pcon42 Samba Member
Posted: Sun Sep 06, 2009 4:40 am Post subject: No Wire on Oil Sensor Switch 78 bus |
After cleaning the engine and compartment with a degreaser, my engine will now not start. I didn't douse it at all. Have a spark off the coil and today will test if the distributor works and the plugs. I did notice there is no wire to the oil switch. Can this be the simple problem?
Thanks |
Rusty O'Toole Samba Member
Posted: Sun Sep 06, 2009 5:26 am Post subject: |
Hook it up and see. Some engines are wired so if you lose oil pressure it kills the ignition. Not sure if VW ever did this.
You may have knocked something else loose accidentally. Go around and push all the electrical connectors on good and vacuum hoses too. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Sun Sep 06, 2009 5:29 am Post subject: |
Rusty O'Toole wrote: |
Some engines are wired so if you lose oil pressure it kills the ignition. Not sure if VW ever did this. |
Definitely not. The lack of wire to the oil pressure switch isn't cauing your engine not to start. If it ran before you cleaned it, it has to be a simple problem. Spray some WD-40 under the cap and give it another go. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
pcon42 Samba Member
Posted: Sun Sep 06, 2009 5:51 am Post subject: no luck |
Tried the wd 40 but not luck, checked the hoses and all are in order. Go figure, wanted to make my first bus nice looking and I screwed it up!
Any other advice?
Saw a post to check the spark on everything.
Thanks |
pcon42 Samba Member
Posted: Sun Sep 06, 2009 9:53 am Post subject: Problem solved! |
Remembered I took a picture before I bought this bus, blew it up and saw I had one wire missing. Now it starts. Thanks for the help. |
kerian159 Samba Member
Joined: February 24, 2008 Posts: 344 Location: Pensacola, FL
Posted: Sun Sep 06, 2009 10:06 am Post subject: |
Yay! always take pics of stuff I tell that to older people when they need to bring their computer to me to work on. Digital or Polaroid works when brain's do not!
Jay _________________ 1976 Type II Westy P22
"Growing older, but not up!" |
