bay window sunroof (deluxe model)
Trucker_Eric
Trucker_Eric is offline
PostPosted: Tue Oct 07, 2008 11:11 am    Post subject: bay window sunroof (deluxe model) Reply with quote
ok, i have a 1971 vw bay window deluxe with the large sunroof that needs repaired. can anyone walk me through how to do this, or point me in the direction of a topic that someone has already restored this part of the bus. i need to know the mechanics of the sunroof, i know the cables are there and everything, but i found some drain lines or something along those lines. please help!
VWMIKE76
VWMIKE76 is offline
PostPosted: Tue Oct 07, 2008 11:45 am    Post subject: Reply with quote
Nice ride! especially in florida! when the roof is open make sure to vaccum out the drain lines the best you can and then blow them out the rear ones drain into the battery tray, and the front ones drain out right behind the front wheels before the rocker panels, as for a good book check the bentley manual, I have noticed that some have the sunroof section and some don't so make sure its in there before handing over the cash. and keep them tracks clean and well lubed and your cables will last forever just take good care of them each year and they will take good care of you.
Mike
77 westy Mac n cheese aka "Mac"
71 crew cab "Damien" sold and missed lots!
78 westy "Doc". in very good hands of a fellow samba member!
79 hardtop landmark "Shaggy II"
Trucker_Eric
PostPosted: Tue Oct 07, 2008 1:11 pm    Post subject: Reply with quote
ok, so how do i fix the lnes if they are broken?
VWMIKE76
VWMIKE76 is offline
PostPosted: Tue Oct 07, 2008 1:12 pm    Post subject: Reply with quote
you mean the cables?
Mike
busdaddy
busdaddy is offline
PostPosted: Tue Oct 07, 2008 3:27 pm    Post subject: Reply with quote
Does anything move when you turn the handle? Does the handle turn? Is there anything jammed into the back to hold it up? Is there any screws or sealant visible on the outside?
Слава Україні!
Herbst '71
Herbst '71 is offline
PostPosted: Tue Oct 07, 2008 3:54 pm    Post subject: Reply with quote
Heed busdaddy's advice. Mine was filled with expanding foam.
Rik
'71 Deluxe/1600 DP
"Fortunately my mistakes are serving as a warning for others."
Trucker_Eric
PostPosted: Wed Oct 08, 2008 3:11 am    Post subject: Reply with quote
ok, we took out the whole system. when i turned the handle, the cables would lock up and they would start to curl up at the end.
