1978 2.0 Liter FI camshaft...regrind?
Ed Ruth
Ed Ruth is offline
PostPosted: Tue Jul 07, 2009 9:40 pm    Post subject: 1978 2.0 Liter FI camshaft...regrind? Reply with quote
Does any company regrind and/or harden used VW bus camshafts? Can an undamaged camshaft be used again without any machine work? Will polishing be beneficial?
We all have problems and so do buses. The universe is, after all, winding down.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jul 07, 2009 10:03 pm    Post subject: Reply with quote
you can talk to Jake Raby http://www.aircooledtechnology.com/store/home.php?cat=259 about one of his new cams or you can call WebCam camshafts in Riverside CA. We got ours through Riddle Machine CO - RIMCO http://www.rimcovw.com/Services.html who sends them to Webcam. http://www.webcamshafts.com/. Scott at German Supply http://germansupply.com also sells camshafts.
Another alternative is watching the shows and see if a new old stock one turns up. You can also run an ad on Samba and see what shows up. There is one running now and he sees a new cam once in awhile I hear.
Other camgrinders are Isky http://www.iskycams.com/ used to have some nice VW cam grinds but I don't know if they do or not. There is also Crane and Engle camshafts http://www.englecams.com/index.php although Crane has been sold and Engle doesn't list a type 4 cam.
George Carlin:
Skills@EuroCarsPlus:
busman78
busman78 is offline
PostPosted: Wed Jul 08, 2009 3:33 am    Post subject: Reply with quote
And Engle was bought by So Cal Imports.
Hoody
Hoody is offline
PostPosted: Thu Jul 09, 2009 3:08 am    Post subject: Reply with quote
Do not waste your time with anyone else.It will cost you a fortune in the long run.Call Jake Raby.
Hoody
Hoody is offline
PostPosted: Thu Jul 09, 2009 3:13 am    Post subject: Reply with quote
Whoops,What I meant to say is if you don't call Jake it will cost you a fortune in the long run
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Jul 09, 2009 3:15 am    Post subject: Reply with quote
I would also suggest that you purchase lifters from the same company as the camshaft. They need to have the same Rockwell hardness so that they do not "eat" each other.
