Steve Tims Stage 1
Stanw3
Stanw3 is offline
PostPosted: Thu May 08, 2008 6:37 am    Post subject: Steve Tims Stage 1 Reply with quote
These arrived yesterday - they couldn't look any better!
View user's profile Send private message MSN Messenger Facebook Gallery Classifieds Feedback
purity
purity is offline
PostPosted: Thu May 08, 2008 6:41 am    Post subject: Reply with quote
How much, and where can i get heads ported by Steve Tims?
- '67 1300 (Original)
- '71 1302 (Daily driver, TIV-engine going in)
Stanw3
Stanw3 is offline
PostPosted: Thu May 08, 2008 7:08 am    Post subject: Reply with quote
http://www.thesamba.com/vw/classifieds/detail.php?id=185137
veedubcrazy
veedubcrazy is offline
PostPosted: Thu May 08, 2008 7:09 am    Post subject: Reply with quote
Good folks to deal with. Those heads look great and should work very well for your application.
1967 Deluxe Sedan
1971 Squareback - "The Silver Surfer"
rustfree1967bug
rustfree1967bug is offline
PostPosted: Thu May 08, 2008 7:36 am    Post subject: Reply with quote
Iv'e always been wondering this, why do most of the performance heads i see have the blue paint around the ports?
'70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu May 08, 2008 7:39 am    Post subject: Reply with quote
I have a pair of Stage 2s and that are awesome.
Mine did have to be taken apart to add shims to correctly set the spring pressure.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Jimmy111
Jimmy111 is offline
PostPosted: Thu May 08, 2008 8:38 am    Post subject: Reply with quote
It is not paint. It is layout dye. It is used to mark where they are going to cut without scratching the surface of the material. It washes off eaisly with alcohol so it you make mistakes, you just wash it off and scribe again. If you scribe the part, it is difficult to remove the scribe mark.
Stanw3
Stanw3 is offline
PostPosted: Thu May 08, 2008 8:54 am    Post subject: Reply with quote
Glen - with new springs I didn't know spring pressure could be an issue. How do I check this??
stoneloco808
stoneloco808 is offline
PostPosted: Thu May 08, 2008 9:16 am    Post subject: Reply with quote
Are all of the valve stem hieghts the same? The best way to check is with a straight edge/ruler laid on all of the valve stems.
vince1
vince1 is offline
PostPosted: Thu May 08, 2008 9:24 am    Post subject: Reply with quote
I had a pair of tims stage 1 on my 1775 bus engine, top heads ! Very Happy ,
they'll go on my next 2074 engine I'll buid this summer since I had to tear down my 1775 because I cracked my case on the rear hanger monting bosses Laughing Laughing ... maybe these heads makes too much HP?? Shocked Laughing
You can find flow charts of my (your Wink ) heads here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=241726
Here is a small video of my engine :
http://fr.youtube.com/watch?v=DDzosC0peQ0
Hope your engine will work as well as mine worked Wink
my French blog https://vwpanelvan.wordpress.com/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ... Wink
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
Bashr52
Bashr52 is offline
PostPosted: Thu May 08, 2008 10:34 am    Post subject: Reply with quote
OK I gotta ask, what exhaust do you have on that thing? It sounds like an 8 cylinder from the inside of the bus.
vince1
vince1 is offline
PostPosted: Thu May 08, 2008 10:44 am    Post subject: Reply with quote
Bugpack street max 1"5/8 header and A1 dynomax muffler, will change for a sidewinder this winter Wink
Other pics by clicking on my "gallery" button Wink [/img]
71sbeetle
71sbeetle is offline
PostPosted: Thu May 08, 2008 10:48 am    Post subject: Reply with quote
woah pas mal !!!! je trouve que les bay windows sont tres populaires en France !
vince1
vince1 is offline
PostPosted: Thu May 08, 2008 1:10 pm    Post subject: Reply with quote
Yes, especially early-bays, for those who use them as daily drivers like I did, they're much more convenient than splittys.
