Brake lines..comments?..suggestions?
ZENAK
ZENAK is offline
PostPosted: Tue Jul 17, 2007 6:06 pm    Post subject: Brake lines..comments?..suggestions? Reply with quote
i was wondering if they made brake line kits out of (kunifer)? if so, who Question
rubbachicken wrote:
.....i wouldn't use steel lines though, they'll rust in time
kunifer much better, {similar stuff to what pennies are made of} will not corrode ever, has a very high pressure bursting rate.....
beetleboy58
Samba Conquestador
beetleboy58 is offline
PostPosted: Tue Jul 17, 2007 6:19 pm    Post subject: Reply with quote
kunifer=copper?
ZENAK
ZENAK is offline
PostPosted: Tue Jul 17, 2007 6:43 pm    Post subject: Reply with quote
after 1982 pennies were made of an alloy..that much copper was worth more then a cent, so save you old pennies Wink ....
and sorry i cant speal two goud Embarassed Smile
Alan Brase
Alan Brase is offline
PostPosted: Tue Jul 17, 2007 11:01 pm    Post subject: Reply with quote
beetleboy58 wrote:
kunifer=copper?
There is some premium alloy metal out there sold for brake line tubing. It has copper and other stuff in it.
Regular Bundyflex (a common US brand of tubing) has a little copper in it.
I figure it's good enough for me. Strong, no cracking. It will rust out, but here in the rust belt, it usually takes 30 years. I figure the next 30 should be easier on the vehicle. After that, it will be my heirs' problem.
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
ZENAK
ZENAK is offline
PostPosted: Tue Jul 17, 2007 11:05 pm    Post subject: Reply with quote
but does it come in kits? for a split bus?...id like to do it right, but i dont wanna bend and flare the lines my self..otherwise i guess ill use steel line kits....what do yall use>? Question
bubblehead
bubblehead is offline
PostPosted: Wed Jul 18, 2007 6:33 am    Post subject: Reply with quote
Don't know of any ready made kunifer kits for splits. Just got the steel kit from wolfsburg west and its got a sort of anodised coating on it so it should last a good long time. FWIW I'm replacing the Og 53 year old lines that dont even leak. How long do you need your lines to last? Also one of the main benefits of the kunifer lines is that they are easier to flare and bend than steel. If you're buying the kit this isn't really an issue.
Clara Premium Member
Clara is offline
PostPosted: Wed Jul 18, 2007 7:24 am    Post subject: Reply with quote
Kunifer is a copper nickel alloy
http://www.ireland-alloys.co.uk/Alloys/CopperNickelAlloys/tabid/113/Default.aspx
http://en.wikipedia.org/wiki/Bundy_pipe
ZENAK
ZENAK is offline
PostPosted: Wed Jul 18, 2007 2:32 pm    Post subject: Reply with quote
i guess your right. the OG lines lasted this long- probably longer if it didnt sit for 25-30 years... i live in Alaska and i dont wanna drive it in the winter, but if i do the steel lines wont implode Razz ...i think the coating is teflon...are you happy with your kit from wolfsburg?..
bubblehead
PostPosted: Thu Jul 19, 2007 6:01 am    Post subject: Reply with quote
Dunno. I just got them in the mail a couple weeks ago and haven't gotten around to installing them yet. They look nice enough, good flares and hardware etc. If they fit OK I'll be happy with them. They are German made which I thought was pretty cool.
