Ignition condenser 02170 being discontinued... they're back
Page: Previous  1, 2, 3
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Mar 11, 2008 8:11 am    Post subject: Reply with quote
Left to right:
Wolfsburg West repro - NOS Bosch - new Bosch 02170
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
rdwood
rdwood is offline
PostPosted: Fri Apr 11, 2008 1:59 pm    Post subject: Reply with quote
How often do condensers go bad? How can you tell?
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Apr 12, 2008 7:30 pm    Post subject: Reply with quote
Not all that often from my experience. Visuallly other than obvious can damage or insulation worn off the lead wire there is no way to tell.
Mr. 010
Glenn is offline
PostPosted: Sat Apr 12, 2008 7:35 pm    Post subject: Reply with quote
I'm running a 40+ year old condenser on my Bosch 010 on my 2180.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
virtanen
virtanen is offline
PostPosted: Sun Apr 13, 2008 3:09 am    Post subject: Reply with quote
You can measure the capacity by suitable gauge. If it is zero, your capacitor is dead.
PostPosted: Sun Apr 13, 2008 5:33 am    Post subject: Reply with quote
I've never had one that failed outright. I usually replace any non-Bosch ones.
billmetric
billmetric is offline
PostPosted: Mon Apr 14, 2008 4:11 am    Post subject: Reply with quote
I have had a couple go bad, the cars ran like crap, they must have been partially shorted internaly, once they were switched out with new ones the cars ran fine again, they had no acceleration but idled ok, I think the best bet is to change them out at least every 10 years, once the points have been filed down as many times as possible its time for a new condensor
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
Snort
Snort is offline
PostPosted: Sat Jul 05, 2008 8:29 pm    Post subject: Reply with quote
My first ever condenser failure just occurred. The wire separated from the lead in. Symptoms were as previously mentioned. The engine idled fine, but misfired when under load.
Mr. 010
Glenn is offline
PostPosted: Sat Jul 05, 2008 8:48 pm    Post subject: Reply with quote
Yup... that's the sign of a bad condenser.
Those yellow wire condensers are 40+ years old and you should not be surprised that it failed.
I'll have to make sure I carry a spare since I have a old condenser on my car.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
perello
perello is offline
PostPosted: Tue Jun 16, 2009 2:05 am    Post subject: Reply with quote
I've been always told that IF there is transfer of material at the points, from one electrode to the other, THAT is signal of a bad condenser?
I misunderstood something?
Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200
Page 3 of 3
