mr matt Samba Member
Joined: May 26, 2005 Posts: 980 Location: southeast Pa
Posted: Wed Jun 27, 2007 12:35 pm Post subject: |
Glenn wrote: |
Any condenser will work. It's just if you want Bosch or close to correct. |
When looking for a replacement, what is required of a condensor for the distrib mentioned to work?
Does it have to be 6 Volt? Not sure if anyone tried switiching 6 volt for 12 volt Bosch
Thanks!!
Matt
Also, Glenn, good to have met ya at the Maple grove show, helped with answering some questions I had -thanks |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26533 Location: Douglas, WY
Posted: Wed Jun 27, 2007 3:04 pm Post subject: |
Ignition condensers work on either 6V or 12V. It's just a capacitor. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79563 Location: Sneaking up behind you
Posted: Wed Jun 27, 2007 3:26 pm Post subject: |
glutamodo wrote: |
Exactly. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Jun 28, 2007 4:23 am Post subject: |
So then even with all the 12 volt VW distrib.s, it does not matter what capicitor to buy (as long as fits to the distrib body)..............
Matt |
Glenn  Mr. 010
Posted: Thu Jun 28, 2007 5:47 am Post subject: |
mr matt wrote: |
Matt |
Yes. _________________ Glenn
Member #1009
#BlueSquare
Glenn  Mr. 010
Posted: Mon Nov 19, 2007 5:07 pm Post subject: |
So... has anyone found an alternative source for aftermarket condensers that fit? _________________ Glenn
Member #1009
#BlueSquare
vwtoyguy Samba Member
Joined: January 31, 2005 Posts: 344 Location: West Fork, AR
Posted: Mon Nov 19, 2007 5:46 pm Post subject: |
Isn't that your job Glenn?  _________________ 1957 Karmann Ghia
1960 Beetle
1965 Mexican CKD Beetle
1967 Beetle Volksrod Project
1967 Beetle Ratrod project
1971 Super Beetle
1971 Squareback
1971 Bus
1972 Beetle
1973 German market standard Beetle
1974 Super Beetle Baja
1988 Scirocco
Home of the most knowledgeable Herbie The Love Bug enthusiasts on the Web |
Glenn  Mr. 010
Posted: Mon Nov 19, 2007 5:50 pm Post subject: |
vwtoyguy wrote: |
Isn't that your job Glenn?  |
Not if you ask my wife.
One option is the use the 02006 which is used on the 010 and does not have a mounting tab. You can mount it with a bracket from a 40hp Big Cap. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Glenn  Mr. 010
Posted: Thu Nov 29, 2007 5:45 pm Post subject: |
Here's my solution, just use a 02006 and get a condenser bracket from a 40hp distributor.
This is a 019, but the VJU4BR8 will look the same.
Member #1009
#BlueSquare
splitjunkie Samba Member
Glenn  Mr. 010
Posted: Fri Mar 07, 2008 11:22 am Post subject: |
THEY'RE BACK
Wolfsburg West now has in stock reproduction 36hp condensers that look fairly close to the original yellow wire ones. These will fit on VJU4BR8, VJ4BR8 and 0 231 192 019 distributors. They will also fit on 383, but are the small diameter version.
I spoke to them and they have 2000 in stock so hopefully they will be around for a while.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111905295 _________________ Glenn
Member #1009
#BlueSquare
Posted: Fri Mar 07, 2008 12:07 pm Post subject: |
is there an echo in here?? _________________ Chris
Glenn  Mr. 010
Posted: Fri Mar 07, 2008 12:48 pm Post subject: |
splitjunkie wrote: |
is there an echo in here?? |
Damn you....  _________________ Glenn
Member #1009
#BlueSquare
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9407 Location: Northwood, NH USA
Posted: Fri Mar 07, 2008 1:54 pm Post subject: |
Glenn wrote: |
Damn you....  |
Damn you.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Just ribbin' ya.
You must get Wolfsburg wired delivered to you inbox too. _________________ Chris
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Fri Mar 07, 2008 3:41 pm Post subject: |
The information in this thread is incorrect. The condenser is available from Wolfsburg West. |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1495 Location: Finland
Posted: Fri Mar 07, 2008 11:25 pm Post subject: |
Major Woody wrote: |
No, it's correct. WW is not delivering Bosch parts, they are reproductions. |
Glenn  Mr. 010
Posted: Sat Mar 08, 2008 6:51 am Post subject: |
I didn't expect a kid of Spanish Inquisition.
Member #1009
#BlueSquare
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Mar 08, 2008 8:32 am Post subject: |
Glenn wrote: |
I prefer the Mel Brooks version of the Inquisition, via History of the World Prt 1 |
Glenn  Mr. 010
Posted: Mon Mar 10, 2008 9:19 pm Post subject: |
I just got my order and have to say they sort of look correct.
The bad:
The body is way to shiny... looks like chrome.
The wire is too thin and the loop on the engine doesn't hold it's shape.
The good:
They fit.
They work.
I'll post a side by side picture tomorrow. _________________ Glenn
Member #1009
#BlueSquare
