Dormobile top restoration
xavi_242
xavi_242 is offline
PostPosted: Thu Feb 12, 2009 9:47 am    Post subject: Dormobile top restoration Reply with quote
Well I bought a Dormy top to hack it in my 67 SO42.
I'll post here all the process from the cleaning, replacing, fixing the roof till the final cutting ( Confused ) and fitting.
the day I picked up... I made 500+ km to get it.
most of the parts are there Smile
rotten cots at the edges... will try to save center of them...
Top to body seal
window seal
vent mechanism ready to be restored
Detail of how canopy attaches to top, Polyurethane was used alla round and in every bolt
only fiberglass ready to 0000# wet sand and polish
strange looking hinge reinforcement... Question
ouch!
I will made a new hinge reinforcement
wanted to save canopy but there are zillions of small craks and some big tears... too dry and fragile...
more to come... Smile
1967 Split SO-42 Dormobile
BarryL Premium Member
BarryL is offline
PostPosted: Thu Feb 12, 2009 9:52 am    Post subject: Reply with quote
4
3
2
1
xavi_242
xavi_242 is offline
PostPosted: Thu Feb 12, 2009 9:55 am    Post subject: Reply with quote
blackdog1999 Premium Member
blackdog1999 is offline
PostPosted: Thu Feb 12, 2009 10:06 am    Post subject: Reply with quote
I am really excited for you. I have one big bit of advice for you that I learned many years ago working in a body & paint shop. Before you cut the roof just make sure to measure twice so you only have to cut once. That is a big hole & you do not want to make it too big. Shocked
I am also getting ready to do another Dorm hack in the next few weeks. I will try to post some info & pics when I do the cutting.
Home of the one true split Bus Motorhome
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Thu Feb 12, 2009 10:18 am    Post subject: Reply with quote
Enter Pyroman, stage left, in the Rush Limbaugh mask...
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Feb 12, 2009 11:29 am    Post subject: Reply with quote
hussein says:
Razz
xavi_242
xavi_242 is offline
PostPosted: Thu Feb 12, 2009 11:35 am    Post subject: Reply with quote
It will be fine if you post some info and detail pics Wink
PostPosted: Thu Feb 12, 2009 1:41 pm    Post subject: Reply with quote
I'll do you one better. I'll install your Dorm top for the cost of a plane tickect. Laughing
DormobileDave67
DormobileDave67 is offline
PostPosted: Thu Feb 12, 2009 4:58 pm    Post subject: Reply with quote
hope it works for ya
originalo
originalo is offline
PostPosted: Fri Feb 13, 2009 10:22 am    Post subject: Re: Dormobile top restoration Reply with quote
To my knowledge the canopy can still be ordered at DORMOBILE in the UK. Not cheap though. A buddy of mine ordered it last year. Although it came from the OEM, the fit was not too great and a bit tricky. But it worked out in skilful hands.
I think , they still carry some of the seals, too. To be doublechecked with DORMOBILE factory.
Good success!!
iveedubbin
iveedubbin is offline
PostPosted: Fri Feb 13, 2009 7:40 pm    Post subject: Reply with quote
I'll be keeping track on the progress of this install, I will also be doing a Dormy top install onto my 63 soon, with the help of pyrOman Very Happy
xavi_242
xavi_242 is offline
PostPosted: Sat Feb 14, 2009 12:18 am    Post subject: Re: Dormobile top restoration Reply with quote
Good success!!
yes I already checked at dormobile.co.uk and contacted Tim, he gave me all the parts he carry and of course the prices... Some parts are at a afine price but others like canopy are very expensive... canopy is 367GBP for a non UK resident and you should add shipping costs...
I saw pics from a guy installing that canopy and it is true that it don't fit as tight as a factory installed... maybe the skills when installing it are very important... I guess that replacing canopy will be a PITA Confused
Damon22
Damon22 is offline
PostPosted: Sat Feb 14, 2009 12:59 am    Post subject: Reply with quote
At least the exchange rate is working in your favour these days!
Dormy tops are great.
xavi_242
xavi_242 is offline
PostPosted: Sat Feb 14, 2009 7:35 am    Post subject: Reply with quote
SS bolts and nuts all around... new window seals and polyhuretane sealer
this seal will do the job... but not looks like the OG Sad
vent seal...
the new I found at a hardware store... less than 1/2 price other sells for specyfic dormy windows...
ready to reassemble Smile
wet sanding...
anyone knows the purpose of the ring screw?? there are 4.
my son was really happy and his looking fordward to go camping with the new top Smile
xavi_242
xavi_242 is offline
PostPosted: Sat Feb 14, 2009 8:51 am    Post subject: Reply with quote
just ended assemblig the vents hardware... put washer like factory fitting but in SS and rivets. Lubed all joints with grease for a porper movement as the rivets left the joints very tight.
there is a missing adjusting knob, if anyone have one for spare please I need one Smile
DormobileDave67
PostPosted: Sat Feb 14, 2009 12:26 pm    Post subject: Reply with quote
iwas looking at my dormy and i didnt see a ring screw.
xavi_242
xavi_242 is offline
PostPosted: Wed Feb 25, 2009 11:08 pm    Post subject: Reply with quote
put the trim-snake that was hard in the bath with hot water and then left it the whole night sitting under a wardoble. After all it looks now much better, then I cleaned it.
before: http://www.thesamba.com/vw/forum/album_page.php?pic_id=527681
Also cleaned the retaining leather straps.
xavi_242
xavi_242 is offline
PostPosted: Sat Feb 28, 2009 1:02 pm    Post subject: Reply with quote
more work done today... polished aluminium plates. Didn't go to mirror finish, looks good. Removed rust from springs and cleaned it well.
Also painted with galvanized paint the telescopic bars... didn't took pics...
westy_LA_fade_away
westy_LA_fade_away is offline
PostPosted: Sat Feb 28, 2009 1:20 pm    Post subject: Reply with quote
Looking Good, Xavi! Can't wait to see it completed!
-Marc
ratherb-buggin
I'm going to try to pick up a few other trannys for more options.
JacsWagen
Sometimes function over looks isn't bad, unless you're at a bar.
Cheers!
Marc Schumer
1990 Westfalia Camper
[email protected]
_______
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
xavi_242
xavi_242 is offline
PostPosted: Tue Mar 03, 2009 12:41 pm    Post subject: Reply with quote
-Marc
thanks Marc... I hope to have it finished for the summer holidays...
Page 1 of 8
