rubber bushings. I used this method and had full control of the spring plates at all times, it was completely safe.
Coil over shocks are a band-aid solution. Your bus was designed to use the torsion bars as springs, your back end will be disproportionately stiffer than the front, which will make the bus handle funny.
I suspect the factory coil-overs were part of a package deal that included other upgraded components to return the suspension to some sort of balance. In any case it's cheaper to just adjust the bars correctly, and you will get better results.
Where did I say I wanted to remedy it PROPERLY? Laughing
And yes, coilovers were often installed AT THE DEALER to compensate for a SLIGHT droop, esp. on Westys, and they did the job well.
I'd love to order a set but they are, naturally, out of stock. Rolling Eyes
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
nemobuscaptain
nemobuscaptain is offline
PostPosted: Thu Aug 17, 2006 5:45 pm    Post subject: Reply with quote
Re: coilovers availability:
I found the coil overs for a mid 80's Chev Astro Van fit the rear of a Late Bay Vw Bus you do need to add a spacer [drilled out nut] and a longer bottom mounting bolt.
Ask you FLAPS to show you the coil overs shocks for a 1986 Chev Astro Van,, They have worked great on my Camper for over 150,000kms, and now I am on a new set.
They won't lift your bus any considerable amount,, mine lift the camper about 1/2" at the rear--Jamie Rivers
Jamie had a webpage showing this installation, but I cannot find it now.
OB, what kind are you using?
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
fukengruvenoval
fukengruvenoval is offline
PostPosted: Thu Aug 17, 2006 5:48 pm    Post subject: Reply with quote
Just my $0.02 on coilovers...
Keep in mind the shock mounts were never designed to handle the kind of forces coilovers will put on them.
Yes, coilovers were a factory option but consider this:
1. This was 30 years ago, the mounts and surrounding metal have almost certainly degraded since then.
2. The rears didn't have a sag from the factory when the coilovers were an option. The coilovers would have worked immediately in conjunction with the torsions to add support to the rear for carrying heavy loads. Using them to raise a sagged rear end means they are handling a significant amount more weight than originally intended.
I considered it briefly on my bus but decided against it for these reasons, plus the fact the rear isn't really sagged anyway, as others point out, when there is weight in the front everything seems level.
Do a search on this forum and you'll see plenty of horror stories of wrecked shock mounts from coilovers.
Check out my video series at www.youtube.com/midnightoilgarage
OB Bus
OB Bus is offline
PostPosted: Thu Aug 17, 2006 5:49 pm    Post subject: Reply with quote
The ones from CIP that (according to Tram) are apparently out of stock. I tried to track down the Astro shocks, but no one could give me a firm idea of which ones were "correct". The ones from CIP are adjustable also.
Larry in OB
nemobuscaptain
PostPosted: Thu Aug 17, 2006 7:37 pm    Post subject: Reply with quote
OB, try Jamie Rivers on type2.com.
GeorgeL
GeorgeL is offline
PostPosted: Thu Aug 17, 2006 9:20 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
Tram wrote:
And yes, coilovers were often installed AT THE DEALER to compensate for a SLIGHT droop.
I don't know about the "often". I recall that someone dug up a picture of coil-overs on a VW parts microfiche, but I've never seen a "factory" coilover in the flesh or even a picture of one on a bus. They might well be in the "rarest of the rare" category.
That being said, a coilover would be fine to lift the rear a half inch or so. More than that and you'll be much better off doing a spring plate adjustment. It doesn't require much in the way of special tools. I did it in a casual weekend and I've had many miles of level motoring since.
George
guatebus
guatebus is offline
PostPosted: Fri Aug 18, 2006 6:48 am    Post subject: Reply with quote
To change the subject slightly:
How is all of this related to rear-wheel camber? I did the spring plate adjustment on my '69 a couple of years ago and the ride height looks good. However, I still have a negative camber on the rear wheels that seems greater than the spec listed in Bentley. According to the manual, rear wheel camber is largely a function of the spring plate angle...
