Kits and how to for dual Carbs to the 40Hp
Page: 1, 2, 3, 4, 5  Next
illombarbugz
illombarbugz is offline
PostPosted: Fri Oct 31, 2008 9:50 am    Post subject: Kits and how to for dual Carbs to the 40Hp Reply with quote
I know there are several kits on the market to fit the dual carbs on the 40 HP, hence I would love to make a list here of all of them including prices, with all of your help...
..as well as what adaptation are possible out of the single port ones...
..or starting with junkyard 40HP intakes, duely modified...
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Oct 31, 2008 12:24 pm    Post subject: Reply with quote
You mean old-school ones? Because I've not seen any new dual carb kits for for the 1200 - 40HP SAE. There was someone that was making manifolds, but I don't know what ever became of that.
The only way I know of to do it with parts available now, is to buy 1300SP heads and put them on the 40HP jugs, and then use SP dual carb kits. Or you can get european 1300 DP heads and do the same.
Alex6373
Alex6373 is offline
PostPosted: Fri Oct 31, 2008 12:46 pm    Post subject: Reply with quote
I am interested in finding out info on this topic is there any one who in the past has made there own intakes out of stock intake manifolds , i would like to know the do's and don'ts on the construction and any helpfull pointers would be greatl , if they cost too much to purchase and not avallable then maybe i will make my own or try!
Bub
Bub is offline
PostPosted: Sat Nov 01, 2008 10:30 am    Post subject: Reply with quote
Pretty simple to make a dual carb kit for almost any application. I did it with a 40hp on a dune buggy I built a couple years back, it used two 28/30PICT carbs.
You need the lower (head) flange from the 40hp, cut maybe a couple inches above the flange, some appropriate pipe (sectioning the VW intake works fine) and two manifold to carb flanges. The good thing is the 40hp manifolds are cheap/free most of the time, so all you need is a welder, some beer and a free saturday afternoon.
You mock it up on your longblock, spot weld and finish the manifolds. In my case I heated the manifolds and slightly 'bent' one to get correct offset. I made linkage hidden on the front of the shroud using steel rod I bought at the hardware store and random dual carb linkage pieces. If you've seen many of the old kits you can easily picture how to make it, and it seriously works fine, many times better than the old stuff.
Vintage is always cooler, but even with a decent wallet they can be hard to find.
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
OvalTeenAZ
OvalTeenAZ is offline
PostPosted: Sun Nov 02, 2008 7:08 pm    Post subject: Reply with quote
would a set of type3 single port manifolds work?? i know i would have to make some custom linkage but i could figure that out.. any ideas?
Bub
Bub is offline
PostPosted: Sun Nov 02, 2008 7:17 pm    Post subject: Reply with quote
The earliest T3's were single side draft of course, so the 13/1500 single port dual manifolds is what you'd start with. They have a different flange where the manifold bolts to the head, but you could saw that off and weld 40hp manifold flanges on...that would be pretty simple.
I personally never liked the Solex's that came on T3's (pcib?), and I dont know if 30pict carbs have the same size base..don't think so. But just another detail in the process.
Joesplace
Joesplace is offline
PostPosted: Sun Nov 02, 2008 8:24 pm    Post subject: Reply with quote
Check out these 1964 Riechert singleport manifolds:
http://www.pre67vw.com/classifieds/detail.aspx?id=1112
"Never take life seriously - nobody gets out alive!"
Lee.
Samba Animal Controller
Lee. is offline
PostPosted: Sun Nov 02, 2008 9:31 pm    Post subject: Reply with quote
I'm making 2 sets. I'm just cutting up the og manifolds to use. One set will have the pci's mounted sideways with a crankbell linkage. The other will have Weber or Berg linkage and the carbs mounted the traditional way.
www.DenverWildlifeControl.com
Alex6373
Alex6373 is offline
PostPosted: Sun Nov 02, 2008 9:37 pm    Post subject: Reply with quote
Very cool Lee keep this link updated with your progress .... thanks
How long will you make the tubes toward the carb base from the cylinder head?
Lee.
Lee. is offline
PostPosted: Sun Nov 02, 2008 10:18 pm    Post subject: Reply with quote
I will.
I haven't decided yet. That will probably be one of the last things I'll do before the engine is complete. I'm going to build the engine over the winter and I'm hoping to have everything done by April of '09.
Alex6373
Alex6373 is offline
PostPosted: Mon Nov 03, 2008 2:07 pm    Post subject: Reply with quote
I am allso doing work on my 63 this winter the dreaded heater chanels and hope to be on the road next year
vicpolky
vicpolky is offline
PostPosted: Mon Nov 03, 2008 4:17 pm    Post subject: Reply with quote
Riechert twin carb/mainfold kit for sp 40 horse
The linkage is really good, too.
1385cc 40HP Vintage Speed Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=325587&postdays=0&postorder=asc&start=0
http://www.oldspeed-mouse-motor.blogspot.com/
http://www.superninety.blogspot.com/
james m. stein
james m. stein is offline
PostPosted: Mon Nov 03, 2008 7:16 pm    Post subject: 40 hp twin carb set up Reply with quote
Are there any suppliers offering a dual carb set ups with linkage and manifolds ready to bolt on "out of the box" for the 40hp engine? Thanks, Jim
Alex6373
Alex6373 is offline
PostPosted: Mon Nov 03, 2008 7:58 pm    Post subject: Reply with quote
Vicpolky those carbs and manifolds look great i am scared to ask the price and how long to get them.... wow
The Android
PostPosted: Mon Nov 03, 2008 8:51 pm    Post subject: Re: 40 hp twin carb set up Reply with quote
No, not that I know of. As I mentioned before, the only way to get something like that, is to get like Weber 34ICTs for SP and use 1300 heads.
motofly196
motofly196 is offline
PostPosted: Mon Nov 03, 2008 11:53 pm    Post subject: Reply with quote
I wonder if Baby Dellorto's (34's) would be too much for a 40 hp? I have some with dp intakes....so I'll need to buy (or fab up) some single port manifolds.
Scott
stede
Location: Buckeye,AZ by way of El Sereno Rifa, Sur Califas 13
stede is offline
PostPosted: Tue Nov 04, 2008 2:20 pm    Post subject: Reply with quote
vicpolky is this same set up on your build up ?
vicpolky
vicpolky is offline
PostPosted: Tue Nov 04, 2008 3:56 pm    Post subject: Re: 40 hp twin carb set up Reply with quote
Riechert do a good kit, single port manifolds to fit 40hp, full linkage, and dual carbs. Worked pretty much 'out of the box' - they even jetted them to suit the engine set-up I was having built.
link: http://www.riechertmotorentechnik.de/
vicpolky
vicpolky is offline
PostPosted: Tue Nov 04, 2008 3:58 pm    Post subject: Reply with quote
Yep. Those are pics of mine being built up.
vicpolky
vicpolky is offline
PostPosted: Tue Nov 04, 2008 4:01 pm    Post subject: Reply with quote
It took a few weeks, but they build them up to order to suit your motor. It cost 748 euro shipped.
Page 1 of 5
