Culito 11010101
Joined: December 07, 2006 Posts: 5882 Location: Columbia Missourah
Posted: Wed Sep 05, 2007 8:20 pm Post subject: TBI |
I'm sure this has been talked to death in here, but has anyone slapped a TBI setup from a small 4cyl on a VW engine?
I've looked into some multi-port VW stuff and it seems like overkill/expensive for a non-performance vehicle. Seems like a simple TBI setup adapted to a stock manifold shouldn't be too much of a problem.
Ideas? _________________ © CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
| johnnypan wrote: |
| ...dont pay no attention to Culito,he's a cornhole.. |
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1066 Location: Gilbert,Arizona
Posted: Wed Sep 05, 2007 11:28 pm Post subject: |
Turbo city out of California,years ago made a T.B.I.setup that used a G.M. unit.Don't know if they still do or not.Hope this helps! _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Sep 06, 2007 1:03 am Post subject: |
I would say that if you're going to go ahead and put EFI on a VW engine, there's really no reason I can think of to go one way or the other. I guess it just depends on what you're trying to achieve.
For example, some people like their engines to look stock, but want the benefits of EFI (e.g. stock resto/resto rod). If I fell into that category, I would modify a standard carburator to function as a throttle body by removing the venturi's, pulgging idle/main circuts, and mounting an injector in such a way that it could be hidden by the stock air cleaner. That's quite a bit of work, so what most people do is use a TB from a production vehicle, and adapt it to work on the car's existing manifold. I don't see any reason why not to do that to a VW engine, aside from the normal fuel dropout/vapor lock issues people sometimes have with carb'd engines.
OTOH, multipoint parts for VW engines are really cheap these days, and if you have any aspirations of going turbo one day, MPI is the way to go IMO. For example, I put together an entire MPI system using Megasquirt and various bits and peices from the junkyard and CB Performance for less than the cost of only a standalone ECU from another company (greddy, ect). _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
| satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Culito 11010101
Posted: Thu Sep 06, 2007 1:29 am Post subject: |
I don't really care about the stock look. I was just looking for an alternative to the fussiness/inefficientcy of a carburated system.
A friend of mine suggested something along the lines of a Suzuki Samuri TBI system...it's relatively simple and the engine size is close. With a addition of a few sensors, it doesn't seem too far-fetched.
Again, I'm not looking for super performance...just reliability and effiicientcy.
| Quote: |
| multipoint parts for VW engines are really cheap these days |
Really? I haven't seen a full-on kit advertised for less than a few thousand bucks. Compare that to a cheap junkyard retrofit... _________________ © CJ Industries, Inc.
'62 bug
| johnnypan wrote: |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16790 Location: North Florida, USA
Posted: Thu Sep 06, 2007 1:57 am Post subject: |
This sounds very interesting.
I'm just starting to collect parts for a EFI system based around a MegaSquirt ECU. I'm not near any junk yards so I've been searching the Internet and eBay. The closest thing I've seen are EFI Motorcycle TBs. These usually come as a set of four, but some are easy to break apart.
Bikes tend to have smaller engines than acvws and their TBs are meant for one on each individual cylinder, but they rev a whole lot higher (like 14,000RPM)! That's like 3x what you might expect for a simple VW. This means one bike TB may have the capacity to handle a stock 1600cc VW engine.
I'll be interested i nwhat you find. _________________ AshMan40
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Thu Sep 06, 2007 3:36 am Post subject: |
I would go with port injection, with TBI you still have the fuel puddling in the manifold like you do with a stock carb. Port injection will increase the performance, drivability and the fuel economy over a TBI setup. The Megasquirt ECU along with a TB from a 2 litre car on a plenum style manifold are a good starting point. _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Culito 11010101
Posted: Thu Sep 06, 2007 10:01 am Post subject: |
So the megasquirt can control a TBI setup? I'll have to study the megasquirt more.
I realize that a multi-port setup would be better, but I really don't want to mess with the stock manifold...I don't suppose I'd be afraid of fabbing a new piece between the DP end castings, though.
What about timing? Doesn't the computer in most TBI or multi-port systems sense the timing and control the advance accordingly? _________________ © CJ Industries, Inc.
