Which truss bar/kaffer bar to buy
Page: 1, 2, 3, 4  Next
andy 64
andy 64 is offline
PostPosted: Sat Aug 01, 2009 3:41 am    Post subject: Which truss bar/kaffer bar to buy Reply with quote
Hi iam looking a getting a truss bar/kaffer bar can anyone recomend one appart from the csp one.as even here in the uk they are big money to buy
thanks for looking
Andy
Bad bug
Bad bug is offline
PostPosted: Sat Aug 01, 2009 4:51 am    Post subject: Reply with quote
I have one from www.vdubengineering.com out of canada.
gonebuggy
gonebuggy is offline
PostPosted: Sat Aug 01, 2009 6:13 am    Post subject: Reply with quote
^ Agreed. Awesome piece.
Alex
mharney
mharney is offline
PostPosted: Sat Aug 01, 2009 7:12 am    Post subject: Reply with quote
I think that the ones Aircooled.net sells are very good. Mine was the weld in version he was selling previous, but the bolt in version he has now looks just as good.
W1K1
W1K1 is offline
PostPosted: Sat Aug 01, 2009 8:10 am    Post subject: Reply with quote
I bought mine from VDub Engineering too.
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
Scott13
Scott13 is offline
PostPosted: Sat Aug 01, 2009 8:21 am    Post subject: Reply with quote
I bought mine from eyeball-engineering.net. I haven't installed it yet, but it looks good just sitting on my shelf.
tpnuckels
tpnuckels is offline
PostPosted: Sat Aug 01, 2009 8:36 am    Post subject: Reply with quote
Ditto on the Eyeball. Works great and is well made. Nice people, too.
http://eyeball-engineering.net/TorqueBar.html
andy 64
andy 64 is offline
PostPosted: Sat Aug 01, 2009 11:23 am    Post subject: Reply with quote
Wow thanks for the info.those bars don't seem to
be useing rose joints is that a bad thing or not
Cheers andy
stealth67vw
stealth67vw is offline
PostPosted: Sat Aug 01, 2009 12:21 pm    Post subject: Reply with quote
I got a bolt in chromoly unit from Fast Fab. It is very nice and very light.
http://www.thesamba.com/vw/classifieds/detail.php?id=790866
FYI, the aircooled.net bar is the Eyeball Eng. bar.
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Aug 01, 2009 7:13 pm    Post subject: Reply with quote
I built my own......and saved a LOT of money doing it.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Bruce
Bruce is offline
PostPosted: Sat Aug 01, 2009 9:13 pm    Post subject: Reply with quote
That may be true, but from an engineering perspective, it is a poor design. The horizontal cross bar will flex down when power is applied because the down links are attached in the middle.
The others (CSP, VDub Engineering) are better designs, with the attachments at the end of the horizontal cross bar.
andy 64
andy 64 is offline
PostPosted: Sat Aug 01, 2009 10:53 pm    Post subject: Reply with quote
Thanks for the info.was not sure about the cross bar being in 2
pices on the eyeball one.does anyone know what the diffrence are in the ends like on the fast fab one to the eyeball one still not sure
Thanks andy
tpnuckels
PostPosted: Sun Aug 02, 2009 9:14 am    Post subject: Reply with quote
Bruce,
You're probably right that there will be a bit more flex with the Eyeball design.
However, I have noticed a remarkable improvement over stock with a more rigid feel. There's no welding needed so installation is much easier.
I don't use my car for drag racing. I was looking to have a better tracking car on the twisties. The truss bar, along with a rear stabilizer and front beam braces have made a significant improvement. Oh, no wheel hop as well.
I felt, for the money and the usage, Eyeball Engineering delivered.
W1K1
W1K1 is offline
PostPosted: Sun Aug 02, 2009 9:34 am    Post subject: Reply with quote
does anyone know what the difference are in the ends like on the fast fab one to the eyeball one
With vibration and time the rod ends on the fast fab one will become loose and sloppy. Basically they are a steel ball with a steel ring bent to capture the ball. Some use teflon/brass others use brass liners for the ball to ride on which can get hammered out in a short time. The end result is the same loose ring and a ball flopping around.
1973 super 2110cc
andy 64
andy 64 is offline
PostPosted: Sun Aug 02, 2009 9:50 am    Post subject: Reply with quote
cool thanks for that.looks like it's between the eyeball one or the Vw eng one as they don't seem to use the ball type ends
Thanks Andy
Tbirdusa
Tbirdusa is offline
PostPosted: Sun Aug 02, 2009 6:07 pm    Post subject: Reply with quote
I welded my roll cage into the horns. I don't think it's going anywhere Wink
Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus!
mharney
mharney is offline
PostPosted: Sun Aug 02, 2009 8:01 pm    Post subject: Reply with quote
This is the point where you start thinking about what is going on at the nose cone, and not what is happening at the frame horns, Tbird. Smile
Hotrodvw
Hotrodvw is offline
PostPosted: Sun Aug 02, 2009 9:03 pm    Post subject: Reply with quote
Then you get ya a mid-mount. Wink
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Speedy
Location: Cape Fort St. Port River Inlet Bay Coast Canal Beach, the median on Hurricane Highway, Florida.
Speedy is offline
PostPosted: Sun Aug 02, 2009 9:39 pm    Post subject: Reply with quote
Two locals installed the Bugpack kafer bar, both cars were street driven. One has a 1776 and occasionally does burnouts, the other had an awesome VW Paradise built 2276 with a geared trans to handle the motor. On both of these cars the Bugpack truss bar performed well.
pimp
_________________________________
Wanted:
A.J. Pierson VW Tag Frame - Orlando FL.
Original Solid Ragtop or Convertible Beetle In Central Florida!
(O\ ! /O)
andy 64
andy 64 is offline
PostPosted: Mon Aug 03, 2009 12:04 pm    Post subject: Reply with quote
where did you get that gearbox strap/cradle from looks like a nice pice
cheers andy
Page 1 of 4
