Wap Samba Member
Joined: October 04, 2005 Posts: 12 Location: Jönköping, Sweden
Posted: Thu Jan 15, 2009 12:54 am Post subject: Spare parts on vacation trip? |
What spare parts would you take with you on a longer vacation trip with a split/zwitter? I have seen a topic about this in the past but can't seem to find it...
Thankful if anyone knows where to find it.
I am planning a summer trip to Norway (about 1000 km) with my car and what spare parts should be in the trunk...
Do you have any suggestions? The car is in in good order and are of course lubricated and the rest before the trip. So there is now direct risk of brakedown but it is better to be on the safe side.
Thanks!
/Patrik |
Sepi Samba Member
Joined: October 04, 2008 Posts: 137 Location: Mikkeli Finland
Posted: Thu Jan 15, 2009 2:53 am Post subject: |
The minumun is a correct fan/generator belt and tools to do the job. I would take a bottlejack instead of an original and a wheelspanner. A small bottle of brakefluid and engineoil. A set of points and a condencer. Some nuts, bolts and washers. Some fuses and bulbs. A towing rope... if it is there you might not need it, but if it's not, then most propably something goes wrong.
Take extra caution for crossply tires as those will come easily too hot with long trips and extra loads.
And a lot of humour and time - have a good trip! |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9408 Location: Northwood, NH USA
Posted: Thu Jan 15, 2009 10:47 am Post subject: |
Good tips. I also a spark plug or two, a length of ignition cable, and some small easily lost parts like that little slotted washer on the end of the accel cable at the carb.
Tools easily forgotten are spark plug socket, 36mm socket for the gen nut and a voltmeter. _________________ John Henry
'57 Deluxe
'56 Single Cab |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Thu Jan 15, 2009 4:12 pm Post subject: |
Of course you'd never want to have to use it, but have a fire extinguisher too. Better to have it and not need it than the other way around! _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
Posted: Thu Jan 15, 2009 4:21 pm Post subject: |
73sports wrote: |
Of course you'd never want to have to use it, but have a fire extinguisher too. Better to have it and not need it than the other way around! |
Absolutely. I have one in each of my "Drivers".... _________________ John Henry
'57 Deluxe
'56 Single Cab |
splitmike Samba Member
Joined: August 03, 2004 Posts: 510 Location: Splitsville
Posted: Thu Jan 15, 2009 4:45 pm Post subject: |
On a recent road trip to Florida I broke down in Pensacola at a red light. I had EVERYTHING.....except a coil. Had the whole family with me. The coil was bad.
So bring a spare coil. |
Posted: Thu Jan 15, 2009 8:24 pm Post subject: |
Yes, in my parts box, I have a spare coil, spare fuel pump also. _________________ John Henry
'57 Deluxe
'56 Single Cab |
drpete Samba Member
Posted: Thu Jan 15, 2009 10:31 pm Post subject: |
johnshenry wrote: |
Yes, in my parts box, I have a spare coil, spare fuel pump also. |
Good ideas, like all of the above. I've had 2 different cars where the fuel pump went out on me. I've also got a carburator in my "first aid" kit. You might also add to the list some electrical tape, a few zip ties, and maybe even a little copper wire. And don't forget a good flashlight. If you think it would help in a pinch, take a copy of the Idiot book or some other reference with you. All this stuff fits real nice behind the front seat of my bus, and behind the back seat of my bug. Have a good trip! _________________ Happy to be alive. Hey Dad, Mom, wish you were here to see all this.
Pete Keesling
Driving a VW every day..... |
ZwitterND Samba Member
Joined: September 08, 2005 Posts: 1453 Location: Fargo, ND
Posted: Thu Jan 15, 2009 11:22 pm Post subject: |
Cell phone and AAA ?? It would be an iteresting thread to start (if not done already) "Unorthodox emergency repairs" ...Our local club was on a cruise and we repaired a members bus with a bread sack "twisty tie" on one of the dual carbs. _________________ Bill |
Sepi Samba Member
Posted: Fri Jan 16, 2009 2:38 am Post subject: |
Chewing gum... As Bill sayed, this needs an own thread. You never know what happens. Ones I came out from savannah with a tyre repaired by chewing gum! I had tube type tyres and I got a (second) puncture. Nail punctured, but also blocked the tyre and air came out from the hole of valve. The sparetyre was flat, so I asked my friend to give his chewing gum, pressed the valve a bit, put the gum inside around the heel of the valve to block it, tight it with a M12 nut and pump the pressure back. Two hours drive to garage with no added pressure  |
john7 Samba Member
Joined: August 06, 2003 Posts: 1551 Location: Garden grove ca
Posted: Fri Jan 16, 2009 12:38 pm Post subject: |
Sepi wrote: |
how funny you mention chewing gum. a friend of mine used chewing gum to plug that dime sized hole on the front of his carburetor when the plug fell out. his temporary fix to get home was on there for 6 years. _________________ Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders. |
Fralg Samba Member
Joined: September 26, 2003 Posts: 15 Location: Norway
Posted: Fri Jan 16, 2009 6:05 pm Post subject: Re: Spare parts on vacation trip? |
Wap wrote: |
I am planning a summer trip to Norway (about 1000 km) with my car........... |
Where will you spend your holiday in Norway?
Frode _________________ 1x51 - 2x58 - 1x59 - 1x61 - 1x99
www.algroy.no |
Wap Samba Member
Posted: Sat Jan 17, 2009 12:26 pm Post subject: |
At the moment I don't now. I will hopefully going to the Gränsträff this summer. It is a meeting between the Swedish and the Norwegian VW-clubs. But I think it will be somewhere in the southern part, maybe around Oslo or Lillehammer. I guess more information will come during the spring.
/Patrik |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3338 Location: N.E. Oklahoma
Posted: Mon Jan 19, 2009 8:50 am Post subject: ...journeys |
Within the ranks of the VVWCA is a group calling themselves, Der Kafer Fahrer, 1945 to 1957. Apparently this was a group that drove their old VWs cross country at times. i remember they had a list of spare parts one should always have available with them.
Also, i have a manual called "Journeys under difficult conditions". This publication gives advice on driving in countries with traffic and climatic conditions which are not usually met within Central Europe...really for harsh conditions, but this list would serve as a great guide. |
Wap Samba Member
Posted: Wed Mar 25, 2009 2:01 pm Post subject: |
Thanks for all the good ideas.
I have put them together in a list so this is what you think should be in the car:
36 mm socket
Bolts
Brakefluid
Carburator
Coil
Condencer
Distribuion cap
Electrical tape
Engine oil
Fan/generator belt
Flashlight
Fule pump
Fuses
Ignition cable
Lamps
Nuts
Rotor
Set of points
Slotted washer to carburator
Spark plug socket
Spark plugs
Towing rope
Washers
Zip ties
Of course the should be a set of needed tools also. This list focus mainly on the parts.
Does anyone have any other parts that you think are necessary?
/Patrik |
