Stanw3 Samba Member
Joined: September 26, 2003 Posts: 1077 Location: Albuquerque, NM
Posted: Wed Apr 01, 2009 9:29 am Post subject: Ragtop Rebuild |
I'm rebuilding the ragtop assembly for my 65.
For refernce: I also had to replace my "sex screws". I couldn't bring myself to pay the $5.00 each that the replacements cost so I went to ACE hardware and put my own together for about $1.50 each.
I used loctite on one end so it adjusts like the original.
I flipped them so the beveled end is on bottom - no heads pushing out on the headliner:
OG
Flipped
Before:
After:
Ian Samba Moderator
Posted: Thu Apr 02, 2009 11:36 am Post subject: |
I have no clue but what you've done so far looks real nice. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024 |
2Pack Samba Member
Joined: September 20, 2005 Posts: 813 Location: Virginia
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1349 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Thu Apr 02, 2009 11:40 am Post subject: |
I know your frustration. I redid my roof a few years back and ended up reusing my original foam instead of the door seal foam WW sends. Didn't like having to do it but it worked. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Stanw3 Samba Member
Posted: Fri Apr 03, 2009 7:54 pm Post subject: |
I see that VW Sunroofs sells the foam blocks for $11 each plus shipping. Uh, yah - mine aren't bad enough to warrant that. I added a layer of camper-top foam seal to get things back to a decent height. All good.
I also had to replace the tack strip on the header bow. Rust just plain sucks. :
_________________ Sanborn7
www.facebook.com/Sanborn7 |
Stanw3 Samba Member
Posted: Sun Apr 05, 2009 8:12 pm Post subject: |
All done. Three trailing bows and one header bow - ready for install.
Out of the 6 blocks on the trailing bows only one was missing. The other five were all in nice shape. I rouned the corners of the replacement block to mimic the originals.
The internal mechanism works much better without the extra rust.
I found these in my bag of spare parts but I have no idea what they are. Anyone recognize them??
Ian Samba Moderator
Posted: Sun Apr 05, 2009 8:25 pm Post subject: |
I believe the three on the left are for mounting the rear splash pans, they are reinforcement inside the corner. I think. _________________ All your Buses are belong to us.
EverettB  Administrator
Joined: April 11, 2000 Posts: 72016 Location: Phoenix 602
Kelly Samba Member
Joined: November 25, 2003 Posts: 2437 Location: Olympia, WA
Posted: Mon Apr 06, 2009 5:27 am Post subject: |
great job with the sunroof bows!
The only thing I did different was I added black heat shrink on the ends of the bows to finish it off. _________________ It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky |
Stanw3 Samba Member
Posted: Mon Apr 06, 2009 6:19 am Post subject: |
Thanks Ian and Jack. I need to find something for the ends before it allgoes together.
Ev - any idea on the pieces on the right? The screw hole is beveled. _________________ Sanborn7
Stanw3 Samba Member
Posted: Sat Sep 05, 2009 2:50 pm Post subject: |
Mostly done - pics for posterity.
First - color sand the roof with 800, 1000, 1200
Buff it till it's chiney!
Lay out the bones - get everything even
Put in the webbing to help everything close up nice:
Look at that front lip!!! I can hardly believe it came out so straight!
MAJOR props to the Master himself, Senor Jorge Coblentz for letting me watch him do his and answering all my phone calls when I did mine! I could never have done it without his help! _________________ Sanborn7
royDHPNM Samba Member
Joined: June 02, 2007 Posts: 359 Location: Albuquerque
Posted: Sat Sep 05, 2009 4:24 pm Post subject: |
it is one sweet bus man. great work all around
if I can ever afford it you will be my first choice for a painter _________________ DHP, bringing the Dry Heat
WHAT?!
http://www.dhpvw.com/
El Roy Pinstriping on Facebook |
Vermeulen Samba Member
Joined: October 30, 2005 Posts: 250 Location: Belgium
Kelly Samba Member
Posted: Sun Sep 06, 2009 5:04 am Post subject: |
nice job!
Lays flat and the front looks perfect.
I noticed when your rag is back it lays flat on itself, and I've seen this on several other buses. Mine seems to puff up. I wonder, is there a particular order in which the bows go to prevent this? _________________ It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky |
Stanw3 Samba Member
Posted: Sun Sep 06, 2009 7:47 am Post subject: |
Nah, the three rear bows are all identical. I'd guess it has more to do with the spacing of the bows and the bend/angle of the rear of the bows (how it pushes the material as it goes back). _________________ Sanborn7
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1666 Location: Budapest, Hungary
Posted: Sun Sep 06, 2009 8:36 am Post subject: |
| Nice job, I like informative threads like this. |
Stanw3 Samba Member
Posted: Sun Sep 06, 2009 1:10 pm Post subject: |
I don't recognize that. Looks like some padding - not sure about the square in the center. Neither were in my sunroof. _________________ Sanborn7
