illombarbugz Samba Member
Posted: Fri Oct 31, 2008 9:50 am Post subject: Kits and how to for dual Carbs to the 40Hp |
I know there are several kits on the market to fit the dual carbs on the 40 HP, hence I would love to make a list here of all of them including prices, with all of your help...
..as well as what adaptation are possible out of the single port ones...
..or starting with junkyard 40HP intakes, duely modified... |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26634 Location: Douglas, WY
Posted: Fri Oct 31, 2008 12:24 pm Post subject: |
You mean old-school ones? Because I've not seen any new dual carb kits for for the 1200 - 40HP SAE. There was someone that was making manifolds, but I don't know what ever became of that.
The only way I know of to do it with parts available now, is to buy 1300SP heads and put them on the 40HP jugs, and then use SP dual carb kits. Or you can get european 1300 DP heads and do the same. |
Alex6373 Samba Member
Joined: August 05, 2007 Posts: 925 Location: Vancouver Island,B.C.
Posted: Fri Oct 31, 2008 12:46 pm Post subject: |
| I am interested in finding out info on this topic is there any one who in the past has made there own intakes out of stock intake manifolds , i would like to know the do's and don'ts on the construction and any helpfull pointers would be greatl , if they cost too much to purchase and not avallable then maybe i will make my own or try! |
Bub Samba Member
Joined: June 10, 2004 Posts: 1336 Location: Central Washington
Posted: Sat Nov 01, 2008 10:30 am Post subject: |
Pretty simple to make a dual carb kit for almost any application. I did it with a 40hp on a dune buggy I built a couple years back, it used two 28/30PICT carbs.
You need the lower (head) flange from the 40hp, cut maybe a couple inches above the flange, some appropriate pipe (sectioning the VW intake works fine) and two manifold to carb flanges. The good thing is the 40hp manifolds are cheap/free most of the time, so all you need is a welder, some beer and a free saturday afternoon.
You mock it up on your longblock, spot weld and finish the manifolds. In my case I heated the manifolds and slightly 'bent' one to get correct offset. I made linkage hidden on the front of the shroud using steel rod I bought at the hardware store and random dual carb linkage pieces. If you've seen many of the old kits you can easily picture how to make it, and it seriously works fine, many times better than the old stuff.
Vintage is always cooler, but even with a decent wallet they can be hard to find. _________________
| hitest wrote: |
| Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
OvalTeenAZ Samba Member
Posted: Sun Nov 02, 2008 7:08 pm Post subject: |
| would a set of type3 single port manifolds work?? i know i would have to make some custom linkage but i could figure that out.. any ideas? |
Bub Samba Member
Posted: Sun Nov 02, 2008 7:17 pm Post subject: |
| 56vwrag wrote: |
The earliest T3's were single side draft of course, so the 13/1500 single port dual manifolds is what you'd start with. They have a different flange where the manifold bolts to the head, but you could saw that off and weld 40hp manifold flanges on...that would be pretty simple.
I personally never liked the Solex's that came on T3's (pcib?), and I dont know if 30pict carbs have the same size base..don't think so. But just another detail in the process. _________________
| hitest wrote: |
Joesplace Samba Member
Joined: February 18, 2006 Posts: 313 Location: Brookings, Oregon
Lee. Samba Animal Controller
Joined: December 22, 2003 Posts: 3079 Location: Denver, CO
Posted: Sun Nov 02, 2008 9:31 pm Post subject: |
I'm making 2 sets. I'm just cutting up the og manifolds to use. One set will have the pci's mounted sideways with a crankbell linkage. The other will have Weber or Berg linkage and the carbs mounted the traditional way.
_________________ www.DenverWildlifeControl.com |
Posted: Sun Nov 02, 2008 9:37 pm Post subject: |
Very cool Lee keep this link updated with your progress .... thanks
How long will you make the tubes toward the carb base from the cylinder head? |
Posted: Sun Nov 02, 2008 10:18 pm Post subject: |
| blamb wrote: |
I will.
I haven't decided yet. That will probably be one of the last things I'll do before the engine is complete. I'm going to build the engine over the winter and I'm hoping to have everything done by April of '09. _________________ www.DenverWildlifeControl.com |
Posted: Mon Nov 03, 2008 2:07 pm Post subject: |
| I am allso doing work on my 63 this winter the dreaded heater chanels and hope to be on the road next year |
vicpolky Samba Member
Joined: August 09, 2006 Posts: 76 Location: Brighton, United Kingdom
james m. stein Samba Member
Posted: Mon Nov 03, 2008 7:16 pm Post subject: 40 hp twin carb set up |
| Are there any suppliers offering a dual carb set ups with linkage and manifolds ready to bolt on "out of the box" for the 40hp engine? Thanks, Jim |
Posted: Mon Nov 03, 2008 7:58 pm Post subject: |
| Vicpolky those carbs and manifolds look great i am scared to ask the price and how long to get them.... wow |
Posted: Mon Nov 03, 2008 8:51 pm Post subject: Re: 40 hp twin carb set up |
| james m. stein wrote: |
No, not that I know of. As I mentioned before, the only way to get something like that, is to get like Weber 34ICTs for SP and use 1300 heads. |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1468 Location: Eastern WA
Posted: Mon Nov 03, 2008 11:53 pm Post subject: |
I wonder if Baby Dellorto's (34's) would be too much for a 40 hp? I have some with dp intakes....so I'll need to buy (or fab up) some single port manifolds.
Scott |
stede Samba Member
Joined: February 27, 2008 Posts: 316 Location: Buckeye,AZ by way of El Sereno Rifa, Sur Califas 13
Posted: Tue Nov 04, 2008 2:20 pm Post subject: |
| vicpolky wrote: |
Riechert twin carb/mainfold kit for sp 40 horse
The linkage is really good, too. |
vicpolky is this same set up on your build up ? |
