Is it worth lowering a classic VW Beetle?
ronbdavis
ronbdavis is offline
PostPosted: Tue Oct 13, 2009 6:30 pm    Post subject: Reply with quote
Glenn, have you installed caster shims? And had you considered dropped spindles either instead of, or in combination with, the adjustable beam?
I have a late model I would like to lower a bit, but am thinking the standard 2 1/2" drop from spindles may be more than I like. Lately I am thinking more of a Ron Lummus narrowed (2-3"), adjustable beam instead. I can turn bolts but can't weld worth a damn.
vespaboy200
vespaboy200 is offline
PostPosted: Wed Oct 14, 2009 7:14 am    Post subject: Reply with quote
Glenn wrote:
vespaboy200 wrote:
So in my conclusion it is not worth lowering your VW Beetle with lowered beams ,its not safe!it doesn't add performance!And adds excessive wear on the suspension...
If its a daily driver,trust me do not use the adjustable beam method....no good!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!DANGER>>>>DANGER>>>>DANGER>>>>
I've had different results, i've put over 100,000 miles on this setup and feel it handles better, brakes better and rides like stock.
Avis adjusters lowered 3"
19mm front anti-roll bar
KYB GR2 shocks (72 Opel GT) 2" shorter
Rear dropped 1"
25mm rear anti-roll bar
KYB GR2 shocks (VW)
5.5x15 ET42 Porsche/Pedrini aluminum wheels
195/60-15 tires
It handles like a go kart.
Sounds good....may be it was just the crappy hack job the last owner did to the beam ....
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Oct 14, 2009 7:27 am    Post subject: Reply with quote
Yes... I have single shims.
I didn't want dropped spindles. First off the push the wheels out and with 195 tires, I would of had to narrow the beam. Also I wanted to go lower then the set 2.5" of dropped spindles.
The trick to a nice ride are the shorter front shocks. If you use stock shocks, the rate are progressive. Meaning the more you compress them the harder they get. So putting them on a lowered beam means that are always compressed a few inches.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
dubtype1
Vdubn' Till I Die
dubtype1 is offline
PostPosted: Wed Oct 14, 2009 9:08 am    Post subject: Reply with quote
vespaboy200 wrote:
It begins......back to original,replacing everything except rims and tires...
You couldn't of been that low runnin' those tall ass tires......
MIAMI V-DUBS
Caleb
'65 Beetle project
vespaboy200
PostPosted: Wed Oct 14, 2009 6:47 pm    Post subject: Reply with quote
It never ends... Shocked
vespaboy200
PostPosted: Sun Oct 18, 2009 7:17 pm    Post subject: Reply with quote
All shocks and damper in drives really nice....but the ass end is a lil low i think...does anyone know the stock height of a vw beetle?
vwsb74
vwsb74 is offline
PostPosted: Sun Oct 18, 2009 7:30 pm    Post subject: Reply with quote
Glenn wrote:
Madtat wrote:
if you lower it properly and follow up with some $ on suspension componets for your application it will handle properly .
Exactly... mine handles great.
3" in the front and 1" in the rear but some other upgrades.
Glen, how many splines did you turn to get 1 inch drop at the rear?thanks
Mr. 010
Glenn is offline
PostPosted: Sun Oct 18, 2009 7:32 pm    Post subject: Reply with quote
It was a combination of inner and outer splines. Honestly, I did it 15 years ago and don't remember the exact combo.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
vespaboy200
PostPosted: Mon Oct 19, 2009 8:24 pm    Post subject: Reply with quote
car drives nice now except when i get on the highway and once i get up to about 60 mph the front starts to bounce like crazy......................
what could it be...ive replaced all the shocks and damper...
Endicott jb
Bondo King
Endicott jb is offline
PostPosted: Mon Oct 19, 2009 8:30 pm    Post subject: Reply with quote
It's because stock does that.
Josh
OORAH!!
1965 vw beetle(Mayble)
1968 vw beetle(Caroline)
1974 VW Panel Bus
2003 Dodge 2500 5.9 Cummins(Katey)
.|_____|.
(0\_!_/0)
Don't drink and post
http://i540.photobucket.com/albums/gg353/endicott_jb/IMG_20110113_085237.jpg
When life throws you curveballs switch to boomerangs.
Max Welton
Max Welton is offline
PostPosted: Mon Oct 19, 2009 9:12 pm    Post subject: Reply with quote
Really? Mine doesn't.
Max
1967 Type-3 Fastback
Inane Cathode
Inane Cathode is offline
PostPosted: Mon Oct 19, 2009 9:23 pm    Post subject: Reply with quote
Me neither
Max Welton
PostPosted: Mon Oct 19, 2009 9:39 pm    Post subject: Reply with quote
Vespaboy200, what size tires you got up front? And what pressure?
Max
69 Jim
69 Jim is offline
PostPosted: Mon Oct 19, 2009 9:52 pm    Post subject: Reply with quote
Max
Same here.
hoghead5150
hoghead5150 is offline
PostPosted: Mon Oct 19, 2009 11:48 pm    Post subject: Reply with quote
most likely tires. are they balanced? how old are they?
"i got a friend that knows a guy who's best friend has an uncle that used to have a bug just like yours!"
i measured once, cut it three times, and the damn thing is STILL to short!
vespaboy200
PostPosted: Wed Oct 21, 2009 3:50 pm    Post subject: Reply with quote
Wink
Max Welton
PostPosted: Wed Oct 21, 2009 4:11 pm    Post subject: Reply with quote
vespaboy200 wrote:
What I have noticed is that the bounce only starts after hitting a bump on the road and it gets worse as the car accelerates ...
That sounds like bad shocks.
Max
vespaboy200
PostPosted: Wed Oct 21, 2009 10:47 pm    Post subject: Reply with quote
Arrow
LeviMan2001
Samba Post Whore
LeviMan2001 is offline
PostPosted: Thu Oct 22, 2009 12:39 am    Post subject: Reply with quote
vespaboy200 wrote:
Max
All new shocks... the frame head pan is weak...
Lets just hope the car doesn't all of a sudden just lower itself while driving then Laughing
http://www.thesamba.com/vw/forum/viewtopic.php?t=366056 - My '73 Super Build. 2332cc, 16" Fuchs
vespaboy200
PostPosted: Thu Oct 22, 2009 6:01 am    Post subject: Reply with quote
no that will not happen,I would never lower a beetle again,unless its my new beetle 2001....
Page 4 of 8
