Rubber seal for DOKA engine cover
Toadranger
Toadranger is offline
PostPosted: Fri Feb 20, 2009 8:02 am    Post subject: Rubber seal for DOKA engine cover Reply with quote
Hello all-
Where can I find replacement rubber for the engine cover in my 88 DOKA? Is this the same as for a Vanagon of the same vintage? The previous owner (Hi Pedro!) made a nice diamond plate cover, but now the rubber is tired and has to go. I am getting frequent leaks in heavy rains. I have made use of simple weatherstripping for now, but need to remove the old rubber, repaint the channel, and replace.
All advice welcome!
Thanks....David....Nashville TN
WestyBob
WestyBob is offline
PostPosted: Fri Feb 20, 2009 10:45 am    Post subject: Re: Rubber seal for DOKA engine cover Reply with quote
Toadranger wrote:
Hello all-
Where can I find replacement rubber for the engine cover in my 88 DOKA? Thanks....David....Nashville TN
Since dokas were sold in Canada, maybe if you contacted a VW dealership there you could luck out and find some seals. You could google on Capilano VW in VanBC or Speedway VW in Victoria BC or whatever's closer to you in TN.
I know the hatch size between the doka and vanagon are not the same but not sure about rubber seal transfer.
zohami
zohami is offline
PostPosted: Fri Feb 20, 2009 5:32 pm    Post subject: Reply with quote
For that or for rear window rubber, Doka specific, I would try Lars at http://www.tristar-connection.de/originalparts/originalparts.php
or the Busman in Belgium at http://www.busman.be/pagina3.html
Toadranger
PostPosted: Mon Feb 23, 2009 11:19 am    Post subject: update Reply with quote
Hello all-
Another Samba member was kind enough to run down the proper part number for the rubber gasket for the DOKA Engine Compartment Lid Seal for a 1988 model. The part number for the doka top engine seal is
251 813 133 B. Turns out this is the same part number used for the lid seal for a Vanagon of the same vintage, and is available at several vendors in the US.
Same question but for the rear deck lid seal....where can that be acquired?
Best to all....dw, nashville, tn
syncrodoka
syncrodoka is offline
PostPosted: Mon Feb 23, 2009 4:41 pm    Post subject: Reply with quote
Try the usual sources for vanagon parts. The first 2 will be the fastest to get the part from if you want it soon.
VanCafe. http://www.van-cafe.com/home/van/page_579_173/engine_compartment_lid_seal.htm
GoWesty. http://www.gowesty.com/ec_view_details.php?id=2336&search_phrase=251-813-133B&start=
Busdepot. http://busdepot.com/details.jsp?partnumber=251813133B
keithwwalker
keithwwalker is offline
PostPosted: Tue Feb 24, 2009 7:55 am    Post subject: Reply with quote
ETOS lists rear engine lid gasket as NLA
Then it lists this code:
F 24-E-062 353
Anyone help
Question
ETOS doesn't list part nos. for NLA parts.
One alternative is to get a used gasket from a german doka supplier or look on german ebay
syncrodoka
PostPosted: Tue Feb 24, 2009 4:36 pm    Post subject: Reply with quote
???- part number is listed above. Same as vanagon and available through all vendors.
keithwwalker
PostPosted: Tue Feb 24, 2009 6:49 pm    Post subject: Reply with quote
This is for the rear hatch in the back, not the rear deck. They are two different gaskets.
F 24-E-062 353
Anyone help
Question
16CVs
16CVs is offline
PostPosted: Tue Feb 24, 2009 7:11 pm    Post subject: Doka/Sinka seal Reply with quote
It is really nothing special .just a high density rubber in a square shape.I would just look at "Mc master Carr" they are bound to have what you need.
Stacy
keithwwalker
PostPosted: Tue Feb 24, 2009 10:44 pm    Post subject: Reply with quote
I thought you asked for both seals:
1. Doka engine deck (top)
2. Doka Rear Hatch
GMByers
GMByers is offline
PostPosted: Fri Mar 06, 2009 2:40 pm    Post subject: Reply with quote
Toadranger,
Did you find/make the gasket yet?
If not, I can go down to the local VW dealer next week to price one for you, if the dealer still carries them.
