Should I paint the underside of my bug fenders body color?
Page: 1, 2, 3, 4  Next
DB
DB is offline
PostPosted: Thu May 29, 2008 1:23 pm    Post subject: Should I paint the underside of my bug fenders body color? Reply with quote
Greetings,
I have recently purchased a '64 Sea Blue beetle for a summer ride. The beetle was taken apart for paint 20 years ago by the PO and sanded down. It is a super nice original car that will be left in stock condition and put back together after paint. The car will be a super nice driver when complete, but the intent is not for a show car - I have too many others for that purpose.
My question is should I "black out" under the fenders and body wheel well areas, or should I paint the area body color? The fenders have no rust and look to have an old dealer undercoating - very thin application. Under this undercoating is the original Sea Blue paint, but this cannot be seen since it is under the undercoating. It would be a pain / costly to remove all this this, but I know the stock situation would be body color only. Since I am primarily a bus guy, I would like the opinion from bug owners on what is considered acceptable and looks good for a driver versus a show car. If I sold the car with blacked out wheel wells would this hurt the value of the car, or would you think I am a dope for not painting them body color when I have a chance to correct this detail? Thanks once more for your time and input to my question. I am sure to have a few more questions as I try to complete this project.
Kind Regards,
DB Smile
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu May 29, 2008 1:26 pm    Post subject: Reply with quote
As a buyer I would wonder what you were covering up with black paint.
Derek Cobb
Annoying
Derek Cobb is offline
PostPosted: Thu May 29, 2008 2:02 pm    Post subject: Reply with quote
I hate undercoating on old VW's cause 98.6% of the time it's used to hide stuff....bad stuff. It's also miserable to remove and just plain ugly. Cars with nice shiney paint under the fenders make me smile.
I would pay more for a car with no undercoating.
DM409
DM409 is offline
PostPosted: Thu May 29, 2008 2:11 pm    Post subject: Reply with quote
Dealer applied undercoating was very common on new VW's and it shouldn't hurt the value at all on a nice driver quality car. I'd go with undercoating on a car that is to be driven, but painted on a show car.
If by "black out" you are referring to black paint instead of undercoating, then I'd agree with KTPhil.
DB
DB is offline
PostPosted: Thu May 29, 2008 2:36 pm    Post subject: Reply with quote
Hi All,
Thanks for the feedback! Yes, "blacked out" would be black paint on top of the undercoat. The undercoat is very light and obviously isn't hiding anything. I am not sure if the undercoating could easily be sanded / DA'd (dual action) off or not. I think you have to chemically remove / soften it and turn it back into goo for removal. Any suggestions on easy removal? It is also on the body as well - which in that area is not flat or simple to clean-up.
Another option is I could do nothing and just paint the top side of the fenders. I wasn't sure in the bug world if keeping the OG paint under the undercoating is preferred to stripping them clean or not. If I strip them clean and repaint the underside, do you guys recommend putting a light stoneguard finish under the paint to reduce stone chips etc?
Regards,
DB
Russ Wolfe
Russ Wolfe is offline
PostPosted: Thu May 29, 2008 2:39 pm    Post subject: Reply with quote
Dealer applied undercoating now days is covering the rust.
This car supposedly only had 15,000 miles on it. See the rust under the undercoat.
Gary: OK. Ima poop.
Keith
Keith is offline
PostPosted: Thu May 29, 2008 2:42 pm    Post subject: Reply with quote
Oven cleaner removes undercoating and doesn't hurt original paint. I've used it before and the results were amazing. Just go to your Dollar store and buy the cheap "Heavy duty" oven cleaner.
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
DB
DB is offline
PostPosted: Thu May 29, 2008 3:11 pm    Post subject: Reply with quote
Thanks Ovalteen for the oven cleaner suggestion! I will try that out! This bug is really nice and is not hiding any rust like the posted picture above shows. I will try to take some pictures and post them showing the undercoating.
Cheers!
DB
paxilill
paxilill is offline
PostPosted: Thu May 29, 2008 7:24 pm    Post subject: Reply with quote
I would undercoat them myself, if it’s a driver. It's not like VW fenders are very complicated and can hide a lot of damage from any suspecting educated buyers down the road.
c.davis419
c.davis419 is offline
PostPosted: Fri May 30, 2008 11:49 am    Post subject: Reply with quote
Also, if your fenders are freshly painted and not undercoated, when driving at higher speeds your tires can kick up rocks that can dent them or crack the fresh paint. Ask me how I know about this Rolling Eyes
1967 beetle
1974 Thing
MURZI
MURZI is offline
PostPosted: Fri May 30, 2008 12:57 pm    Post subject: Reply with quote
I second this.....If you DRIVE it rocks will dent the fenders from the underside.
