FK8 Clearanced cam?
Page: Previous  1, 2
1961bluebug
1961bluebug is offline
PostPosted: Wed Oct 15, 2008 11:33 pm    Post subject: Reply with quote
turboblue wrote:
1961bluebug wrote:
what is the safe limit when clearancing the cam on a lathe? I need to clearance my FK8 to use with 82mm crank, VW journals. Clearancing on a lathe seems comfortable. Thanks.
What rod?
H-beams have a smaller cap than I-beams and need less of course.
Valve springs and over the nose pressures figure into that number too..........somehow........ Laughing
H beam rod 5.4 length
enghof rambeling.
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold)
turboblue
turboblue is offline
PostPosted: Thu Oct 16, 2008 8:14 am    Post subject: Reply with quote
1961bluebug wrote:
turboblue wrote:
What rod?
H-beam should require minimal clearance, similar to dubkrzy's picture.
With an 84 stroke, you really need to check the piston/case clearance at BDC with that short rod.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
speedy s
speedy s is offline
PostPosted: Thu Oct 16, 2008 3:09 pm    Post subject: Reply with quote
IM RUNNING 5.5 SCAT H-BEAMS WITH 84 SCAT CRANK AND CB CLEARANCED ALLOY CASE, AFTER READING ABOUT SCAT FOLLOWERS IM STICKING WITH MY CB LIFTERS AND ENGLE CAM AND CLEARANCING MYSELF! I WOULD OF GONE FOR SCAT CAM IF I DIDNT NEED TO USE THIER LIFTERS!!!
sorry for the shouting didnt relize cap lock was on!!!
1961bluebug
PostPosted: Wed Jan 21, 2009 7:12 am    Post subject: Reply with quote
kind of related question - what is the recommended or ideal compression ratio for FK-8? From what I read it varies between 9.0-10.1:1?
Thanks,
enghof rambeling.
|82x94|
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jan 21, 2009 7:30 am    Post subject: Reply with quote
I'm running 9.5 with mine.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
nsracing
nsracing is offline
PostPosted: Thu Jan 22, 2009 1:42 pm    Post subject: Reply with quote
Here is another idea of notching/clearancing a camshaft. Between the lobes are also cleaned up on a cylindrical grinder to improve windage.
turboblue
PostPosted: Thu Jan 22, 2009 1:52 pm    Post subject: Reply with quote
You building that engine out in the garden Nick?.............. Laughing
Thanks,
Yeah 9-10:1 will make you a sweet running engine.
Gary
1961bluebug
PostPosted: Thu Jan 22, 2009 1:57 pm    Post subject: Reply with quote
I always drool above this cam..sir, can you make me one? Smile
enghof rambeling.
|82x94|
nsracing
nsracing is offline
PostPosted: Thu Jan 22, 2009 3:43 pm    Post subject: Reply with quote
The day was too good that day to be inside. The engine was out for picture-taking. Very Happy
I can't wait for summer.
neil68
neil68 is offline
PostPosted: Fri Jan 23, 2009 4:01 pm    Post subject: clearance Reply with quote
speedy s wrote:
just recieved e-mail from darren at drd, he says if i go for scat sc1 cam i have to use scat lifters do go with it!! trouble is ive just bought 28mm cb lightweights!!!
so do i clearance engle cam and use my lifters or buy scat cam and lifters instead??
is the scat cam better i.e less likely to flat the lobes??
do you think i will have to crearance cam if im using scat forged 84mm chevy journal crank and rods???
I clearanced my similar combo with hand tools such as a dremel style grinder. Yes, you will have to clearance the cam...if you look at the cam where it says D4, you can see how close the rod gets to the cam. I ground my Engle cam on the sides (rather than all the way around like a lathe).
I clearanced the case and cam bearings/supports, etc, with hand tools. It doesn't look as clean as the pros posted above, but I didn't have any VW machine shops local. This was for an 84 mm crank with chevy journals, 5.5" H-beams, FK8 cam, Bugpack race lifters, so it sounds similar to your plan:
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
venomous-67
venomous-67 is offline
PostPosted: Sat Jan 24, 2009 2:00 pm    Post subject: Reply with quote
I had my Billet Clay Smith cam done the same way.
Much stronger.
nsracing
nsracing is offline
PostPosted: Sat Jan 24, 2009 2:19 pm    Post subject: Reply with quote
Now..that is a CAM! Very nice. Very Happy
venomous-67
PostPosted: Sat Jan 24, 2009 3:53 pm    Post subject: Reply with quote
I would use a Engle or even better a Webcam.
I had a Scat go flat after 1200 miles Sad
biancovw
biancovw is offline
PostPosted: Sun Jan 25, 2009 10:37 am    Post subject: Reply with quote
stroker clearenced on lathe vs non stroker clearenced
nsracing
nsracing is offline
PostPosted: Sun Jan 25, 2009 10:41 am    Post subject: Reply with quote
I would be afraid to run the top cam. That is clearanced waay too much and will probably snap in half. That cam is probably the size of your pinky. Very Happy
biancovw
biancovw is offline
PostPosted: Sun Jan 25, 2009 10:49 am    Post subject: Reply with quote
it was run before and ready to be run again Wink
Page: Previous  1, 2
Page 2 of 2
