Rear Bearing Assembly?
Page: 1, 2, 3, 4, 5  Next
midnyter
midnyter is offline
PostPosted: Tue Apr 26, 2005 5:01 pm    Post subject: Rear Bearing Assembly? Reply with quote
ok ive been working on this for a couple of days, i had to replace the axle and had problems taking out the old bearing well thats all done now and im installing the new bearings and i forgot how it all goes back together i took a pic of what i have.. if im missing any of it please let me know i havent put it all together but from what i think i can remember it goes 2-3-6-4-1 from the axle tube to the drum, i dont remember pulling any rubber o-rings out when i took it apart but that came in the kit of seals and gaskets for the axle so i dont know where they go..
1964 Bug "Christine"
R.I.P. 1964-2006
Whyyyyyyyyyyyyy?
hazetguy
hazetguy is offline
PostPosted: Tue Apr 26, 2005 6:03 pm    Post subject: Reply with quote
#2 goes on the axle first, behind the bearing. it should have a tapered inside, and that goes up against the axle. the flat side is what hits the bearing. you'll know if this is on wrong, because the spacer will not butt up to the axle and there will be a space between it and the axle.
then #6 bearing goes on.
then #4 ring goes on the axle, against the bearing.
then #5 o-ring goes on the axle, up against #4. make sure the o-ring is not twisted.
?? there may be a paper gasket between the bearing housing and the backing plate, behind the backing plate.
(backing plate goes on, maybe here)
?? i think there should be a paper gasket installed before the #7 o-ring. don't use silicon on the gasket, use gaske sealant like gaska-sinch or permatex high-tack.
#7 goes around the bearing.
#3 spacer goes inside the bearing housing with seal (#1) with the tapered side, the side showing in the pic, facing the bearing. lightly oil the lip of the seal and the spacer before installing it in the seal. slide all that on as a unit (the bearing housing and spacer) with the drain hole (you did clean that out, right?) facing downwards, making sure the spacer does not pop out of the seal and that the spring in the seal does not pop out.
torque the 4 retaining bolts.
then put the drum on and torque it so squish the #5 o-ring BEFORE adding gear oil.
i took this pic out of a service manual, based on the type of bearing cover you have. hope it helps.
midnyter
midnyter is offline
PostPosted: Tue Apr 26, 2005 8:42 pm    Post subject: Reply with quote
thanks bro. i put it all together a lil while ago hoping that i did it right and from your instructions seems like i did.. the only think im missing is #14 in the diagram you have. is this something that i can still buy or NOS only??
R.I.P. 1964-2006
Whyyyyyyyyyyyyy?
bill may
bill may is offline
PostPosted: Tue Apr 26, 2005 8:52 pm    Post subject: Reply with quote
64 dont use no.14 it has a large washer instead which is not shown in his illustration.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
hazetguy
hazetguy is offline
PostPosted: Wed Apr 27, 2005 7:55 am    Post subject: Reply with quote
Bill. i am not much of a type 1 guy, but i posted the pic i did based on his bearing cover. here's a pic of a later style as you describe, but there are differences in the bearing cover shape/design and that oil slinger washer you metnioned, from that of what is pictured in midnyter's original picture. maybe he has an earlier rear end in there?
both pics taken fom VW publications. the first dated 1963, the other one dated 1967 (stating for 1966 and newer vehicles).
bill may
bill may is offline
PostPosted: Wed Apr 27, 2005 9:01 am    Post subject: Reply with quote
this one above this post is 67 for sure. no drain tube in brake drum like first picture.
www.sv2s.com
SBS #100
midnyter
midnyter is offline
PostPosted: Wed Apr 27, 2005 9:06 am    Post subject: Reply with quote
I guess i have the later model then also my transmission has the later model throwout bearing. How can i tell what year my trans is from?
R.I.P. 1964-2006
Whyyyyyyyyyyyyy?
bill may
bill may is offline
PostPosted: Wed Apr 27, 2005 9:49 am    Post subject: Reply with quote
serial number on trans case.
www.sv2s.com
SBS #100
79SuperVert
79SuperVert is offline
PostPosted: Wed Apr 27, 2005 10:01 am    Post subject: Reply with quote
My 65 doesn't have that "early" oil slinger (#14 in first diagram) and my Bentley manual for 60-65 also doesn't show it for a 65.