Why is my camber still lousy and how can I fix it?
- Guatebus
Micropassatman
Micropassatman is offline
PostPosted: Fri Aug 18, 2006 10:15 am    Post subject: Reply with quote
I have coilovers on my '70 as well. I used them primarily to keep the sidewalls of my rear tires from being cut to shreds. Seems to do the job just fine. They are not overtly harsh at all, and they reduce that 'sailboat effect' in high winds and while swimming with semis.
steponmebbbboom
steponmebbbboom is offline
PostPosted: Fri Aug 18, 2006 1:54 pm    Post subject: Reply with quote
- Guatebus
Because you didnt replace the spring plate bushings at the same time.
guatebus
guatebus is offline
PostPosted: Mon Aug 21, 2006 8:50 am    Post subject: Reply with quote
Ahem.
I did replace those bushings at the time. Any other ideas?
- Guatebus
JamesT
JamesT is offline
PostPosted: Wed Mar 28, 2007 9:09 pm    Post subject: Reply with quote
- Guatebus
Spring plate bushings have almost no affect on camber. The cause of the negative camber on bays is that over the years, the weight of the bus causes the inner trailing arms to flex upwards. You can kinda fix this problem by swapping the sides of the inner trailing arms. the only thing that you have to change is the cup that the kong hits against. I did this on my double cab and it solved the camber problem. I left my bay with this problem when I lowered it just because it looks like a swing axle (and I'm lazy...).
-James T
1968 Kombi
1995 Eurovan Camper
2006 Garbage Jetta TDI
cbr900racer
cbr900racer is offline
PostPosted: Sun Apr 01, 2007 4:03 pm    Post subject: Reply with quote
i just came in from adjusting the the driver's side rear of my 71 bay. i could not believe how easy that was! I thought doing a bug was easy. all i removed was the nut on the Ebrake cable, remove the clip that holds brake line to diagonal bars and remove the top shock bolt. That by far was the easiest i have ever done. I will attack the passenger side sometime this week. I guess they probably got alot harder from 72 on Crying or Very sad
71 Bay (1776 in process)
94 Sonoma
98 Suburban (bike hauler)
97 Blazer
07 Nitro
94 CBR900RR (runs 5.70s 1/8 mile)
woodyvw9
woodyvw9 is offline
PostPosted: Sun Apr 01, 2007 6:15 pm    Post subject: Reply with quote
I went on a different route altogether, when I replaced stock wheels with 15' BRM replicas I put slightly taller tires on the back than on the front. No more sag and heck I needed new tires anyways. Sort of ghetto but it worked and I did not have to do any trigonometry.
Woody
1978 Westy
1986 Jetta turbo-diesel
2002 Passat GLX wagon
theizzardking
theizzardking is offline
PostPosted: Mon Sep 28, 2015 4:21 pm    Post subject: Reply with quote
Kirwin wrote:
You should probably do a search on the topic first. That subject has been hit many times.
Hey, good luck, I have the same problem with my Bus.
CMK
i hate these sort of posts....
you know why this thread got brought back from the dead after 8 YEARS?!
because someone used the search function and ended up in a thread where some jackwad tells someone to use the search function...lol..
if you are going to go to the effort of scolding someone for not using the search function at least be helpful and throw up a link to help them out...and everyone else out as well, even if they come through 8 years later...
i get why people say "use the search", just remember that some people actually do and they will end up in these threads as well...
