ofcdoug Samba Member
Posted: Mon Sep 01, 2008 5:56 pm Post subject: 72 Super popping out of reverse |
| my 72 S.B. is popping out of reverse. I know the shift rod bushing needs to be replaced but I dont think thats the problem. Any sugestions?? |
homeworld8118 Samba Member
Posted: Mon Sep 01, 2008 7:07 pm Post subject: |
| yea same hear in my 74 sb(but its a 73 pan + drive train). Its just fine in every other gear but quite often does it pop out when in reverse. If all's right in the world it actually goes in you can just feel the gears lock in but most of the time i doesn't feel like it. I always just assumed that the reverse gear wasn't in the proper alignment any more. I don't use reverse often so i never worried a whole lot about it with mine, but it would be nice to hear some info on the topic. |
BUGSTUFF Samba Member
Joined: October 20, 2004 Posts: 533 Location: Bartlett, IL
Posted: Mon Sep 01, 2008 7:29 pm Post subject: |
Hmm, our '72 Super does the same thing. Fluid was changed, bushing was changed, coupler was changed and the clutch cable was changed & adjusted to specs. Still does it so I'm assuming it's something internal. _________________ Kirk
Northeast IL VW Association - www.nivaclub.org
www.facebook.com/nivaclub
Volkswagen Club of America - www.vwclub.org |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Mon Sep 01, 2008 10:05 pm Post subject: |
If it's popping out of gear, and the shift linkage is aligned, you're gonna have get inside the trans, my friend. No external adjustments to be made.
Or swap it out for a fresher tranny. _________________ sent from a phone using poor grammar and spelling |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17700 Location: Left coast, Canada
Posted: Mon Sep 01, 2008 10:09 pm Post subject: |
Bob's right, the problem is inside the gearbox. On the late gearboxes, it is ALWAYS the small reverse idler gear that is worn out. Crappy metalurgy is the cause. It should be swapped out now instead of waiting, otherwise, you risk damaging the 1-2 slider as well. New late model 1-2 sliders are not available new. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Thu Sep 04, 2008 1:10 pm Post subject: |
Can the small reverse idler gear be replaced with the trans still in the car? I'm planning on doing an engine swap soon.
Hey ofcdoug, know anyone in the area who works on transmissions? _________________ Kirk
Bruce Samba Member
Posted: Fri Sep 05, 2008 12:06 am Post subject: |
| BUGSTUFF wrote: |
| Can the small reverse idler gear be replaced with the trans still in the car? |
Nope.
And you have to take the gearbox apart to do it. _________________
Terrispots Samba Member
Joined: August 05, 2008 Posts: 42 Location: Inwood WV
Posted: Sun Sep 21, 2008 9:24 pm Post subject: |
We had the same issue on our 74, a trans is inexpensive and was easy enough just to replace! We had some engine removal and reinstall issues, then a clutch issue, but all in all, I think it will be worth it. _________________ 74 Super Beetle
08 Scion xB RS 5.0 |
Lotrat Samba Member
Joined: December 08, 2007 Posts: 2528 Location: Vista, CA
Posted: Sun Sep 21, 2008 9:33 pm Post subject: |
| Reverse is the weakest gear. Someone said that you should always hold the stick in reverse to make it last longer and to prevent it from popping out... |
rterfert Samba Member
Joined: October 08, 2003 Posts: 1419 Location: Yuma Arizona
Posted: Sun Sep 21, 2008 10:47 pm Post subject: |
number 57 the brass gear carrier is probably worn
Holding it in reverse will only prolong the problem.
It's an easy fix, once you get inside the trans case
They do make a later steel version (if that's the case?)
the gear might just be toast. |
Bruce Samba Member
Posted: Mon Sep 22, 2008 1:12 am Post subject: |
| Lotrat wrote: |
IMO that will accelerate the wear on the reverse lever's fork. This will make it pop out of gear sooner than if you keep your hand off the shifter while backing up. VW specifically advises against holding onto the shifter while driving. You shouldn't hold ANY gear engaged while moving. _________________
Posted: Mon Sep 22, 2008 5:13 pm Post subject: |
If you are already going to have the engine out its only another 10 mins to pull the trans and it would be easier to work on. Set it up on the work bench for easy reach instead of working on it upside down. _________________ 74 Super Beetle
