One by One Samba Member
Joined: August 14, 2003 Posts: 43 Location: Northern Wisconsin
Posted: Thu Apr 10, 2008 10:51 am Post subject: Homeade/DIY Awning? |
Anyone have some ideas or better yet pictures of any awnings you have built? I've seen some really nice permamently attached awning for sale as well as the Kelty type.
The theme I'm looking for is, ummm, inexpensive. _________________ '91 Carat |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Thu Apr 10, 2008 11:30 am Post subject: |
Here check this out:
http://web.mac.com/tubaneil/iWeb/Site%205/AWNING.html
The notes I made are a little out of date as I have changed it a little.
I plan on making the jack point pieces a twist/turn lock kind of thing.
The neat thing is that whey you push out the struts (L/R) it puts enough tension on them at the jack point tubes that it doesn't slide *easily*. I plan on using bungees to help keep the struts "out". Just hook it on PVC piece and end of "beam" tube.
Not totally tested, but may give you some ideas.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2725 Location: Portland Oregon
Posted: Thu Apr 10, 2008 12:05 pm Post subject: |
jackbombay wrote: |
I like the EMT conduit, I saw a similar one made from PVC, but the metal is better IMO. |
I agree. And so it seems, they are surprisingly strong.
When collapsed, and using the bungees, the polls fit along the area just above the slider door inside the Westy. IIRC, they run up into the PS area, but are not in the way.
I'll be curious to field test it under some stronger winds when I make the "L" groove for twist-locking in the jack point piece and possibly some kind of simple pin arrangement to hold poles in jack point part.
btw, some don't like the idea of the struts being in the way.
Also, I installed a SS eyehook at rear of poptop, (in place of carriage bolt on hinge) and a SS bolt/nut/washer arrangement (there must be an eyehook for this too??) mounted in place of a bolt on the luggage carrier. Although untested, it's possible with this setup, that the top can be up OR down and awning still mountable. The rear SS part doesn't raise so much that it's not doable. In theory....
Enjoy!
(VW Gas I4)
VE7TBN |
Posted: Thu Apr 10, 2008 6:23 pm Post subject: |
Vanagon Nut wrote: |
Thanks. Nice work, very nice.
I actual have access to some scrap 1" conduit and a bender at the job site. I'm thinking of trying to bend the conduit into jack points and see if that will be stable enough. _________________ '91 Carat |
jalopyjockey Samba Member
Posted: Thu Apr 10, 2008 6:55 pm Post subject: |
ive been slowly collecting parts to do a cheapy awning setup....canvas is pvc backed painters drop clothes(theyre kinda heavy, but i also kinda like that theyre that way, from home depot for 14).....the support pieces are metal adjustable clothes line props also from the depot for 5/ea.....those will be welded to two springs that have conduit or somesuch welded to the other end to slip into the jack supports......the other end of the props will slip into grommets in the clothe and the poles will be kept apart with a fiberglass rod that slips into drill holes in the poles.....im not so sure thats easy to visualize but the way i picture it the springs will force the pole tips away from the van and the fiberglass will be kept away from the canvas so that it can be used to hang towels and also allow water to run off.....i still havent figured out how to attach the clothe to the gutter yet though.....hope some of that helps |
Posted: Thu Apr 10, 2008 7:24 pm Post subject: |
One by One wrote: |
I actual have access to some scrap 1" conduit and a bender at the job site. I'm thinking of trying to bend the conduit into jack points and see if that will be stable enough. |
Thanks!
Ironically I brought a couple of 90* pieces home today in hopes of using it as a transition from Jetta rubber lines to rubber lines then long pipes. This is for a Jetta engine to Vanagon conversion.
Oddly enough, 1.25" EMT pipe isn't really that dimension. Almost 1.5" OD
But I like the idea! No kooky holes to drill, just a slot (if you want) to fit into the tang inside of jack point hole. (there's one on each point on my '81)
The hard part for me was getting the angles so it would drain back to gutter if it rained. Bad idea. Much better, and easier, IMHO, to have it drain away from the van.
Best of luck with the awning.
(VW Gas I4)
VE7TBN |
Van Morrison Samba Member
Joined: February 05, 2009 Posts: 8 Location: New England
Posted: Mon Feb 09, 2009 3:18 am Post subject: My Try at DIY awning |
I read all the posts and thought I’d give a try at the DIY awning. Here’s my take:
Bottom Line: VERY Cheap, very quick, won’t work for me.
Ingredients: 1.7meter x 1.7meter tarp, 4 spring clamps, two adjustable height laundry poles, and one plant stake (1.7meters long).
Without wasting any time sewing I just pinned the plant stake into one edge of the tarp. I then placed the plant stake edge of the tarp into my rain gutter and secured it with the spring clamps. Next I pulled the tops off my laundry poles and placed them through each of the outer corners of the tarp. I then extended the tarp and had each of my two children hold a pole in place (in lieu of staking the tarp off or embedding the poles into the ground). The 15 knot wind blew the tarp around extensively making it clear that this would be a sun shade awning on a still day ONLY.
