Largest single port engine
ppp
ppp is offline
PostPosted: Tue Jul 07, 2009 4:02 pm    Post subject: Largest single port engine Reply with quote
Is there a limit to the size a single port can be? Without some tricked out heads or intake. Keeping it real and inexpensive...maybe?
nsracing
nsracing is offline
PostPosted: Tue Jul 07, 2009 7:13 pm    Post subject: Reply with quote
"tricked out" can never go w/ inexpensive. Very Happy
It will always cost money or time or both to do anymore than stock. But I think in the end, it is all worth it.
krusher
krusher is offline
PostPosted: Thu Jul 16, 2009 9:23 am    Post subject: Re: Largest single port engine Reply with quote
Well you could open out the single port heads to a 94mm barrels and any stroker crank can be fitted int the case with work just like a duel port, so you could have a 3L single
without very good port work I would say over 1776 is pointless.
(06:31:07) RoachGhia: "i drink dick way too fast"
Gary
Person of Interest
Gary is offline
PostPosted: Thu Jul 16, 2009 10:56 am    Post subject: Reply with quote
Really? That's interesting, Keith. It's been my understanding that the limit for a SP was 1600, after which any larger would necessitate going to dual port status. I'm completely ignoring 1641 as I consider that unimpressive.
What kind of port work and other mods would have to be done in order to go 1776 with a single port?
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
PostPosted: Thu Jul 16, 2009 10:58 am    Post subject: Reply with quote
I don't know the gritty details but I know there have been several people with 1776cc single port engines in Buses.
loor
loor is offline
PostPosted: Thu Jul 16, 2009 3:01 pm    Post subject: Reply with quote
any size can be done but as krusher said - pointless. even with stock dp heads its pointless to expect power cuz you cant even fill the barrels fast enough
some guy in germany drives around with a 1966cc engin with bored 36mm solex pci carbs and sp heads and has got 110hp
so it can be done but with much effort and maybe if you cant do it yourself - plenty of money
just some impressions how its gotta look like if you want that a hipo engine may breath
good luck.
Unkl Ian
Unkl Ian is offline
PostPosted: Thu Jul 16, 2009 5:30 pm    Post subject: Reply with quote
Try running 5k, not easy if you are out of shape;
now do it breathing through a straw. Possible, but much harder.
The factory had the right idea.
Thornton
EMPI Guru
Thornton is offline
PostPosted: Fri Jul 17, 2009 7:22 am    Post subject: Reply with quote
Jeff aka Rizzag here on samba has built a couple 1776 Single ports
they are a torque motors and pull really good.
In fact this is his 67 he had a 1776 single port in
burn out
Thornton
krusher
krusher is offline
PostPosted: Fri Jul 17, 2009 8:55 am    Post subject: Reply with quote
As an engine gets faster and faster it needs to breath more air so if the head is the most restrictive part then it will become a rev limiter, so you can build a 3L single port and it may only rev to 4500rpm but have loads of power compared to a 1600 below that breathing limit.
This is how v8's work, very bad efficiency per litre.
Jake raby used to make type1 2.1 single port bus engines as the single port has very good port velocity and there for great low rpm TQ.
Its all in a full engine combo, carbs, heads , cam , exhaust.
slo356
slo356 is offline
PostPosted: Wed Aug 05, 2009 10:58 pm    Post subject: Single Port 1776 Reply with quote
Physically, you can built a Single Port head engine as large as any other head choice (dual Port). The real limit to useable increases in engine size is the availability of fuel/air mixture getting to the combustion chamber. Single Port heads are pretty restrictive in terms flowing big fuel/air mixtures. Also restrictive are available manifold / carburetor choices. When was the last time you saw, even on custom made manifolds, dual 48 Webers on a Single Port head engine? I believe the practical limit for Single Port engines is 1776 and should be done only to increase torque performance numbers. Small valves, small runners, taller intake manifolds and small carburetion sizes coupled with larger displacement will improve engine torque.
A 1776cc engine with Single Port heads, dual 28 to 34 mm carburetors on tall manifolds, a high torque cam (sometimes called a RV cams by engine builders), a torque tuned header/collector and an efficient ignition system should be a great engine for around town or endless hours on the highway. BTW, terrible at the drag strip.
Most driving needs torque not horsepower, which is why some people love diesel power. Confused
'65 T1 Sedan
'87 T3 Syncro
TomSimon
TomSimon is offline
PostPosted: Sat Aug 15, 2009 7:11 am    Post subject: Re: Single Port 1776 Reply with quote
slo356 wrote:
Physically, you can built a Single Port head engine as large as any other head choice (dual Port). The real limit to useable increases in engine size is the availability of fuel/air mixture getting to the combustion chamber. Single Port heads are pretty restrictive in terms flowing big fuel/air mixtures. Also restrictive are available manifold / carburetor choices. .. Confused
I think it was Dave Cormack that did a story in hotVW's or VW Trends about a set of single port 1600 heads that Fred Simpson did (back in the late 90"s?) called Psycho-Single ports or something like that.
I don't remember numbers, but the engine that was built around those heads was VERY impressive. can't remember what he used for the rest of the intake, but it was nothing exotic
Just a little hop for anyone who wants to build a stump-puller of a VW bus engine around the under appreciated single port...
Jimmy111
Jimmy111 is offline
PostPosted: Sun Aug 16, 2009 4:09 pm    Post subject: Reply with quote
You can build a 2332 if you want to.
I saw a 2180 that was dynoed at 157HP 5 years ago. and 5800 RPM
Of course the crappy intake has got to go.
peoplesvw
peoplesvw is offline
PostPosted: Mon Aug 17, 2009 2:13 pm    Post subject: Reply with quote
singleport?
Awesome..... Twisted Evil
Spezialist
Banned
Spezialist is offline
PostPosted: Mon Aug 17, 2009 8:22 pm    Post subject: Reply with quote
You could get away with a bunch of cc's if you had really trick dual manifolds made
Popcorn
bvilletom
bvilletom is offline
PostPosted: Tue Aug 18, 2009 7:54 pm    Post subject: Single port motors Reply with quote
I have been building single port VWs for 4 years now in the 36 HP challenge and have a whole new respect for them. You can make a single port really breathe; it takes very detailed port work and hand fabricated tapered intake manifolds, and fairly large single barrel carbs. If the manifold works right it will actually make the flow numbers at the valve increase from just the head alone. It's all about velocity on the flow bench. If you flow an entire intake system air cleaner, through intake valve, it becomes a very interesting study.
Bville Tom
bvilletom
36hp Challenge record holder New Age 126.236mph
1970 Porsche 914/6 – 2 liter LSR record holder
1992 Metro Sedan – 1 liter LSR records
1987 Chevy Turbo Sprint – under construction
