Small Car Performance new stainless exhaust - LOCKED
Franklinstower
Franklinstower is offline
PostPosted: Wed Jan 16, 2008 3:33 pm    Post subject: Small Car Performance new stainless exhaust - LOCKED Reply with quote
Moderator edit: This thread is LOCKED. More information to be found at:
http://www.thesamba.com/vw/forum/viewtopic.php?t=457261
FYI - I just saw this on the SV Yahoo page.
Small Car has a new stainless exhaust that fits the WBX and Subaru Conversions...
It sure looks purdy....
http://smallcar.com/images/ssexhaustt.jpg
http://smallcar.com/index.php?act=viewProd&productId=132
Another option besides TK's.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
Tristar Eric
Tristar Eric is offline
PostPosted: Thu Jan 17, 2008 12:18 am    Post subject: Reply with quote
See it here installed:
http://forums.vwvortex.com/zerothread?id=3590419
I added the 911 muffler and custom high flow cat.
Vanagon/Transporter flares here: www.terrawagen.com
[email protected]
D Clymer
D Clymer is offline
PostPosted: Thu Jan 17, 2008 10:56 am    Post subject: Reply with quote
It sure looks like a good deal to me. It also has a clever design detail. They set up the tailpipe and muffler outlet flange to use a metal donut just like the J pipe. This allows you to angle the tip for whatever your application demands.
I have a Smallcar stainless Vanaru header, and the quality is very impressive. Whoever they have doing those stainless parts has certainly got it together.
David
pete000
pete000 is offline
PostPosted: Thu Jan 17, 2008 3:01 pm    Post subject: Reply with quote
It also fits stock 2.1 as well !
I just ordered one .
FOR SALE CHEAP S & S ceramic coated performance muffler.
1990 Vanagon
Koni Shocks
Witech Springs
Addco Sway Bars Front-Rear
OEM Porsche Wheels
Recaro Power-Heated seats
JL Audio, Kenwood, Soundstream, MB Quart, Audiocontrol
D Clymer
D Clymer is offline
PostPosted: Thu Jan 17, 2008 3:55 pm    Post subject: Reply with quote
Yeah, the wbx compatibility ends up being a bonus since their Subaru conversion uses the stock wasserboxer J-pipe and muffler. The parts they make for the conversion end up being a high quality solution for wbx owners too. Post a picture when you install yours.
David
Franklinstower
PostPosted: Tue Jul 15, 2008 8:26 pm    Post subject: Reply with quote
Eric,
I just received my 911sc Muffler in the mail today. What kind of cat is that? How is the interior noise level of the engine under load?
Do you have more pictures of how you hung the muffler. Fortunately, mine also came with the 911 clamps. Now I just have to figure out how to connect it to the the SC header. Any help on what you did would be great!
Thanks,
Paul
YITB
Sodo
Sodo is offline
PostPosted: Fri Nov 26, 2010 5:22 pm    Post subject: Reply with quote
I have this stainless exhaust, 2 years old, and it's really rusty. I would not be able to tell the difference between this and "steel".
http://www.smallcar.com/index.php?dispatch=products.view&product_id=29829
http://www.smallcar.com/index.php?dispatch=products.view&product_id=29799
Should 304 rust like this? I could post a photo but it might give some folks the willies... Shocked Shocked
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important.
syncrodoka
syncrodoka is offline
PostPosted: Fri Nov 26, 2010 5:57 pm    Post subject: Reply with quote
Pictures, pictures, pictures
(you have to chant it like the jerry springer theme song)
Sodo
Sodo is offline
PostPosted: Fri Nov 26, 2010 8:00 pm    Post subject: Reply with quote
It was gleaming, looked like chrome, just like this:
This photo below is 22 months old. I'm surprised to the extent that it rusted. Wondering if the aluminized coating process would be better than this type of stainless (304).
Notice even the Stainless bolts rusted bigtime.
The question: Is this "normal" for stainless --->exhaust<--- systems?
Tom
Vango Conversions
Vango Conversions is offline
PostPosted: Fri Nov 26, 2010 10:00 pm    Post subject: Reply with quote
The small car exhaust sure does look nice new but I've seen quite a few failures. The outer surfaces do rust, especially in salty conditions but the main thing is that sometimes the muffler baffles come loose, causing a loud and rattling exhaust. Stock steel mufflers last about as long.