I love my DD panelvan, even if it's ratty... for the moment...
and BTW your French is "parfait" Wink
71sbeetle
PostPosted: Thu May 08, 2008 3:31 pm    Post subject: Reply with quote
yes I was looking at the pics, I am (was !) not a big fan of bay windows (they're ok but that's it) but now that I have seen yours, I know they have potential if they are done right. I love the way yours looks !
oh and I was raised in Tahiti, lived there for 20 years Smile
Stanw3
Stanw3 is offline
PostPosted: Thu May 08, 2008 6:58 pm    Post subject: Reply with quote
The heads are for my 2110 I'm building for my 61 DD bus. Here's the specs:
New AS41 Magnesium Case
*full flowed
*stroker clearanced
*cut for 90.5's
*8mm case savers
*dual relief oil plungers
New 4340 82mm Crank
*Magna Fluxed
*Shot Peened
*Precision Ground
*Micro-Polished
*Nitrided Journals
*RC60 hardened journals
*Spg 8 dowelled
*Dynamic Balanced by DRD
*Dyno tested to over 200hp, and race proven
CB Performance I Beam Connecting Rods
*forged 4340 I beam rods
*5.4 length
*Real 3/8 8740 ARP bolt
*Big end is honned to spec by DRD
*balanced end to end
Mahle 90.5 Pistons and Cylinders
*balanced at Edwards Engines ABQ
DRD 1.4 Solid Rocker Shafts
*Bronze bushed rocker arms
*hd stud set
*shim kit and lash cap set
*Rocker arms are drilled for proper oiling to the shafts
*Dyno test to over 200hp
Engle FK7 Cam
*Stroker Clearanced
*0.500" lift with 1.4's
*244º Duration at .050"
Steve Tims Stage 1 Oval Port Heads
*043 Mexican Castings with 3/4 reach plug holes
*Stainless Steel 40 x 35.5 Valves
*Dual Valve Springs
*Chromoly Retainers
*Professional Multi angle Valve job.
*Hand ported intakes, exhaust and a true ported combustion chamber area
Entire rotating assembly balanced at Edwards Engines in ABQ
Mallory Unilite Dizzy
*Grey/Grey Springs
*12 initial/32 full
DTM Shroud
*Type 4 Oil Cooler
*Porsche Gen Pulley
Dual Dell 40's
*34 Venturis
*CB Update Kits
Exhaust
*1.5" merged header
*Magnaflow Muffler
Assembly begins next week. Smile
vince1
vince1 is offline
PostPosted: Thu May 08, 2008 11:32 pm    Post subject: Reply with quote
Very good combo Wink
Maybe you could post some pics of the building?
I'll build near the same engine this summer Wink exept:
78 crank
92 thick walled P&C's
same rods
same rockers
Dual Lobe cam Fk43 intake/Fk7 exhaust on 108°LC
same carbs with 34 vents
I hope you'll enjoy your future engine Cool
viNce
71sbeetle
PostPosted: Fri May 09, 2008 8:39 am    Post subject: Reply with quote
looks like a good combo. One thing though I would do personally next time I build or have an engine built is have Jake Raby balance it. It's not that much when you think about it !
Stanw3
Stanw3 is offline
PostPosted: Fri May 16, 2008 2:45 pm    Post subject: Reply with quote
Just a little update:
Yesterday I realized that my valve stems are not all the same height. On one head - one exhaust valve is shorter than the other 3 stems. n the other head, one exhaust and one intake (in different cylinders) are shorter. I called Greg - he said that they don't pay attention to that - I could have them milled down to match if I wanted but it really doesn't matter. Rolling Eyes Aditionally, I cc's the heads last night to find this:
Head #1
57.5 cc
58 cc
Head #2
59 cc
60 cc
Am I asking too much for the cc's to be the same? I realize I could open them up more - but I'm not a head porter - that's why I paid to have them done - I'll screw them up. They look beautiful and the porting looks great - but the details here are killing me.
What do you guys think - Am I asking too much for $600?
thetravman
thetravman is offline
PostPosted: Fri May 16, 2008 4:06 pm    Post subject: Reply with quote
Those numbers boil down to plus or minus 2cc's. Someone correct me if I'm wrong but on the engines that these heads are made for, it probably will make little to no noticeable difference. I have no experience although I have held those heads in my hands. On a 1915 or 1776, it may be too small a difference to tell.
Have your car serviced at your local aircooled repair shop today.
/=O=\ good ole swing axles
