perello Samba Member
Joined: April 15, 2005 Posts: 888 Location: where social security comes for free
Posted: Thu Oct 23, 2008 1:24 am Post subject: 36hp oil coolers |
Hi
Trying to finish my okrasa setup, was wondering whether a standard oil cooler was used at the time or is worth installing an aluminum one (6mm studs) ...
any opinions? |
oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Thu Oct 23, 2008 5:09 am Post subject: |
if you have an origianl one in aluminium use them, but do not use a 356 one, wich down sizes the temperature on oil, but raises the heattemperature  _________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1276 Location: Lamorinda CA
Posted: Thu Oct 23, 2008 5:15 pm Post subject: |
oval56 wrote: |
if you have an origianl one in aluminium use them, but do not use a 356 one, wich down sizes the temperature on oil, but raises the heattemperature  |
Ok.. maybe its a language barrier.. or ?? "Down sizes the temperature on oil" what does that mean? Reduces the Temperature? Ive always used 356 Oil Coolers on 36hp engines and they do INDEED reduce the oil temperature over stock oil coolers. Explain please? _________________ DB
11/1966 Porsche 912
7/1968 Type 265 Double Cab
4/1955 Type 117 - 3 Fold |
oval56 Samba Member
Posted: Thu Oct 23, 2008 9:29 pm Post subject: |
52HoffmanSplit wrote: |
oval56 wrote: |
Ok.. maybe its a language barrier.. or ?? "Down sizes the temperature on oil" what does that mean? Reduces the Temperature? Ive always used 356 Oil Coolers on 36hp engines and they do INDEED reduce the oil temperature over stock oil coolers. Explain please? |
yes you are right, the oiltemperature will go down but the 356 oilcooler block the aircirculation in the fan shroud...so the cylinderheadtemperature rises! - overheatproblem on cylinder 3 /4
i do hat the problem on my second 57...
90°C oiltemp up tu 100°C at strong longtime runs... but an overheatproblem on cylinder3 with damage on only the head
after changeing to an standard vw cooler, oiltemp goes up to 100-110 deg
but no damages on my valves and head..
same topic discussed in pre67vw.co.uk some weeks ago, with same result
www.dbkvw.com |
Posted: Fri Oct 24, 2008 3:14 am Post subject: |
thank guys, this is becoming very informative  _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
EverettB  Administrator
Joined: April 11, 2000 Posts: 71515 Location: Phoenix 602
joe h. Samba Member
Joined: September 04, 2005 Posts: 782 Location: Seattle, Wa
Posted: Fri Oct 24, 2008 11:59 pm Post subject: |
Quote: |
I remembered I found this Behr oil cooler a while back |
Yeah, that's what I ended up buying. They seem smaller than the one pictured above. Perhaps the best of both worlds (oil temp and head temp) or should I just stay stock?
Braukuche Samba Member
Posted: Sat Oct 25, 2008 6:39 am Post subject: |
joe h. wrote: |
I will further complicate the issue by adding that I have two coolers, one a Porsche A cooler, steel with the mounting tab, and a VW one with a similar profile, it has a rounded top but no mounting tab. Is the round top VW one for an earlier model? Which is the best cooler to use?
--Dan |
Posted: Sat Oct 25, 2008 7:06 am Post subject: |
actually I am after a Behr unit...but before taking the steep price I wanted to know if it is worth it..... _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Sat Oct 25, 2008 7:54 am Post subject: |
Im not buying into Oval56's statements about NOT using a Porsche Alluminum Oil cooler and its drawbacks. A single word of mouth case is not technical data, his burn out of 3/4 could have been caused by many other things.
My brother (volksworker) and myself have successfully used the Porsche Alluminum oil cooler in 36hp engines since the mid-80's with 100% success and no 3/4 overheating problems.. and this is in the desert of Arizona!! I daily drove a 57 Oval Rag (even more engine heat in open ragtops)... 40hp Big Bore, with a Porsche Oil Cooler in Phoenix, thoughout the summers for 5 years and when you got done with long trips the engine was cool as a cucumber.
I think more discussion is warranted, Oval56's Opinion being taken into consideration... but his single failure is insufficient data to keep people from installing a period modification that has been happening since the 60's.... My opinion is that, if a Porsche Oil Cooler REALLY had that effect, it wouldnt be so ingrained in VW folkslore that they do such a great job, and that they were STILL so valuable at VW swapmeets/ebay etc. Severe failures would be constant... but that just hasnt happened. _________________ DB
11/1966 Porsche 912
Posted: Sat Oct 25, 2008 9:07 am Post subject: |
Braukuche wrote: |
I have two coolers, one a Porsche A cooler, steel with the mounting tab, and a VW one with a similar profile, it has a rounded top but no mounting tab. Is the round top VW one for an earlier model? |
The rounded top one is 25hp/early 36hp, if I remember correctly. _________________ How to Post Photos
oval56 Samba Member
Posted: Sat Oct 25, 2008 9:09 am Post subject: |
I think more discussion is warranted, Oval56's Opinion being taken into consideration... but his single failure is insufficient data to keep people from installing a period modification that has been happening since the 60's.... My opinion is that, if a Porsche Oil Cooler REALLY had that effect, it wouldnt be so ingrained in VW folkslore that they do such a great job, and that they were STILL so valuable at VW swapmeets/ebay etc. Severe failures would be constant... but that just hasnt happened. |
okay, the other way, 8000km with 356 oilcooler- before complete rebuilt engine AND heads, ignition 8° static, mainjet driven on dyno...., 8,5:1 compression ratio
8000km, problems on third cylinder..
