Vin Plate Restoration
Page: Previous  1, 2, 3
543fold
543fold is offline
PostPosted: Thu Oct 08, 2009 8:03 am    Post subject: Reply with quote
Has anyone tried a vibratory tumbler/polisher?
https://www.instagram.com/w.a.r._wills.auto.restoration/
______________________
....even the rust has rust!
How "NICE" do you wanna spend?
W.A.R.
Will's Auto Restoration
VWwerks
VWwerks is offline
PostPosted: Thu Oct 08, 2009 9:27 am    Post subject: Reply with quote
I tried tumbling and it didn't work as well or as fast as a light glass bead blast.
Glass bead, clear zinc plate... works perfect every time. I have done at least 20 or so this way. Some really rusted and some not very bad, all came out great. Glass bead leaves a nice uniform satin finish for the clear zink.
I use an aircraft rivet set on an air hammer to put them back on. With the gas tank out it is easy to hold a "buck" (any chunk of metal, even a hammer works) behind the rivet and a quick shot with an air hammer and you're done.
www.VWwerks.com
54vert
54vert is offline
PostPosted: Fri Nov 06, 2009 10:42 am    Post subject: Reply with quote
Jim.....I took my vin plate and made in Western Germany plate to a local metal finishing shop which does zinc plating....they tried twice to glass bead blast and clear zinc the two plates and they still have not turned out right....the bead blast does not appear uniform and the clear zinc has a spotty yellow color to it....the platers stated that is what clear zinc does unless you add chromate to it which then gives is a silvery blue color (does not appear to have that bare metel look anymore).
I was wondering if I could send them to you to have done since you have had 20 or so done with no problems and if so, how much?
Thanks...James
56 type 1 vert 54 type 1 vert
Bruce
Bruce is offline
PostPosted: Fri Nov 06, 2009 9:02 pm    Post subject: Reply with quote
Why not use the original, cadmium?
Russ
Russ is offline
PostPosted: Fri Nov 06, 2009 11:06 pm    Post subject: Re: figured i would revive this Reply with quote
Russ wrote:
just had my vin tag lightly blasted then i sent it out for zinc plating.it turned out really well.
not sure if the made in germany tag is supposed to be like this or black but i went with zinc and i'm happy
i just used a zinc finish and they turned out great.
Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:)
JeffRens
JeffRens is offline
PostPosted: Sun Jan 05, 2014 8:22 pm    Post subject: Reply with quote
Lemon juice and a toothbrush... amazing results on my VIN plate. Gotta say I'm kinda concerned about licencing my car after reading this post. I have a donor apron I need to put my VIN plate on and a non-matching pan. Wish me luck....
Page 3 of 3
