TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Sat Jun 22, 2002 3:00 pm Post subject: Notch wheels |
| Does anyone know which wheels go on a late 65 notch ? Ive seen early type 1 wheels and 66-67 slotted on them. I have both styles but need to know which to paint. Any help is appreciated. Tim. |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Sun Jun 23, 2002 9:17 am Post subject: Notch wheels |
| Tim, maybe try the type 3 gallery area on this site and look for original pics or at the owners manuals and you can determine it that way? I'm with you I've seen both, I think for sure they were supposed to have the 4.5" most early bugs came with 4"....But being a 65 I would think they were solid...???? |
ibjack Samba Member
Joined: February 06, 2002 Posts: 2116 Location: Imperial Beach CA
Posted: Mon Jun 24, 2002 11:22 pm Post subject: Notch wheels |
| Neither of those. The 64-65 type3 wheel is it's own thing. They're solid like the bugs but there are no hubcap clips. The bug ones will work though. jack |
Paul Knight Samba Member
Posted: Fri Jun 28, 2002 7:19 am Post subject: Notch wheels |
it had a wheel very similar to the 66/67 bug in hub cap fitting but visually more like an early bus wheel. unique offset, too.
wheel is solid looking with 4 long slots like the bus wheel and a flat, push-on hubcap |
ibjack Samba Member
Posted: Fri Jun 28, 2002 10:54 pm Post subject: Notch wheels |
| Only the early '61-'63 had the slots with 5 lug. Again it's unique to the t3. J |
TimGud Samba Member
Posted: Sat Jun 29, 2002 9:31 am Post subject: Notch wheels |
| Ok. Does this make sense; Three of the wheels on it are smooth like the pre 66 wheels of the beetle and no hub cap clips but instead it has the bumps for a 66-67 style beetle hub-cap. Looks like I can take a beetle early wheel,remove the hub-cap clips,mig-weld the bumps on them and shape them to hold the66-67 hubcaps and that will give me the fourth wheel. I believe the offset is the same but I haven't measured it yet. |
Nancy08 Samba Member
Joined: March 31, 2011 Posts: 9 Location: Bell GArdens
Posted: Mon May 08, 2017 10:17 pm Post subject: Re: Notch wheels |
| His 61 different lip as a 62 or 63 wheel i have a slotted wheel but the one as a smaller lip its about. 1/2 and the ither is like One inch |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71832 Location: Phoenix 602
Posted: Tue May 09, 2017 10:04 am Post subject: Re: Notch wheels |
Has u could see the lips are different
I can see the date one the white rim can any one tell me if this is a 61 rim because of the lip |
Posted: Tue May 09, 2017 5:48 pm Post subject: Re: Notch wheels |
U can see the lip |
Posted: Tue May 09, 2017 6:08 pm Post subject: Re: Notch wheels |
Has u can see the lip ends at the valve stem hole and the white rims. The lip is different |
Posted: Tue May 09, 2017 6:34 pm Post subject: Re: Notch wheels |
The lip is 1 inch
The lip is 1/2 |