The headers are made of the same stuff and they look beautiful at first but I've seen many crack and rust. I'm curious as to how many people have had good or bad experiences with those headers after a year or so of regular use?
syncrodoka
PostPosted: Fri Nov 26, 2010 10:05 pm    Post subject: Reply with quote
I had to have several cracks welded up recently. Mine were packed up with mud but they didn't look too bad when they were cleaned up for the welding.
They are the only syncro subaru conversion header available so...
purplegodzilla
purplegodzilla is offline
PostPosted: Sat Nov 27, 2010 7:00 am    Post subject: Reply with quote
In salty conditions it would still rust. Have you tried cleaning it with naval jelly?
1995 Eurovan Camper (SOLD)
1971 Westfalia (SOLD)
1991 Westfalia (SOLD)
http://i123.photobucket.com/albums/o292/purpleGORILLA/P1020720.jpg
1985 Westfalia
insyncro
Banned
insyncro is offline
PostPosted: Sat Nov 27, 2010 7:11 am    Post subject: Reply with quote
Not sure which Subaru engine you have but.......
Next week I will have a complete, stainless, made in the USA replacement exhaust system for the SVX EG33 motors that have been transplanted into Vanagons.
It is a three piece header system.
If any of the parts crack....only that part needs to be replaced, not the entire header.
This system will work with RMW and Small Car parts.
The factory skid plate on the Syncro, if fabricated to ft with the Small Car mounts will be able to be retroed to work with this system very easily.
Pictures, installation pictorial and pricing will be available shortly.
The manufacturer is considering a lifetime warranty on these products.
I will keep you posted.
dylan
syncrodoka
PostPosted: Sat Nov 27, 2010 9:38 am    Post subject: Reply with quote
I am running a EJ series motor but it is good to hear that there is another player in the field anyways- everyone benefits from friendly competition. Smile
insyncro
Banned
insyncro is offline
PostPosted: Sat Nov 27, 2010 10:14 am    Post subject: Reply with quote
Small Car EJ headers seem to hold up better than the SVX headers.
I don't think there are any EJ headers in the works yet, but I will check and keep everyone posted.
dylan
j_dirge
j_dirge is offline
PostPosted: Sat Nov 27, 2010 11:43 am    Post subject: Reply with quote
dylan
I'll be looking for more on this when the system comes available.
Keep us posted.
thx.
jim
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
Franklinstower
PostPosted: Sat Nov 27, 2010 5:19 pm    Post subject: Reply with quote
dylan
what i am looking for is a tuned, equal length header for the EJ 2 port heads. I was thinking about picking up an OBX header and modifying it to fit the vanagon. A tuned header can easily at 5 - 10hp to a stock Subaru engine.
http://www.sparktecmotorsports.com/h10798s.html
Paul
YITB
Vango Conversions
PostPosted: Sun Nov 28, 2010 12:10 am    Post subject: Reply with quote
Vanaru and I are installing a new made in the USA (by Hans) stainless exhaust header and J pipe on our EJ25 installs. They aren't available for sale alone currently but they're included in the conversion. They're fairly new so there aren't too many miles racked up on them yet but the Stainless is heavier gauge and they're jigged up propperly so you don't need to pry them onto the engine like the small car ones so there shouldn't be the same kind of cracking issues. Time will tell how they hold up but so far so good.
vanaguy
vanaguy is offline
PostPosted: Sun Nov 28, 2010 1:27 am    Post subject: Reply with quote
I've got about 3,000 miles on one of Vanaru's prototypes, and it's been great.
It's thicker, heavier metal, and it went on super easily and is a little quieter than the SmallCar P.O.S. it replaced- the SC one made a sort of whooshing sound on acceleration and Vanaru's does not.
I haven't had a chance to drench it in a salty, slushy winter, but it has certainly not become a sodden, discolored, cracked & rusty mess the way my SC one had after just a few thousand miles.
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Mar 27, 2011 10:18 pm    Post subject: Reply with quote
Status on the Hans wonder headers?????
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Vanagon All times are Mountain Standard Time/Pacific Daylight Savings Time