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer"
Jimmunson
Jimmunson is offline
PostPosted: Thu Mar 17, 2022 8:26 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
We have a ‘71 bus and there is no room for coil over shocks. I thought that would be a solution too, but not on this year.
aeromech
aeromech is offline
PostPosted: Thu Mar 17, 2022 9:36 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
I put them on my 1971. They lasted for years. Never damaged anything. That was back in the 1980’s. Later, I pulled them and installed a new set of Bilsteins. Can’t remember if I adjusted my torsion bars but I probably did. That was a long time ago
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
metahacker
metahacker is offline
PostPosted: Thu Mar 17, 2022 10:26 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
you can fit Gabriel HiJacker 49215 rear shocks
they are chrome piston gas shocks with real "bellows" style suspension air-bags over them and a steel shield over them. (basically an "air coil-over")
they are tough and work well.
the price vs quality is pretty remarkable IMO, they are very inexpensive! (yet very high quality IMO)
they are not to be confused with the monroe max-airs .. which are just not as nice IMO
i have them on 2 buses, a 69 single cab and a 78 riviera camper ..
here they are on a vanagon, fitment is similar...
(they look big and fat but clearance has not been an issue for me with 225 or 215 tires on the one side, or the frame itself on the other)
you can use, i believe, Audi bolt part N-909-24-02 for upper mount bolt.... with an extra washer under shock ear (as a spacer for alignment)
and the stock upper bolt in lower position
that is how they are on my 78 IIRC
the mounting ears are a little wider, so hence the hardware changes ..
alternatively, on my 69 i cut the shock ears down and pressed in the stock bushings from a vw OE shock.. and mounted using the original hardware... IIRC...those went on 12 years ago.... still hold air just fine
if you look at the standard OE replacement shocks (per Gabriel) for the rear of a Bus, here are the specs:
Shock Extended Length: 22.73 in. 577.34 mm.
Shock Collapsed Length: 13.87 in. 352.3 mm.
Length of Stroke: 8.86 in 225.04 mm.
here is the bagged shock
Shock Extended Length: 23.02 in. 584.71 mm.
Shock Collapsed Length: 14.16 in. 359.66 mm.
you can see they are within a reasonable tolerance of each other (less than 1/3" length...and identical stroke)
you should use gabriel accessory kit # 141099 with them.. which will plumb them with independent air lines ... that way air doesn't transfer between them while cornering (acting as an anti-anti-sway-bar Smile )
they fill/release air using a standard schrader tire valve that you can easily mount in the existing factory holes in your fender, or somewhere else clever like in the support brackets for the heater box dump tubes .. you add air to add more 'coil-over' support and remove it to reduce spring rate ... they are terrific for load-leveling or simply adding a little bit of spring rate ..
they are rated to take ~20-25 min to 200 max (!) psi ...
VW has a history of using coil overs in the rear of buses, as the single cab was rated at +0.25 tons additional load with a VW optional coil over.. so i don't consider adding them to be inherently unsafe
that said, reinforcing the mounts is always a good idea with any "coil over" (bagged shock is essentially the same)
i once have used the hijackers on my single cab to haul 2,200 lbs of concrete rubble .. easily reset to stock ride height with a reasonable amount of psi and worked great ...
you can basically dial in how high you want your rear and corner match between sides for uneven loads (like a bunch of camper stuff...i know vanagon guys use these same shocks and talk about their "westy lean" on the drivers side)
IMO bilstein front and gabriel hijacker rear is BY FAR my favorite setup for a Bus after testing stock, KYB gr-2, KYB gas-a-just and even the famous Koni adjustables
also, i believe Gabriel 49307, based on my research, fits the front if you want to get crazy adding air bags to the front ... but, i have not ran those ... and can't say much ..
and yes one should not ignore the index of the rear torsion bars .. one should be mindful of understanding / making sure they are set properly... in tandem with these variable rate coil overs
you have some useful adjustability ..... the base height of the torsion bars can be decreased/increased in tandem with adding/removing air to alter the final spring rate ...
Abscate Premium Member
Abscate is offline
PostPosted: Fri Mar 18, 2022 2:29 am    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
One minute of arc is 1/60th of a degree, one second of arc is 1/60 th of a minute.
Units borrowed from time. The SI unit of angle of measure is the radian
2 * pi radians , approximately 6.28 = 360 degrees
Page: Previous  1, 2
Page 2 of 2
