Ollie W Samba Member
Joined: May 20, 2004 Posts: 844 Location: Portland, OR
Posted: Tue Apr 08, 2008 8:09 am Post subject: Rear bumper, splash pan and plates. |
Hey,
So I've got my bumper repainted. I bought some splash pans off the Samba and then I bought the install kit.
But I'm confused on where the backing plates go. Does anyone have a sketch or pic, even my Bentley manual didn't seem to help.
Thanks,
Chris |
Clara  Samba Member
EverettB  Administrator
Joined: April 11, 2000 Posts: 71523 Location: Phoenix 602
dreadnotmusic Samba Member
Joined: March 04, 2003 Posts: 880 Location: Guam, USA
Posted: Fri Feb 26, 2010 5:25 pm Post subject: |
The link above doesn't seem to work anymore.
I bought the splash pan install kit from WW and I can't figure out how in the world this "bracket" is supposed to go. Anyone have good pics of it? _________________ 66 Riviera |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Fri Feb 26, 2010 5:36 pm Post subject: |
It goes inside the corner.
dreadnotmusic wrote: |
I bought the splash pan install kit from WW and I can't figure out how in the world this "bracket" is supposed to go. Anyone have good pics of it? |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Fri Feb 26, 2010 5:38 pm Post subject: |
Like this?
_________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Fri Feb 26, 2010 5:48 pm Post subject: |
I got that far, and it's actually installed already. I have these two small brackets from the WW kit left over. The are angled as if they go in the corner in between the splash pan and body.
Also, is there supposed to be a bit of weight on the corner body bolts? I had to pull the corners of the bumper up a bit to get the bolts started. I don't want to stress the holes in the body.
Edit.....Mink, if I read you correctly you mean it goes on the inside of the body, effectively strengthening the mounting area? _________________ 66 Riviera |
Posted: Fri Feb 26, 2010 5:54 pm Post subject: |
Edit.....Mink, if I read you correctly you mean it goes on the inside of the body, effectively strengthening the mounting area? |
Yep, from the M8 bolt down to the smaller one at the very bottom of the corner. Kind of hard to explain, but pretty obvious if you look inside the corner. |
Posted: Fri Feb 26, 2010 5:56 pm Post subject: |
I get it now...and you're right. It's pretty obvious
Thanks much. _________________ 66 Riviera |
mstephens28 Samba Member
Joined: September 28, 2013 Posts: 49 Location: Bakersfield, CA
Posted: Sat Feb 21, 2015 3:49 pm Post subject: |
Does anyone know what the small, round seals that come in the WW splas pan kit are for? They look like the could fit in the smaller, bottom hole in the reinforcement bracket, but of course there is a bolt that goes there. I'm stumped. |
Posted: Sat Feb 21, 2015 10:29 pm Post subject: |
Got it, thanks! |
Posted: Fri Sep 13, 2024 5:58 pm Post subject: Re: Rear bumper, splash pan and plates. |
This is funny, I was just searching for a topic on how the whole rear bumper goes together as I'm putting my new 67 DC back together and I find that it's a thread I started the last time I didn't know what I was doing! |
