Smoke cleanup-off topic
chipmcluk
chipmcluk is offline
PostPosted: Sun Dec 16, 2007 3:27 am    Post subject: Smoke cleanup-off topic Reply with quote
So I had somewhat of a grease fire in the kitchen today, scared the shit out of me. Got it out and everything cleaned up except the smoke buildup on the ceiling. Since it was vegetable oil which ignited, i figured engine degreaser would do the trick. It does. But the fumes are awful, especially to use excessively in the kitchen. Anyone know of anything else that would do the trick? Also, the Mrs. comes back into town Sunday night, and I want no evidence!
typesoneandtwo
typesoneandtwo is offline
PostPosted: Sun Dec 16, 2007 5:52 am    Post subject: Reply with quote
Do not use oven cleaner!
I suppect you need to scrub and re-paint your ceiling. Try TSP for cleanup.(hardware store) and if it still looks yucky you will need a fresh coat of paint. Maybe there's an interior painter here with different advice. If iit's only a small area you may have decent results with a household cleaner containing bleach and/or grease cutting agents. Good luck!
Each day is precious.
spook
spook is offline
PostPosted: Sun Dec 16, 2007 6:28 am    Post subject: Reply with quote
bakingsoda
www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here.
View user's profile Send private message Visit poster's website Facebook Twitter Classifieds Feedback
KGCoupe
KGCoupe is offline
PostPosted: Sun Dec 16, 2007 7:22 am    Post subject: Reply with quote
Try a cleaner called Simple Green - that stuff rarely is harmful to any surface, yet does a great job of cleaning.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Sun Dec 16, 2007 7:31 am    Post subject: Reply with quote
Shocked
The stuff should be used rather quickly as it will "clean" much more than you want if left to sit, specially on painted surfaces! Confused
KGCoupe
KGCoupe is offline
PostPosted: Sun Dec 16, 2007 7:38 am    Post subject: Reply with quote
pyrOman wrote:
Shocked
Really?
I've never had a problem with it, and I've cleaned several engines with it.
I've even used it to clean body panels on a car that has sat outside for many years, and it shined them up nicely.
I should point out that I don't ever let it sit long though - just spray it on, add a little cold water to the surface, a quick scrub with the appropriate tool (depending on what I'm cleaning), and then rinse with cold water.
It makes sense that it can damage a surface if left on too long - I know it works great for cleaning off Audi and Porsche brake dust, and that shit is hard to get off.
typesoneandtwo
PostPosted: Sun Dec 16, 2007 7:59 am    Post subject: Reply with quote
I always though Simple Green smelled like black licorice.
AuBenseiter Motor Sports
AuBenseiter Motor Sports is offline
PostPosted: Sun Dec 16, 2007 8:28 am    Post subject: Reply with quote
Thats Purple Power and Eagle1 Mag wheel cleaner
chipmcluk
PostPosted: Sun Dec 16, 2007 9:25 am    Post subject: Reply with quote
A repaint isn't necessary, I know. I have tall ceilings throughout my house (no trailer, fuckers) and the flames never hit the ceiling, just some sooty shit. The engine degreaser worked well when I tested it in a spot, but its just too fucking caustic to use around food. It was a mad dash to the fire extinguisher, and this all happened within 35-45 seconds. KEEP A FIRE EXTINGUISHER IN THE KITCHEN!! Saved my ass.
mandysbus
mandysbus is offline
PostPosted: Sun Dec 16, 2007 9:56 am    Post subject: Reply with quote
try hand cleaner...the white gloppy petrol based kind....
69 Jim
69 Jim is offline
PostPosted: Sun Dec 16, 2007 10:12 am    Post subject: Reply with quote
It does to me also. That shit is an awesome engine cleaner. Cool
chipmcluk
PostPosted: Sun Dec 16, 2007 10:49 am    Post subject: Reply with quote
Thank you!
I tryed orange goop, its all I have in my house and it works very well! Still have alot to do though.
mandysbus
PostPosted: Sun Dec 16, 2007 11:08 am    Post subject: Reply with quote
Very Happy glad it worked...a friend of mine left a kerosene pot burner heater turned up too long and sooted his whole room.looked like someone sprayed flatblack paint over the whole room.
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Sun Dec 16, 2007 11:18 am    Post subject: Reply with quote
Oh, it's awesome alright.
I used it to remove greasy dirt around the engine louvers on my
O.G. Beetle and it took the paint right off! Crying or Very sad
KGCoupe
KGCoupe is offline
PostPosted: Sun Dec 16, 2007 1:44 pm    Post subject: Reply with quote
Are you people that are removing paint with Simple Green using the original formula, or the Automotive version?
I've only used the original formula, and have not had any bad experiences with it.
I've never used the automotive formula, but suspect that it may be stronger.
You did read on the bottle that it should be diluted with water, right?
69 Jim
69 Jim is offline
PostPosted: Sun Dec 16, 2007 2:54 pm    Post subject: Reply with quote
I spray it on in a fine mist of 100% solution. Then I rinse it off with clear water. It doesn't seem to harm rubber, decals or anything else under the hood. It sure does an awesome job. My cars look showroom underneath and under the hood. Cool