OvalWindowBucket
OvalWindowBucket is offline
PostPosted: Sat May 17, 2008 5:19 pm    Post subject: Reply with quote
Do the bearing cap retaining bolts require a washer of some sort? I torqued to 43 ft./lbs without washers because it didnt have any when I removed the cap. What type of washer should I get if so? Any M10 washer? Lock washer, wavy washer, or flat washer?
Also, using later brakes on oval axles tube, do I need the oil deflector washer if im not using the oil slinger on the drums?
Wanted OG Basalt & Silver Beige interior panels for '63 Deluxe
http://www.thesamba.com/vw/classifieds/detail.php?id=1041828
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Sun Feb 20, 2011 8:45 am    Post subject: Reply with quote
So the #2 on my axle is wrong?
I do have some play...
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Snort
Snort is offline
PostPosted: Sun Feb 20, 2011 9:03 am    Post subject: Reply with quote
In your photo, your number 1 is the bearing cap which is the early style. See that small lip pointing up in the photo? That's a drip edge that directs any leaking oil into the #14 oil slinger.
Notice how the main seal comes all the way out to the edge of your bearing cap? Later style caps have extra material there which partially blocks the seal from view. That extra material is like a built-in #14 oil slinger, and along with a giant washer, direct the oil in the new style cap out the back side of the backing plate.
You need, or at least should have the #14 whacky looking oil slinger for your early bearing cap design.
Samba YardMan
PostPosted: Tue Feb 22, 2011 8:35 pm    Post subject: Reply with quote
#3 spacer goes inside the bearing housing with seal (#1) with the ...
I just did this.
I found that the #7 large should not go "around the bearing", but maybe inside the bearing cap (part#1). There is a small groove inside the bearing cap for it.
Small cylinder type spacer
Bearing
Bearing washer in axle seal kit
Small O-ring in axle seal kit
With bearing cap on floor a part number facing down,
Assemble Bearing cap with large flat spacer that looks like a washer
main seal from axle seal kit
Longer big tapered cylinder type spacer
large o-ring
then fit bearing cap unto bearing.
Snort
Snort is offline
PostPosted: Tue Feb 22, 2011 9:33 pm    Post subject: Reply with quote
I've had these photos sitting around for a while, now's as good a time as any to post them up. These are all Oval axle tube photos, yours will be nearly identical.
First the bare axle tube bearing recess.
Next the inner spacer.
Install bearing by tapping on the inner race.
Washer and small O-ring.
Outer bearing spacer.
Backing plate.
Large O-ring, hard to see on the early ones, they sit right in the backing plate space.
Paper gasket.
Bearing cap with seal installed.
Samba YardMan
PostPosted: Tue Feb 22, 2011 9:45 pm    Post subject: Reply with quote
Hmmmmm....
This is what I did on mine....Close up of the groove in the bearing cap that I though was to accept the large o-ring from the axle seal kit
I put the spacer in the bearing cap before assembly to ensure a good seal without messing up the seal
A clean assembly photo of the bearing cap, seal, spacer, o-ring located in the groove, and high tack gasket sealer to try and keep it dry...
Put some high tack sealer on the backing plate too.
Snort
Snort is offline
PostPosted: Tue Feb 22, 2011 9:58 pm    Post subject: Reply with quote
Your large O-ring is in the wrong location. In this drawing, it is number 11.
Samba YardMan
PostPosted: Tue Feb 22, 2011 10:05 pm    Post subject: Reply with quote
Thank you very much for that clarification....
bill may
bill may is offline
PostPosted: Wed Feb 23, 2011 4:58 am    Post subject: Reply with quote
do not install the washer that comes in todays axle seal kits.
they are too soft and deform causing the small o-ring to leak. assemble without it.#7 in illustration.
www.sv2s.com
SBS #100
tb03830
tb03830 is offline
PostPosted: Wed Feb 23, 2011 12:49 pm    Post subject: Reply with quote
My 64 has the Oil Deflectors. #14
"Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower.
Samba YardMan
PostPosted: Wed Feb 23, 2011 7:56 pm    Post subject: Reply with quote
IF they deform (get thinner) wouldn't that cause the axle nut to become loose (looser)?
Couldn't I just retighten after 1000 miles or something like that?
Page 1 of 5
