biancovw Samba Member
Posted: Fri Dec 12, 2008 6:35 am Post subject: Durability of Stage 2 heads |
Can Steve Tims stage 2 unwelded heads hold up with a 10.5:1 compression,and not crack?
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Fri Dec 12, 2008 7:09 am Post subject: |
why dont you ask him?
steve is a very honest cat, him or greg ( his son i think? ) both will tell you whats up.
my personal opinion is that they should handle that and then more. to get some more replies you may want to change the title of the post.. i came here thinkin it would be a clutch topic.
maybe tims stage 2 heads. _________________ Brian
68 sedan
Dallas Air Coolers
| perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time.  |
| cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Fri Dec 12, 2008 9:56 pm Post subject: |
These Tims heads hold 14 to1 so 10-1 on smaller heads should be no problem.
EvolveES Samba Member
Joined: June 18, 2008 Posts: 261 Location: longmont CO
Posted: Fri Dec 12, 2008 9:58 pm Post subject: |
| perrib wrote: |
Which heads ae those, are they the stage 2's, i'm looking at a set for a 2110cc fair weather driver. |
Posted: Fri Dec 12, 2008 10:00 pm Post subject: |
those are his welded race heads. _________________ Brian
68 sedan
Dallas Air Coolers
| perrib wrote: |
| cr@M wrote: |
Posted: Fri Dec 12, 2008 10:11 pm Post subject: |
| grimace007 wrote: |
| those are his welded race heads. |
Oh, Duh, i should have seen the huge welds right in front of me those are nice but unfortunately out of my budget.
thanks man |
Posted: Sat Dec 13, 2008 12:53 am Post subject: |
| perrib wrote: |
yeah,bit I ment unwelded heads,Stage 2's which are on the special price now  |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3515 Location: Charleston, SC
Posted: Sat Dec 13, 2008 1:00 am Post subject: |
| biancovw wrote: |
The Stage 2's and Steve Tims' Signature race heads all start from the same casting. _________________
| 66brm wrote: |
| Bodacious wrote: |
| Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Sat Dec 13, 2008 1:24 am Post subject: |
| but welded are much stronger,or? |
Posted: Sat Dec 13, 2008 1:27 am Post subject: |
| biancovw wrote: |
The weld is simply to build up material above the intake port wall to allow for a larger port. It contributes very little, if at all, to the strength of the combustion chamber. _________________
| 66brm wrote: |
| Bodacious wrote: |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80319 Location: Sneaking up behind you
Posted: Sat Dec 13, 2008 5:43 am Post subject: |
I'm running 9.5:1 with Stage 2s. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
perrib Samba Member
Posted: Sat Dec 13, 2008 7:09 am Post subject: |
I meant if you can take that much out of a stock head and it remain durable the Stage Twos will be durable. Welding heads is just for being able to put the port where no aluminium was present in the stock casting.
Get the Stage Twos you won't be dissapointed. |
craigman Samba Member
Posted: Sat Dec 13, 2008 11:28 am Post subject: Re: Durability of Stage 2 heads |
| biancovw wrote: |
| Can Steve Tims stage 2 unwelded heads hold up with a 10.5:1 compression,and not crack? |
Just about ANY type 1 head will crack. It's a very common thing. The only place a type 1 head will crack is between the valves. Sometimes around the spark plug, but not as common.
People run with crack heads with no problems all the time. The only way to get a type 1 head not to crack between the valves is have the biggest valves you can put in them where the valve seats actually touch. But that not practical on most engines. |
Posted: Sat Dec 13, 2008 11:43 am Post subject: Re: Durability of Stage 2 heads |
| craigman wrote: |
| biancovw wrote: |
Just about ANY cylinder head will crack. there. fixed that one for ya
It's a very common thing. yes
The only place a type 1 head will crack is between the valves. Sometimes around the spark plug, but not as common. sure why not.
People run with crack heads with no problems all the time. yes they do, doesnt mean its ideal.
The only way to get a type 1 head not to crack between the valves is have the biggest valves you can put in them where the valve seats actually touch. But that not practical on most engines. flat out period NO FALSE WRONG ANSWER |
i have put about 30k on a set of heads without cracking them and have seen heads with over 100k without cracks.
its all about how your setup and how you take care of your engine. make sure you have proper cooling, and proper warmup.
i dont know where you got your info from craig but i disagree strongly. _________________ Brian
68 sedan
Dallas Air Coolers
| perrib wrote: |
| cr@M wrote: |
Posted: Sat Dec 13, 2008 1:01 pm Post subject: |
| grimace007 wrote: |
maybe tims stage 2 heads. |
Only you would think it's a clutch topic..  |
Posted: Sat Dec 13, 2008 1:15 pm Post subject: |
before he edited the topic all it said was stage 2 durability, way to go you got me.im a moron for thinking about a kennedy PP _________________ Brian
68 sedan
Dallas Air Coolers
| perrib wrote: |
| cr@M wrote: |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17655 Location: Left coast, Canada
Posted: Sat Dec 13, 2008 5:02 pm Post subject: Re: Durability of Stage 2 heads |
| biancovw wrote: |
Cracking is caused by overheating.
Why are you so hung up on having 10.5:1 CR? What gas are you gonna use? _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Sun Dec 14, 2008 2:32 am Post subject: Re: Durability of Stage 2 heads |
| Bruce wrote: |
| biancovw wrote: |
Why are you so hung up on having 10.5:1 CR? What gas are you gonna use? |
Out here in Europe we have 98 octane fuel. |
Posted: Sun Dec 14, 2008 8:47 am Post subject: |
what method is your octane measured i know its different than here in the states. i cannot remember the differences offhand but im sure someone knows and will chime in with it.
the heads will handle but man that is ALOT of compression for a "fair weather" driver. im sure you could make it driveable.
but 9:1 with an engle fk-8 and those stage 2 heads from steve tims on a 2 liter make for a KILLER setup and 100% driveable
ask glenn lol
im not sure what his compression is exactly but its close to 9:1 im pretty sure. _________________ Brian
68 sedan
Dallas Air Coolers
| perrib wrote: |
| cr@M wrote: |
Posted: Sun Dec 14, 2008 9:00 am Post subject: |
| grimace007 wrote: |
ask glenn lol
im not sure what his compression is exactly but its close to 9:1 im pretty sure. |
we have RON measurment for fuel,I think that is that. |
