550 Spyder "4 cam"-like engine build up **NEW UPDA
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
micheloaks
micheloaks is offline
PostPosted: Sun Jan 11, 2009 9:28 am    Post subject: Reply with quote
turk turk its been said before but...amazing and tenacious! looking forward for more posts and development pics.
Mark have you had any success with machining parts and any pics to post?
Of interest look at Martin Bott's project at [email protected] A contemporary iteration of the 4 cammer. I believe all new excepting the use of Porsche cylinders
M-Owen
M-Owen is offline
PostPosted: Mon Jan 12, 2009 9:26 pm    Post subject: Reply with quote
Hey Michel I have not gotten a chance to take any pics of my work on the engine yet and I sure Turk will tell you that I have been promising for sometime now. I did send my case to the machine shop yesterday thanks to my son and with some luck I will pick up my camshafts when I get home and get them assembled so that can be done. I am also experimenting with some the high strength epoxy's for joining my cam towers as opposed to the stress associated with welding stay tuned...
I saw those heads being developed by 5speed and I must admit I am envious and a little sceptical of using 4 valve heads on aircooled heads I keep thinking about heat build-up They would be great as a high revving 2valve design... maybe I should stick to designing heat pumps not cylinder heads
micheloaks
PostPosted: Wed Jan 14, 2009 12:49 am    Post subject: Reply with quote
c'mon post a pic!
M-Owen
M-Owen is offline
PostPosted: Wed Jun 24, 2009 3:36 am    Post subject: Reply with quote
Turk have you gotten any further? I have most of my engine mocked up and I did decide to reconfigure my drive system but still stayed from convential wisdom, I am using the original cam to drive porsche cams at an 1:1 ratio (opposed to driving from crank) now I designing the oilpump that will fit in the void left from back half of camshaft.... as usual when i figure out how to post pictures I will do so soon!
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Wed Jun 24, 2009 7:43 am    Post subject: Reply with quote
M-Owen wrote:
....as usual when i figure out how to post pictures I will do so soon!
I've always wondered how it's possible to be smart enough to design an atom bomb, yet not know how to post pictures in a forum. Confused
Nukes in the Navy are all like that- they can run a Reactor, but need help tying their shoes! Laughing
http://www.thesamba.com/vw/forum/viewtopic.php?t=6
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
gears
gears is offline
PostPosted: Wed Jun 24, 2009 9:09 am    Post subject: Reply with quote
I can't make any atomic weapons, but I might be able to insert a photo ..
M-Owen
M-Owen is offline
PostPosted: Wed Jun 24, 2009 1:59 pm    Post subject: Reply with quote
To make matters worse I am an engineer with a PHD you would think I could figure out how to post a picture in a forum. I will sit down this weekend and overthink the picture posting thing Razz
Very nice oilpump
M-Owen
M-Owen is offline
PostPosted: Sat Jul 11, 2009 2:47 am    Post subject: Reply with quote
Here is a picture of my first mock-up, Now that I understand how to post pictures I will take some better images and post when machining is completed.
And yes you were right it wasn't rocket science just a different procedure from other forums. Look forward to your feedback.
M-Owen
M-Owen is offline
PostPosted: Sat Jul 18, 2009 5:19 am    Post subject: Reply with quote
Who's oil pump is this? I am in the process of machining a housing using porsche oil pump internals. I need to mount in an exterior location as room as at a premium
gears
gears is offline
PostPosted: Sat Jul 18, 2009 8:10 am    Post subject: Reply with quote
Well, that's only half of the components for a 4-cam pump. It was made by my machinist, who made two when he was presented with the job years ago. Although it's been judged to be of higher quality than the other German-made replacement pump for these engines, the close-knit politics of 4-cam restoration has delegated this one to my display case.
M-Owen
M-Owen is offline
PostPosted: Sun Jul 19, 2009 8:46 am    Post subject: Reply with quote
Well it's a very impressive oil pump non the less!
sled
sled is offline
PostPosted: Tue Sep 01, 2009 9:38 pm    Post subject: Reply with quote
Turk Turk, updates?
anyone updates on their projects?
drive your split.
Page 10 of 10