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
DB
DB is offline
PostPosted: Fri May 30, 2008 1:26 pm    Post subject: Reply with quote
Hi C.Davis,
Thanks for sharing your experience, and I am sorry about your paint job! Your situation is exactly why I am asking this question. The purist in me would like to paint the underside of the fenders and wheel well area. But the practical side of me says does anyone really care or does this really matter? A number of bug owners I have talked to have told me to leave it and black it out. If I painted the fenders body color on the underside I would apply a light stone guard under the paint to avoid your situation and road chips. Since the bug will be left at stock height you can still see a lot of fender wheel well area under there - I don't want it to look stupid if it is painted black. Luckily the contrast between Sea Blue and Black is not that big compared to a lighter color. I would still like a few more view points on body color paint only versus leaving the existing undercoat on and "freshen it up" with a coat of black paint. Thanks all for any input on this topic!
Kind Regards,
DB
Maimas13
Maimas13 is offline
PostPosted: Fri May 30, 2008 5:19 pm    Post subject: Reply with quote
you could always rhino coat the underisde of the fenders, this may be a little priceyer but it will definately protect the paint on top and it looks really cool, plus you could match/paint over the coating to make it really sick
MAIMAS... read it backwards
(.o\ ! /o.) 62 chopped, dropped, cal looked, oval grafted, 57 styled, ragtop with polk audio sound system, driven daily by an 18 year old
A must read for understanding tires sizes and wheel offsets
Go Bears!!! Mech E
65ruby
65ruby is offline
PostPosted: Fri May 30, 2008 7:27 pm    Post subject: Reply with quote
Check out my gallery... I just painted my 65 and was thinking about also putting color under the fenders,but after many discusions with my painter, as stated above, the rocks he said will "STAR" the paint Crying or Very sad
So we did strip all the old coating off the 1/4 panels and put color on them.
Then we removed the fenders and undercoated them only.So now IF you were to look under the fenders(you must get on all fours to see it) you will see the color on the 1/4's but the fenders have a black undercoating.
Standing from a distance you can only see the painted part of the 1/4 panels.
Scott Red Bug
Agave58
Agave58 is offline
PostPosted: Fri May 30, 2008 7:50 pm    Post subject: Reply with quote
If the car came with undercoating from the dealer, and is not going to be a show car then leave it. You might as well take advantage of the fact that the underside will fair better with the undercoating then regular paint.
Terry
1958 Beetle
Harrison
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Fri May 30, 2008 8:02 pm    Post subject: Reply with quote
Interesting... not one of the VWs I own or have owned have had this supposedly "common" dealer undercoating. The are all body colored. And none of them have dents from rocks, either... interesting...
-Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
Agave58
Agave58 is offline
PostPosted: Fri May 30, 2008 8:12 pm    Post subject: Reply with quote
I was wondering if undercoating was pushed by dealers in states that used salt for the roads? My 58 has no undercoating, and was sold new in New York?
Terry
1958 Beetle
Harrison
BUGTHUG
Samba's Rented Mule
BUGTHUG is offline
PostPosted: Sat May 31, 2008 1:06 am    Post subject: undecoating Reply with quote
Line-X, makes a great undercoating and they have differnt colors, they might be able to match any color.
A few years back, the owner of a line-X showed me a test they did, where they took two concrete blocks, painted one with line-X and left the other natural. They droped both blocks from 15feet onto the parking lot, the un-coated block shattered, and the coated one did't. They were starting to use this stuff for military aps.
It is strong stuff, and will probably out last the car Smile Its similar to the rhino stuff, you might check it out as an option.
I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1966 VW bug
1966 21 window micro bus
1969 Dune Buggy
1965 VW bug
1974 VW bug
1972 Kelmark, VW drive line
1948 Chevrolet Hearse
ocdbeetle
Samba Optimist
ocdbeetle is offline
PostPosted: Sat May 31, 2008 5:38 am    Post subject: Reply with quote
Terry
1958 Beetle
Harrison
I bet thats got a lot to do with it...Were most of your cars sold in the South Kent?
It would be interesting to see input on where cars were originally sold and if they had an undercoating...
1967 Lotus White Beetle
67 Florida Deluxe
Samba Purist
PostPosted: Sat May 31, 2008 5:56 am    Post subject: Reply with quote
ocdbeetle wrote:
Terry
1958 Beetle
Harrison
My former Zenith Blue '67 came from Iowa. From what I hear, it snows there occasionally. Notwithstanding that, I have looked at many, many cars for sale and only one had undercoating. It's not as common as one would be led to believe. Yes, it was pushed by dealers because it was a way for the salespeople and dealership to add to their income. However, keep in mind that these cars were the Subaru Justy of their time; essentially, a disposable economy car that wasnt usually prone to getting "extras". Perhaps, Russ, Bill or someone else who worked at dealerships back in the day could elaborate.
Page 1 of 4
