Where to get a relief valve reamer?
74 Thing
74 Thing is offline
PostPosted: Fri Apr 18, 2008 3:40 pm    Post subject: Reply with quote
How do you replicate that counter sink-just use a 10mm drill bit?
Jimmy111
Jimmy111 is offline
PostPosted: Fri Apr 18, 2008 4:05 pm    Post subject: Reply with quote
I dont remember, Ill check. I think it was a 10mm.
Clatter
Clatter is offline
PostPosted: Fri Apr 18, 2008 4:27 pm    Post subject: Reply with quote
Sweet! Very Happy
How much for a tool with the correct bevel?
Bus Motor Build
It does not exist!
Clatter
Clatter is offline
PostPosted: Tue Apr 22, 2008 10:10 am    Post subject: Reply with quote
Bump! Very Happy
Bus Motor Build
It does not exist!
nsracing
nsracing is offline
PostPosted: Tue Apr 22, 2008 10:13 am    Post subject: Reply with quote
You should not need to re-countersink it. All you are doing is re-surfacing that a tiny bit. 0.001 - 0.002 inch should be plenty to clean up.
You are not trying to mill it down, are ya? Very Happy
Clatter
Clatter is offline
PostPosted: Tue Apr 22, 2008 10:27 am    Post subject: Reply with quote
Nick, you can make one?
How much?
The people want to know!
Bus Motor Build
It does not exist!
nsracing
nsracing is offline
PostPosted: Tue Apr 22, 2008 10:31 am    Post subject: Reply with quote
How much?
I can make a production run. But if you are in a hurry, I cannot help ya. Very Happy
What should be a good price for them if done in HSS? Input guys. Input!
It can be done in several configurations..even with replaceable carbide bits.
Clatter
Clatter is offline
PostPosted: Tue Apr 22, 2008 10:33 am    Post subject: Reply with quote
As far as i can tell, we want a 4-flute end mill.
Long shank.
Preferably with the sides a little dull, maybe polished/broken edges.
Plus a stop, (collet stop?)
The stop was knurled, so you could grab it pretty good.
Sticking a thou or two feeler gauge in for to set the depth of cut,
then turning by hand cleaned 'em up pretty nicely.
A pro machinist might have a good relationship with tooling suppliers, and get a deal, right? Very Happy
Can't remember, but think it should run about 50-60 bucks, maybe? Question
Bus Motor Build
It does not exist!
Clatter
Clatter is offline
PostPosted: Tue Apr 22, 2008 10:35 am    Post subject: Reply with quote
because we are taking off just a little (hopefully),
and a little more oil pressure can be a good thing for some of us....
Maybe no need to go for the taper, right?
Bus Motor Build
It does not exist!
Jimmy111
Jimmy111 is offline
PostPosted: Tue Apr 22, 2008 10:58 am    Post subject: Reply with quote
I thought I sent you a PM. Well you should use a 3/8" or 1/2" drill for the taper. You want it to be about 11 mm in diameter. The bigger the diameter the lower the pressure required to open the valve. If you cant find a tool. Just go to the local auto parts supply house and buy some 100 and 400 sticky back sand paper. You just need one sheet of each one. Cut a piece of 100 grit that is the size of your piston. (16mm) stick it to the end of the piston and drop the piston in the hole. Use a wooden dowel that will barely fit in the hole in the back of the piston and rotate the piston to clean the surface. After it is smooth use the 400 grit and do the same thing. It takes a long time but works well. A tool would be better but if you are in a pinch.
Nick. what he said would work fine but make it more of a grinder than a cutter. A 6mm pilot might be good too.
SRP1
SRP1 is offline
PostPosted: Tue Apr 22, 2008 11:19 am    Post subject: Reply with quote
Guys, theres more to this than just resurfacing the seat face. The bigger problem is the case bore, think of it as piston to cylinder clearance. When the bore wears out the piston becomes sloppy, it starts to rock in it's bore and can either hang up on an edge due to wear or just become plain sloppy allowing pressure to simply bypass the piston.
This becomes particularly evident at idle and slow speeds when pump speed is low, causing your warning light to come on.
This is the case for both the bypass and relief pistons, and why the PRV conversion to a ball works so well. The seat pressed into the case has the proper surface impressed into which the ball seals too. It's a perfect seal and never wears out.
Back before the ball idea, the hot ticket on the old cases was to ream the bores to fit a new oversize relief piston giving everything a fresh start.
Another on topic concern is the replacement pistons, the majority of aftermarket pistons I come across are under size to start with, not good on a fresh rebuild.
Jimmy111
Jimmy111 is offline
PostPosted: Tue Apr 22, 2008 11:24 am    Post subject: Reply with quote
I agree with you 100% But the parts just arent available to the average person....
Do you have any photos of that ball valve? Ive been trying to find one that I didnt have to buy Very Happy To take a look at but no luck yet...
SRP1
SRP1 is offline
PostPosted: Tue Apr 22, 2008 11:34 am    Post subject: Reply with quote
PRV conversion parts are available to the average joe. I would offer them as I use them in every engine I build, however I can't take credit for it. Adrian at headflow designed it, it's his product and his idea, call him up.
Just for the record it was Adrian who designed this for Mr.Bergmann.
Headflow masters
760-727-1827
Clatter
Clatter is offline
PostPosted: Tue Apr 22, 2008 12:51 pm    Post subject: Reply with quote
I just ordered the kit from Adrian.
$95
Will report back...
Bus Motor Build
It does not exist!
Clatter
Clatter is offline
PostPosted: Fri May 02, 2008 1:45 pm    Post subject: Reply with quote
Check it out...
Still have to install it, though.
How do think it will work?
It has the hole all the way through, like the side shown here, only without the ID chamfer (sp?).
Bus Motor Build
It does not exist!
nsracing
nsracing is offline
PostPosted: Fri May 02, 2008 2:49 pm    Post subject: Reply with quote
How much for those two pieces of steel? $115!!! Holy Cow! Laughing
Maybe I can start producing those for $50
[email protected]
roy@mofoco.com is offline
PostPosted: Fri May 02, 2008 2:50 pm    Post subject: Reply with quote
Nick is 100% right, I use the 4 flute end mill on every engine we build or rebuild and have never countersunk that before. I have never had a problem with the last 500 engines I've done that to.
Jimmy111
Jimmy111 is offline
PostPosted: Fri May 02, 2008 3:17 pm    Post subject: Reply with quote
That is for a type 4. It will work in a type 4 but I cant see it working correctly in a type 1.
Yes, Nick is correct if only a very small amount is milled off. The problem is when the entire Countersink Shocked or a good portion of it is milled off.
Tvättbjörn
Tvättbjörn is offline
PostPosted: Sat May 03, 2008 9:21 pm    Post subject: Reply with quote
Yes, Nick is correct if only a very small amount is milled off. The problem is when the entire Countersink :shock: or a good portion of it is milled off.
Why not on a T1 ??
lostinbaja
lostinbaja is offline
PostPosted: Sun May 04, 2008 4:45 am    Post subject: Reply with quote
You are not only paying for 2 pieces of steel, you are paying for the R&D time to develop them as well. Making copys and undercutting them on the price is a good way to stop people from sharing their developments and stagnate the hobby.
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
Page 2 of 4