'62 bug
| johnnypan wrote: |
Loopole Samba Member
Posted: Thu Sep 06, 2007 11:23 am Post subject: |
go to the shoptalkforums.com, go to the fuel injection forum for your education. I have been looking into this for some time, the new megesquirt two is really impressive, can now control all your ignition needs now as well. One aproach would be to use an early vw cis throttle body which is a two barrel progressive t/b. These have the same footprint as a weber progressive, so use a weber progressive manifold and use cb performance dual port end castings with the fuel injector bungs welded in, not a engineered plenum setup but should work well for a small displacement engine, and minimal fabrication. I am considering doing this, but some have said the dual port end casting will be way to restrictive for a 2110 even if opened up. Another option is the full on dual idf style throttle bodies but then you are into some serious money.
Another option would be to convert your pict 34 to a throttle body by removing the venturi and adapting a tps to it and use the cb end castings.
then lock out your 009 and add a pertronix, you probably already have these.
return fuel line, new pump and regulator 150
buy a preassembled megasquirt/harness $350
cb efi endcastings fuel rail and injectors $250
plus of course your time and tinkering but would be in another universe as far as driveability and economy, and simplicity. someone needs to do it. |
Posted: Thu Sep 06, 2007 11:47 am Post subject: |
| Culito wrote: |
| So the megasquirt can control a TBI setup? |
Yes.
| Culito wrote: |
| I realize that a multi-port setup would be better, but I really don't want to mess with the stock manifold...I don't suppose I'd be afraid of fabbing a new piece between the DP end castings, though. |
if you don't want to mess with the stock setup too much, you can always mount a TPS on the carb and use THESE for a simple multipoint setup. That's what I did.
| Culito wrote: |
| What about timing? Doesn't the computer in most TBI or multi-port systems sense the timing and control the advance accordingly? |
Megasquirt can control a wide range of ignition systems, and is even capable of driving coil on plug setups directly from the ECU. I'm using Ford's EDIS system, for distributorless ignition. All that's required for EDIS is the crank trigger, a trigger disk mounted on the pulley, the coil pack, control module, and the associated wiring. I got everything for free from a junkyard...  _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
buggofast Samba Member
Posted: Thu Sep 06, 2007 1:16 pm Post subject: |
| buying every piece you could put a multiport setup together for around, 1200 or so. I wouldn't waste my time w/ tbi it's barely a step above the carb. cb sells stock end castings with injector bungs in them. I built my own centersection to work w/ a ford tb and made my own fuel rails on my first setup. |
Culito 11010101
Posted: Thu Sep 06, 2007 2:18 pm Post subject: |
| Quote: |
| Megasquirt can control a wide range of ignition systems, and is even capable of driving coil on plug setups directly from the ECU. I'm using Ford's EDIS system, for distributorless ignition. All that's required for EDIS is the crank trigger, a trigger disk mounted on the pulley, the coil pack, control module, and the associated wiring. I got everything for free from a junkyard... |
Well that's pretty awesome.
How did you do your trigger/disk setup?
I'd like to see some pics of tbi or home made multi port setups. _________________ © CJ Industries, Inc.
'62 bug
| johnnypan wrote: |
Posted: Thu Sep 06, 2007 8:00 pm Post subject: |
| Culito wrote: |
I'd like to see some pics of tbi or home made multi port setups. |
Well, I suppose I could show off a little....
Here goes. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
Posted: Thu Sep 06, 2007 8:44 pm Post subject: |
I mounted the trigger wheel with 5 allen head machine screws, lockwashers, and locktite on the threads to make sure it doesn't come apart at speed. It was a bitch to get it centered, it would have helped if I had bought a solid pulley instead of this one with the holes.
Or, you could just buy one from these guys:http://home.earthlink.net/~beanbooger/boost_engineering/
I haven't fabbed the bracket for the VR sensor just yet...
EFI end castings. They will be plummed to a single TB, for simplicity.....
....which is in turn fed by CB's turbo buggy header, and one of 4 different turbochargers (I don't know which one will work best yet ) Oh yeah, it will be intercooled as well. That's as much progress as I've made since getting off the boat, more to come soon, I hope.
I'm a lazy b*stard!
| Glenn wrote: |
Culito 11010101
Posted: Fri Sep 07, 2007 9:35 am Post subject: |
Cool stuff.
I guess since I'm pretty low on cash, I'll have to stick with my crappy 34 pict 3 for now.
But I'll be planning the ultimate setup in the meantime.
(insert evil laugh here) _________________ © CJ Industries, Inc.
'62 bug
| johnnypan wrote: |
