Stock cooling tin with "J" pipes?
Saggs
Saggs is offline
PostPosted: Tue Jun 27, 2006 12:39 pm    Post subject: Stock cooling tin with "J" pipes? Reply with quote
I have a stock 1600 sp w/ dual carbs I'm building. It currently has all the stock tin w/ a dog house. The heater boxes are junk and I won't be needing them as I only run it in the summer. Question is, with the "J" pipes taking the place of the fatter heater box, do I need some extra tin to cover the large gap left where the heater box was? Didn't know if this large gap would affect cooling ability of the engine?
"One man can make a difference...Jesus did."
6D2
SBS Hit Squad
6D2 is offline
PostPosted: Tue Jun 27, 2006 1:05 pm    Post subject: Reply with quote
Im running a 1600 dp. I replaced my heaterboxes about a month ago with j-tubes. it seems to run better then before and I didn't add any extra tin. the freakin heater boxes weigh a ton.. I think one of those is as heavy as my whole new exhaust.. (single tip monza)
Chris
The SBS #62
Red Hot Ad Specialties & Stuff...
Shirts and hoodies for shows or clubs.. we ship world wide...
www.pottymouthpromos.com
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
TinCanFab
TinCanFab is offline
PostPosted: Tue Jun 27, 2006 1:43 pm    Post subject: Reply with quote
if you have the tin you should run it. some j tubes have tabs that hang off of them to attach the tins. the ones i see look like 2 skinny strips of sheet metal a couple inches long.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jun 27, 2006 2:06 pm    Post subject: Reply with quote
You need 73 Thing lower tins.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
GregZA
GregZA is offline
PostPosted: Tue Jun 27, 2006 3:29 pm    Post subject: Reply with quote
Hey Glenn,
you wouldn't happen to have dimensions on those would you?
They look easy enough to fabricate, but it would be much easier if one knew what sort of dimensions will actually fit.
I take these are for a 73 with a gas heater setup.
It seems these bits of tin would be most useful to a lot of us who are no longer running the std heater setup and certainly much more useful in terms of cooling than just bolting the j-plates to the j-tubes.
Cheers
Greg
BTW is there anything you don't have pictures of? Razz
Saggs
Saggs is offline
PostPosted: Wed Jun 28, 2006 11:20 am    Post subject: Reply with quote
Looks like Glenn is on the money...again. I think I'll fabricate a pair for my motor. This would also keep the thermostat running properly I think. Here's another question. Does the later stock doghouse thermostat have a longer stroke than the earlier-non doghouse setup? Was wondering cause my doghouse flaps need like twice the travel on the actuator rod to open them than do the earlier air flap setup??? Any ideas??
Mr. 010
Glenn is offline
PostPosted: Wed Jun 28, 2006 11:38 am    Post subject: Reply with quote
Gene Berg sells copies called "Industrial Shields" I think the part numbers are GB-4700R and GB-4700L.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bren
Bren is offline
PostPosted: Sun Feb 17, 2008 7:15 am    Post subject: Reply with quote
Does anyone else carry these tins? Berg does not seem to have them on their site anylonger?
Any one have dimensions for these? They look easy enough to make.
1967 Beetle, 1971 Bay Window Westy, 1972 Super Beetle, 1970 Drag Beetle, 1976 Porsche 912E
www.thegoodvolks.com
www.us131msp.com
Sigurd
Sigurd is offline
PostPosted: Sun Feb 17, 2008 8:17 am    Post subject: Reply with quote
http://www.geneberg.com/advanced_search_result.php?keywords=industrial&x=0&y=0
The top two items. 7400L and R.
Sigurd
Sigurd is offline
PostPosted: Sun Feb 17, 2008 8:20 am    Post subject: Reply with quote
Yes. Got this from one of Glenn's posts.
That's what I thought. I'm planning on doing it when I build my 1915 with Sidewinder.
128vw
128vw is offline
PostPosted: Sun Feb 17, 2008 10:17 am    Post subject: Reply with quote
I think you should check your measurments. One side is a different length than the other, otherwise the same. So I found out as I made a left and right as mirror of each other and one fit and one was too short.
spanky324
spanky324 is offline
PostPosted: Sun Feb 17, 2008 10:21 am    Post subject: Reply with quote
GB 7400R and GB7400L I just ordered them yesterday 51.00 delivered to your door!!
Sigurd
Sigurd is offline
PostPosted: Sun Feb 17, 2008 11:46 am    Post subject: Reply with quote
So which side corresponds to the measurements posted above? What are the new ones?
Bren
Bren is offline
PostPosted: Sun Feb 17, 2008 6:15 pm    Post subject: Reply with quote
$51. Wow, that seems expensive!
Has anyone got dimensions for both sides?
Seems to me I could make these up much cheaper. Having dimensions would help. Though I bet they could be fabbed up without them if necessary.
Anyone made their own yet?
www.us131msp.com
Mr. 010
Glenn is offline
PostPosted: Sun Feb 17, 2008 8:21 pm    Post subject: Reply with quote
I'm away from home for a few day, but give me time and i'll draw up the other one.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Sigurd
Sigurd is offline
PostPosted: Sun Feb 17, 2008 9:00 pm    Post subject: Reply with quote
That would be great, Glenn. Thanks!
spanky324
PostPosted: Mon Feb 18, 2008 7:40 am    Post subject: Reply with quote
Sorry it is 41.52 not 51.00(33.00 plus shipping)
Bren
Bren is offline
PostPosted: Mon Feb 18, 2008 10:09 am    Post subject: Reply with quote
Thanks for the clarification. Still seems high.
I will wait for Glenn's other drawing and try my hand at making my own. Can't be that difficult.
www.us131msp.com
vwracerdave
vwracerdave is offline
PostPosted: Mon Feb 18, 2008 12:47 pm    Post subject: Reply with quote
I bet the drawing is the same for both sides. You just flip the drawing over and bend them in the opposite direction.
Bren
Bren is offline
PostPosted: Tue Feb 19, 2008 8:39 pm    Post subject: Reply with quote
128vw tried making both to the same dimensions and one was too short according to his earlier post. Too cold in my garage to go verify!
www.us131msp.com