All tolled I spent $12.34, about an hour shopping for the goods at the 100Yen Store (aka Japan’s Dollar Tree) and the local Home Depot type and about 15 minutes on the initial attempt. What I learned is that for my purposes (withstand wind and rain) I’d need something a lot sturdier. However, the plant stake in the edge in the rain gutter held by spring clamps held like a champ though!
the poles
the tops come off the poles
tarp and clamps[/img] _________________ '74 Transporter - Burnt to ground on I95. Cos Cob, CT.
'84 Westy - Totaled in freak drive-by while parked at repair shop. Monterey, CA.
'95 Mazda Bongo Friendee - Vanu Chau while in Northern Japan.
'81 Westy - New England |
syncrosimon Samba Member
Joined: November 20, 2008 Posts: 257 Location: Devon, England
Posted: Mon Feb 09, 2009 4:38 am Post subject: |
This is my set up.
I have a rail screwed to and the same length as the hightop. Then I sewed together 3 army tarps and a length of kador gusset. This tarp now slides onto the rail, and is much longer than the rail, so can be arranged to provide shelter as required. Total cost £30. Just need some adjustable height poles for the front. I have sewed loops all around and the trap can be used in it's own right.
But we use a tent version when staying more than one night, or it is raining.
_________________ 1991 16" 2.1 DJ Syncro factory hightop ex Finnish Army Ambulance, now sold.
Thinking about Thing or 181 (182) ownership. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Feb 09, 2009 8:47 am Post subject: |
Tarps and adjustable poles work remarkably well.
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Mon Feb 09, 2009 10:12 am Post subject: |
I get a "file not found" error on Vanagon Nut's post at the top of this page, so I am not sure what he refers to. But it sounds like electrical conduit.
I saw a pretty nice set up at the recent Wetwesty gathering on the Oregon coast. A guy from Seattle had a Syncro hardtop with a nice Yakima rack system, He rigged an electrical conduit awning frame and then put the horizontal ends into the already mounted Yakima bars, thus connecting the conduit frame to the van in a very fast and pretty sturdy way. A tarp, awning, camel skin etc. can then be tossed over the frame. This rig has apparently been field tested in the heat and winds of Burning Man several times, so that seems a pretty good endorsement.
[/img] _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
campism Samba Member
Joined: September 07, 2007 Posts: 4686 Location: Richmond VA
Posted: Mon Feb 09, 2009 10:55 am Post subject: |
Not exactly homemade, but home-modified. This one works for us.
http://picasaweb.google.com/bike2vcu/AwningProject#
It also retains the ability to be used as the four-pole freestanding fly in its original configuration.
Stephen
winkshog Samba Member
Joined: August 16, 2006 Posts: 294 Location: Mich-Wallhalla
Posted: Mon Feb 09, 2009 1:08 pm Post subject: |
climberjohn wrote: |
Yah, stupid iWeb wasn't uploading files completely to my .mac. Seemed like $ was needed for software update to solve problem. I shut my .mac site down out of principal. Ain't gonna pay to upgrade software when already paying premium for space/bandwidth.... <rant off>
Here's some pics from my FREE googlepages site:
http://tubaneil.googlepages.com/homemadeawning
They're tiny, but should shed some light.
(VW Gas I4)
VE7TBN |
Timwhy Samba Member
Posted: Wed Feb 11, 2009 3:17 am Post subject: |
Your pictures look great and your work on the awning is excellant! This awning looks simular to the Bus Depot Ez Awning. At least in the design and presentation. Your idea along with my desire for a BD awning convinced me to purchase the Northwest Territory dining canopy from Sears. It will be my V-Day project, don't think I like the idea of drilling holes in my van so I'll go the BD route and secure it to the van via pole & clamps. Stephen thanks again for saving me some ca$h!! _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
Posted: Wed Feb 11, 2009 6:15 am Post subject: |
The BD awning has a perimeter frame in addition to the X supporting the dome so it may be sturdier, and is pretty fairly priced. Good luck with your project! |
Posted: Wed Feb 11, 2009 7:56 am Post subject: |
For those of you using tarps as awnings, I found some interesting fittings. Go to www.leevalley.com and then click on Gardening>Leisure>Camping & Hiking.
They show several different tarp clips that might be handy for anchoring in different conditions. These things may also be available elsewhere but my gardening bride just got their newest catalog. |
dubstar Samba Member
Joined: January 17, 2009 Posts: 1438 Location: New York
Posted: Fri Jul 03, 2009 8:40 am Post subject: |
I found this link:
http://www.vanagon.com/info/accessories/inexpensive-awning/index.html
and I tested mine for the first time yesterday:
it worked really well and I am happy with the results...total cost about $28, but I already had the steel pole for the rain gutter...
I think the tent rope lengths can be shorter and only one per side is necessary if it is not windy...with two lines coming off each pole, it is very solid...little flags or bits of ribbon on the ropes will also prevent people from running into them...I'm going to try to figure out a way to set this up on hard surfaces next... |
Bruce Wayne Samba Member
Posted: Fri Jul 03, 2009 9:06 am Post subject: |
dubstar wrote: |
I used some re-bar "feet",not sure what you really call them. you can see them in this pic.
my awning is made from conduit so they may be to big for your needs. something like it should work for you though. I also put eye-hooks in the feet of mine so I could stake it down and added a middle leg since this pic. |
buildyourown Samba Member
