Looking for an old okrasa, abarth pic.....beehive cooler
Mark Henry
Mark Henry is offline
PostPosted: Sat Jun 14, 2008 4:39 pm    Post subject: Looking for an old okrasa, abarth pic.....beehive cooler Reply with quote
Looking for an old okrasa, abarth pic, the one with the EMPI beehive cooler/filter assembly.
I used to have it, done a search no luck....
Thanks!
'74 914, back on jackstands for a 3.0/6
'67 Bus 2007cc, Berg engine
'67 EMPI GTV bug w/ 102mm Nickies, massIVe bottom end, SDS FI, 2.6L T4 monster in the works
swanlakers
swanlakers is offline
PostPosted: Sat Jun 14, 2008 10:04 pm    Post subject: Reply with quote
https://www.thesamba.com/vw/archives/lit/56ghia/cover.jpg
Mark Henry
PostPosted: Sun Jun 15, 2008 5:41 am    Post subject: Reply with quote
That's my beehive! Couple of extras...bounus!
Thank you!
billmetric
billmetric is offline
PostPosted: Sun Jun 15, 2008 10:23 am    Post subject: Reply with quote
the Beehive filter coolers have been reproduced, a bit pricey though here :
http://cgi.ebay.com/ebaymotors/NEW-50s-styleHOT-RO...enameZWD1V
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
Mark Henry
PostPosted: Sun Jun 15, 2008 3:13 pm    Post subject: Reply with quote
You think they could have polished the ribs.
I wonder what a real one would go for?
Anyone know which canister it takes?
Agave58
Agave58 is offline
PostPosted: Mon Jun 16, 2008 1:38 pm    Post subject: Reply with quote
How do the "Beehive" coolers compare to the Frams?
Terry
1958 Agave Beetle (0\_!_/0)
Stateside Motors Inc
501 Foote Ave
Jamestown, New York 14701
Stateside Imported Cars/Motors Items Wanted
Sunland Motors
2030 Fremont St Las Vegas, Nevada
Sunland Motors Items Wanted
billmetric
PostPosted: Mon Jun 16, 2008 5:53 pm    Post subject: Reply with quote
the Beehive Filcoolator is much "cooler" with the fins, not as much cooling going on with a Fram
John Moxon Premium Member
John Moxon is offline
PostPosted: Tue Jun 17, 2008 3:22 am    Post subject: Reply with quote
The Fram doesn't make claims to be a cooler, it's simply a filter. Having said that you put more oil through the engine it will have a cooling effect.
My only reservation about the Beehive Cooler and the cooling spirals is that they will lower oil temperature but the heat extracted from both is channelled back through the fanhousing leading to higher head temperatures.
A sump extension will cool the oil without recirculating the extracted head back into the engine.
John.
vwovalguy
vwovalguy is offline
PostPosted: Sat Mar 28, 2009 8:34 pm    Post subject: Reply with quote
How much are the reproduction beehive coolers?
SGM
SGM is offline
PostPosted: Sun Mar 29, 2009 10:39 am    Post subject: Reply with quote
around $200....I've seen them anywhere from $199-$280 so search around. A few of the online hot rod stores have them.
Regards, Sean
jimmy1
jimmy1 is offline
PostPosted: Fri Apr 09, 2010 5:20 pm    Post subject: Reply with quote
Anyone sell hoses for those aftermarket beehives?
North Hollywood, CA
1956 Kabrolett
"I'd rather be driving my VW thinking about God than sitting in church thinking about my VW."
check out my classified ads, lots of rare parts/accessories for sale.
vwovalguy
PostPosted: Fri Apr 09, 2010 10:23 pm    Post subject: Reply with quote
Funny, as i was just talking with Steph about this http://www.thesamba.com/vw/classifieds/detail.php?id=946078. I have an original beehive, but don't know where to mount the darn thing.......I want it where the fram goes, but it's much bigger and it might hit my rain gaurds on my vert lid. Steph said he can make the lines for it because he has one also......he just needed to know where it would be mounted. I ordered the fram lines instead.
Can anyone recommend a good spot to mount a beehive filter/cooler?
jimmy1
jimmy1 is offline
PostPosted: Sat Apr 10, 2010 12:51 am    Post subject: Reply with quote
Maybe by the firewall? Dunno about dual carbs, but I should be ok with judson?
Keep me posted on steph. =)
North Hollywood, CA
1956 Kabrolett
Eric Outland
Eric Outland is offline
PostPosted: Sat Apr 10, 2010 8:32 am    Post subject: Eric (VMR) Reply with quote
The mounting bracket thats sold ( seperatly) with this Beehive looks shallow as far as mounting go's! Looks like in the Original Okrasa Picture the Beehive mounting bracket extended the cooler farther away from the fan shroud to allow the dual carb set up to function Properly.
Does anybody know what size the inlet and outlet fittings are for this cooler?
Steph
Steph is offline
PostPosted: Sun Apr 18, 2010 1:32 pm    Post subject: beehive filter Reply with quote
Fitting threads: 1/8 NPT.... normal it is US made
This is the correct thread for the original one but there is not reason to make an other one even on a repro
garagebandking41
garagebandking41 is offline
PostPosted: Fri Nov 22, 2019 12:02 pm    Post subject: Re: Looking for an old okrasa, abarth pic.....beehive cooler Reply with quote
Sorry to resurrect this thread, but the picture says this cooler adds 1.5 quarts to the oil capacity. I am about to use one of these on a 36hp rebuild and was wondering how to go about adding the extra oil? Do I just put in 2.5+1.5 quarts into the filler or should i open the beehive and add oil that way. Or do I add the standard 2.5 quarts and slowly add the extra amount as per the dipstick?
I'm guessing I soak the beehive filter first and see how much it soaks up - but 1.5 quarts seems excessive...any one have experience with one of these?
gatorwyatt
gatorwyatt is offline
PostPosted: Tue Dec 03, 2019 7:01 am    Post subject: Re: Looking for an old okrasa, abarth pic.....beehive cooler Reply with quote
I have a Fram on my Okrasa and during an oil and filter change I suck all the oil from the filter housing replace the filter and slowly add the additional oil to pre soak the filter. Then replace cover and continue with the standard oil change. Once done filling to mark on the dip stick run engine and recheck level. Should be the same for the beehive.
www.blastserv.com
wanted:
Nothing!
garagebandking41
PostPosted: Tue Dec 03, 2019 7:38 am    Post subject: Re: Looking for an old okrasa, abarth pic.....beehive cooler Reply with quote
Thanks for the advise wyatt. You blasted the case for me about 2 years ago! Laughing I hope to stop by soon with it running.
Peter_Plade
Peter_Plade is offline
PostPosted: Mon Sep 26, 2022 10:01 am    Post subject: Re: Looking for an old okrasa, abarth pic.....beehive cooler Reply with quote
Anyone ever started running one of these?
I’m a little confused as it says inlet at the bottom.
http://vw-bluehats.blogspot.com/
garagebandking41
PostPosted: Tue Sep 27, 2022 7:01 pm    Post subject: Re: Looking for an old okrasa, abarth pic.....beehive cooler Reply with quote
I run one of these. If I recall correctly there is small pipe that runs up the middle. Oil enters the side, fills the chamber, and moves forward through the filter media to the middle where it exits a small hole at the top of the pipe down to the return.
I get a lot of water in the cooler. Not sure if it "Sweats" a bit. I don't run the car very often so it could be that as well...I really enjoy that it is there.
