Spark plug access window
kahala46
kahala46 is offline
PostPosted: Tue Mar 17, 2009 4:26 pm    Post subject: Spark plug access window Reply with quote
Has any one cut a window in the rear wheel well to access the spark plugs and make changeing the plugs easer when you are running dual carbs.If you have a pic it would help.Thank you
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Mar 17, 2009 4:27 pm    Post subject: Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
kahala46
kahala46 is offline
PostPosted: Tue Mar 17, 2009 4:31 pm    Post subject: Reply with quote
Thank you Glenn butI was thinking of something a little bigger so you could access the manafold nuts and take them off as well.
andk5591
andk5591 is offline
PostPosted: Tue Mar 17, 2009 4:41 pm    Post subject: Reply with quote
I am so glad you posted that again - Was trying to find it the other day because I need to do the same thing on my project. Thanks!
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
nobuggybob
nobuggybob is offline
PostPosted: Tue Mar 17, 2009 4:45 pm    Post subject: Reply with quote
For the guys that just drill holes for your jets and adj. screws,What do you plug the holes with when not in use?
You Can't Quit Poverty
kahala46
kahala46 is offline
PostPosted: Tue Mar 17, 2009 5:05 pm    Post subject: Reply with quote
[quote="nobuggybob"]What do you plug the holes with when not in use?[/qu I plan to use nut inserts and and screw a plate over the hole with some kind of rubber backing to keep the H2O out ote]
Cusser
Cusser is offline
PostPosted: Tue Mar 17, 2009 5:30 pm    Post subject: Reply with quote
I cut an access panel maybe 6 x 10 inches in my 1970 sedan, to access #3 and #4 spark plugs, which were behind/under the AC compressor. I used a piece of sheet metal to seal that, with a hex head screw at each end to hold it. Maybe I can take and post a photo this weekend, PM me Friday.
Mr. 010
Glenn is offline
PostPosted: Tue Mar 17, 2009 6:43 pm    Post subject: Reply with quote
I have no problem getting to the intake manifold nuts.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Hotrodvw
Hotrodvw is offline
PostPosted: Tue Mar 17, 2009 9:07 pm    Post subject: Reply with quote
Can ya see them winder's in there????
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Cusser
Cusser is offline
PostPosted: Wed Mar 18, 2009 4:49 am    Post subject: Reply with quote
My access window was similar to that posted just above, but he did a nicer job.
HerrrKafer
HerrrKafer is offline
PostPosted: Wed Mar 18, 2009 5:39 am    Post subject: Reply with quote
http://ebasic.easily.co.uk/01101C/024024/hipacshowto.html
Evan H.
In a perfect world, anyone running chromies would be shot.
marekv8
marekv8 is offline
PostPosted: Wed Mar 18, 2009 6:30 am    Post subject: Reply with quote
I'm running the HiPacs from the previous post and they're extremely well made. All the Hooky's Panel Shop bits are great.
kahala46
kahala46 is offline
PostPosted: Thu Mar 19, 2009 10:42 am    Post subject: Reply with quote
Thank you all for all your posts. please keep the pics and ideas comming Rob
hemifalcon
hemifalcon is offline
PostPosted: Sat Feb 13, 2010 8:38 am    Post subject: Reply with quote
I don't need to do this, although it may make things easier. Removing those covers is one extra headache. I can get my carbs and all off without doing some cutting of the car. I have to use a similar setup with my ratchet, and different connections, but I can get the job done with dual Dell 40's installed. It's a bit of a pain, but I don't see how this really makes it any easier in the end.
'62 VW Bug Sedan (Ruby Red)
Resto pics> http://smg.photobucket.com/albums/v697/hemifalcon/Bug%20resto/?start=all&paginator=top
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Feb 13, 2010 8:42 am    Post subject: Reply with quote
It does make it easier to change plugs, get to manifold nuts, etc......BUT, IMO I wouldn't cut the car if it isn't already. Mine were done when i bought it.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