after rebuild the head again, 18000km, no problem with any valve or head..
i do not say that the cooler of a 356 is a bad thing, but in my case , the airstream is lower becaus the surface of the 356 cooler is bigger than a stock cooler
if i would do it again, i would modifiy a stock fanshroud with a dog house shroud, and would use the adapter tu us a 356 cooler (356B or 912 type) in a doghous conversion...
and here the discussion in a other forum: http://forums.pre67vw.com/Default.aspx?g=posts&t=16265 _________________ www.oval56.com
www.dbkvw.com |
Posted: Sat Oct 25, 2008 11:05 am Post subject: |
oval56 wrote: |
...., 8,5:1 compression ratio |
ahh 8.5:1 Compression when a Stock 36hp is supposed to be 6.6:1?? You dont think that had anything to do with your car running hot?
For 45 years... American VW afficianados have used Porsche 356 Coolers on their engines to good effect.. there exists no information except your post that says it is a bad idea.... so.... try not to be so alarmist in your posts, yours is one experience... and frankly I think I just found out why yours ran hot.
All my cars are Bone Stock 25hp and 36hp running the exact compression ratio they should be (well, I did boost my 36hp to 7:1). In that situation... the Porsche Cooler works... wonders.
NUFF SAID _________________ DB
11/1966 Porsche 912
Last edited by 52HoffmanSplit on Sat Oct 25, 2008 12:26 pm; edited 2 times in total |
oval56 Samba Member
Posted: Sat Oct 25, 2008 11:34 am Post subject: |
oval56 wrote: |
For 45 years... American VW afficianados have used Porsche 356 Coolers on their ebgines to good effect.. there exists no information except your post that says it is a bad idea.... so.... try not to be so alarmist in your posts, yours is one experience... and frankly I think I just found out why yours ran hot.
All my cars are Bone Stock 25hp and 36hp running the exact compression ratio they should be (well, I did boost my 36hp to 7:1). In that situation... the Porsche Cooler works... wonders. |
sorry sir for shareing my experiences....
and to point out my view:
-original engine, original cooler or if i do not drive faster because of the fact of cooler oiltemp, use a 356 cooler
-upgraded 36hp stock cooler or external system
and last but not least:"You would think fitting the more efficient 912/356 Cooler would be a simple fix. Yes they do physically fit with a little tapping of the top of the fanshroud as they are slightly taller.
The thing is because they channel away more heat, whilst they lower oil temperatures, they also raise head temperatures for two reasons. The first because as I say they channel more heat away but blow this over number 3 cylinder and they cast a larger "shadow" than the stock cooler which has always been a problem with number 3.
" -> from pre67vw.co.uk _________________ www.oval56.com
www.dbkvw.com |
Bengt H Samba Member
Joined: September 11, 2005 Posts: 334 Location: Sweden
Posted: Sun Oct 26, 2008 1:22 pm Post subject: |
I dont know if this ad any info but I use a Behr oilcooler (as seen in Everetts pics) on my1620 Okrasa with 8,5 comp. It has a very low oiltemp and when I meassure the temp on the heads with a infa red instrument its the same temp on both heads. |
thefladge Samba Member
Joined: July 25, 2005 Posts: 1294 Location: Anaheim, CA
Posted: Fri Apr 22, 2011 8:32 pm Post subject: |
If there was a problem with the 356 / 912 cooler restricting air flow, wouldn't we hear stories of high cylinder head temps and burned valves in Porsches? _________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
Posted: Sat Apr 23, 2011 7:36 am Post subject: |
thefladge wrote: |
If there was a problem with the 356 / 912 cooler restricting air flow, wouldn't we hear stories of high cylinder head temps and burned valves in Porsches? |
Since the 356 and 912 used the same shroud and I believe fan I would agree it would seem to pose a problem for those carsd as well, if there actually is a problem. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
Posted: Sat Apr 23, 2011 9:23 am Post subject: |
I ran a 912 oil cooler on a 2084cc VW engine for many years and never had a problem with high cylinder head temps.
I wonder if there is a real scientific way to measure the flow of air through various oil coolers. _________________ 1957 Vintage Baja Bug.
Posted: Mon Apr 25, 2011 3:48 pm Post subject: |
Hello-
You might want to contact William Genevro at Aiflow Systems (http://www.airflow-systems.com/oilcooler.html). His day job is designing oil coolers for aircraft. He's also a 912 owner who wanted a high quality oil cooler that would provide more air to cylinders 3 & 4, so he designed one himself.
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
