Early Oval fender Identification
Nifski
Nifski is offline
PostPosted: Fri Sep 04, 2009 9:15 am    Post subject: Early Oval fender Identification Reply with quote
I am currently restoring a '54 Sedan and have these two bullets, my first intention was to remove the bullets if I could not locate the correct fronts but upon taking the car apart I noticed the differences in the running board flares as well as the headlight buckets, the fender shapes look the same.
Which one is earlier? which one (shape) would be correct for my car other then the bullet. I would rather buy correct fenders if anyone knows of any, but need to get educated on this as plan B .Thanks for any help!
Oval fender differences
Drivers side bucket
Passenger side bucket
Driver side flare
Passenger side flare
joshbuchan
joshbuchan is offline
PostPosted: Fri Sep 04, 2009 10:14 am    Post subject: Reply with quote
pass side looks right, the bucket on pre 55 should be smooth like that with no vertical pressings Cool not sure why it would have a bullet... mabey late 55 Question
Braukuche
Braukuche is offline
PostPosted: Fri Sep 04, 2009 11:11 am    Post subject: Reply with quote
Check the housing on the non-flared fender. I'll bet its added on and not an original bullet fender.
--Dan
Nifski
Nifski is offline
PostPosted: Fri Sep 04, 2009 11:21 am    Post subject: Reply with quote
After taking a close look, the passenger side has had the bullet added, so this means it was an early oval fender, '55 or older with an added bullet, correct?
slowtwitch
slowtwitch is offline
PostPosted: Fri Sep 04, 2009 12:36 pm    Post subject: Reply with quote
I'm in the proces of saving a pair of early fenders. As has been mentioned , early fenders had a smoother headlight bucket.
Another way to determine if you have early fenders, is to take a measurement across the fender. Take a tape measure, place it centered with the top most mounting hole (5th hole, either from the front or rear) and mearsure to the lip of the fender.
This is a later fender....
This is an early fender...
As you can see, there is about an inch difference.
hope this helps
pete
janerick3
janerick3 is offline
PostPosted: Fri Sep 04, 2009 8:29 pm    Post subject: Reply with quote
My og late '56 buckets don't have the vertical pressing either, so the passenger side is probably off a late oval. The bullets are only spot-welded on, so they are relatively easy to remove and replace if the fender was repaired.
The driver's side is probably genuine VW from the '60s, as the horn grill hole is the same location as the pass. side (unlike aftermarket fenders). Look for a welded-up turn signal hole on top.
Thanks,
Jan K.
Nifski
Nifski is offline
PostPosted: Sat Sep 05, 2009 11:32 am    Post subject: Reply with quote
Seems like two different responses,can we get a few more opinions?Thanks.
oval-man
oval-man is offline
PostPosted: Wed Sep 09, 2009 5:00 am    Post subject: Re: Early Oval fender Identification Reply with quote
[quote="Nifski"]Oval fender differences
Drivers side bucket
Hi
The drive side one is 100% not a oval wing it's for a 60's car due the headlamp bowl is the wrong shape.
but the other one is for a early oval 53> 55 all you need to find a match.
good luck
Jay
www.restowagenuk.com
valentinesr
valentinesr is offline
PostPosted: Wed Sep 09, 2009 7:08 am    Post subject: Re: Early Oval fender Identification Reply with quote
Hi
good luck
Jay
Uhhh, not to be a smarty pants Jay or anything..but they didnt have bullet fenders until midway through 55 when they started that modification..
I agree on the passenger side is an OG fender, see the bucket contour inside is smooth, along with the flared running board area. The drivers side has the dimpled rectangular indention inside the bucket..so from reading and have had a set of that style..Not original.
Fender Reference Threads:
http://www.thesamba.com/vw/forum/viewtopic.php?t=307483&highlight=fender
http://www.thesamba.com/vw/forum/viewtopic.php?t=295256&highlight=fender
Valentine, Ray J Sr.
Ontario, California
thebucket wrote:
I gave my oval a nasty look. Money hungry bitch....
(Delilah) http://www.thesamba.com/vw/forum/viewtopic.php?t=319235
1954 Parts Book (CD PDF) PM TO INQUIRE
oval-man
oval-man is offline
PostPosted: Thu Sep 17, 2009 7:27 am    Post subject: Re: Early Oval fender Identification Reply with quote
valentinesr wrote:
Hi
good luck
Jay
You are quite right there, when I post this I forgot about you guy with the bullet fenders Laughing I was referring to euro fenders with my quote with regards the year date.
I have both a 60's euro fender and an oval euro fender I will post some photo's up later so you can have look at.
Jay Very Happy
